2.8 carb rebuild ?? - S-10 Forum
post #1 of 32 Old 02-22-2010, 10:50 PM Thread Starter
User is: stevew007 is offline
2.8 carb rebuild ??
is it hard and is it worth it ? a buddy of mine said that it's not worth it because it will leak he also said i could get a new one for under $150 but AZ wants almost $500
post #2 of 32 Old 02-22-2010, 11:06 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
Re: 2.8 carb rebuild ??
an aftermaket carb&intake would probably be cheaper.
http://www.jegs.com/i/Edelbrock/350/...oductId=745125
Teamsters Local 1150
SH-60B is offline
post #3 of 32 Old 02-22-2010, 11:20 PM
adamwilkes20's Avatar
User is: adamwilkes20 is offline
if it is done right it should be okay...I mean a Holley 2bbl is gonna set you back $300 alone...maybe ask around to local shops and see what they would charge for the rebuild...
post #4 of 32 Old 02-23-2010, 01:16 AM
User is: slosteve is offline
I had one rebuilt at a local carb shop (with a good reputation) and it runs great - no leaks. Wasn't all that pricey either.
slosteve is offline
post #5 of 32 Old 02-23-2010, 09:03 AM Thread Starter
I've rebuilt a couple of carbs i just want to make sure it's worth it. I was goinf to rebuild the carb on my samurai but those things are a POS and even if a 50year vet rebuilt it the truck still wouldent run the same
post #6 of 32 Old 02-23-2010, 12:06 PM
joed's Avatar
User is: joed is offline
"because it will leak" ??
It will leak if it's already leaking. You sure you've rebuilt a carb before?...if so why are you asking this?
1985 Black Chevy S-10 v6 2.8L 4x4
Rochester 2se carb
joed is offline
post #7 of 32 Old 02-23-2010, 04:26 PM
Awww..you ain't got shit!
jimmykicker's Avatar
. Yep, this is exactly the reason I swapped to the Holley. My original was toast and not worth rebuilding. A few will argue this with me, but I don't think they have experienced th Holley with the intake. My mileage actually improved if you keep your foot out of it (hard).
I think the truck is overall better. However, if you can build it cheap you might be better off. No doubt the Holley is the way to go vs buying a new or rebuilt one dollar for dollar imo.
1984 xcab s-10 3.4L GM crate engine 87 S10 TBI swap w bored intake, Edelbrock headers. 3.42 locker rear end swap. Flowmaster, shift kit, e-fan.
EFI swap http://www.s10forum.com/forum/f106/c...e-help-513616/
My build thread (3.4L)http://www.s10forum.com/forum/f106/b...stions-427168/
I had to cut my nut in half .
post #8 of 32 Old 02-23-2010, 07:27 PM
joed's Avatar
All stock carbs leak? Holley's don't leak?
Jimmy and I are on opposite sides of this fence...but it's ok, he's been wrong for a while now
But seriously, Jimmy how can you really suggest the Holley route? He's looking at spending way more than you're leading on.
1. carb kit could run you $20 or so.
If the carb is ok and you know what you're doing....then bam - done.
2. a remanufactired carb with a core return will run you $180 or so. www.guaranteedcarbs.com. Off with old carb, on with new.
Bam - done.
3. Holley is likely gonna run ya $300+, on top of the new intake you'll buy (more time/work there as well).
Then time to rig it up for usage.
Then, sorry but there's worse mpg with the Holley option compared to staying with stock.
Then...bam, done.
If time and $ are a factor....is it really a tough decision here?
Why not have the carb examined at least to see if a rebuild is better? (option 1)
If not, option 2 is a lot less $ and work.
With option 3, once it's complete...you then get to incessantly reply to others how they should do what you did and get a Holley.
*Jimmykick - I kid because I care.
Rochester 2se carb
joed is offline
post #9 of 32 Old 02-23-2010, 08:06 PM Thread Starter
the truck was well taken care of and I am going to rebuild the carb this week. because cheaper is better at the moment (yes I know)but with plans for a v8 swap i dont want to spend a ton of money on it.
post #10 of 32 Old 02-23-2010, 08:51 PM
User is: crash55 is offline
don't foget to buy a new float they are known to get bad over the years
crash55 is offline
post #11 of 32 Old 02-23-2010, 09:45 PM
It's "Neanderthal"
SH-60B's Avatar
X2 for a float. That $20 "carb kit" won't have one. It probably doesn't have the throttle shaft bushings and reamer you'll need to stop the vacuum leaks at the worn out shaft. So.....Bam - some things to think about.
SH-60B is offline
post #12 of 32 Old 02-23-2010, 09:58 PM
joed's Avatar
Yeah, the separate float game is kinda BS...but that's how they do.
That should be in a carb kit (really).
A quality kit should have the bushings, you can always ask.
Note: there is no info stating the carb IS leaking btw (just a rough guess from a buddy it sounds like). Heck, there's no info that it's in need of a rebuild for that matter either. Yer gonna have to check it.
What's the problem to make you ask about a carb rebuild btw?
Rochester 2se carb
joed is offline
post #13 of 32 Old 02-23-2010, 10:03 PM
joed's Avatar
How's your mech fuel pump doin? Orig?
How's the fuel filter?
Rochester 2se carb
joed is offline
post #14 of 32 Old 02-23-2010, 10:15 PM Thread Starter
this is what I have to do to start it after sitting over night.
stick the gas to the floor (the whole time while starting)
it turns and turns and turns almost a minute before it even start's to fire once it starts to fire a little i still need to keep the starter going because it's just not there yet.once it finally fires enough to let off the key I still have the gas to the floor while it chuggs its way to an idle and then to a rev and thats when i let off the gas and start to feather it to keep running until it will idle by its self. BUT once it warms up i can start it up without even touching the gas pedal. then if it sit's for say an hour or so in the 35* wheather i have to go through it all again. it also backfires when i rev it up
yes the bad carb did come from a buddy of mine that has a 2.8 that had a bad float. I'm going to dig in tomorrow first off i'm going to replace the fuel filter.then hit it with the timing light
post #15 of 32 Old 02-23-2010, 10:16 PM Thread Starter
not sure about either! I'm going to get a new filter in the morn. is there a way to test the pump?
post #16 of 32 Old 02-23-2010, 10:25 PM
joed's Avatar
Hmmmm...carb from a friend, but did you replace the known bad parts (float)?
Still, ya know, I think I'd be changing that mech fuel pump, def fuel filter (cheap-cheap) AND may as well rebuild the carb. Your description is coming from what one would do to start if the carb was flooded i realize...but it's also a possible sign of a worn mech fuel pump too.
Is it orig ya think?
Before I got the reman carb I replaced the mech fuel pump after having like symptoms, and the starting issue was resolved. I knew mine was orig so i didn't test it. Now it's just pump the pedal a few times before turning the key, then start and let her idle till warm. Pretty standard.
They don't last forever (although longer than an in-tank) and they aren't all that much (don't have to be that is).
Not too diffcult to replace btw, just gotta get in there.
While we're at it, how's the choke operating? When it starts, is it going into high idle and then subsiding when warm?
Separate part once again, not too crazy to replace (drill out old rivets, replace part for proper operation, use screws instead of rivets (or re-rivet if you want).
Rochester 2se carb
joed is offline
post #17 of 32 Old 02-23-2010, 10:25 PM
heeter_33's Avatar
User is: heeter_33 is offline
ya mine needs to be rebuilt badly too, but im just going to wait and drop in a 350 and buy a 4 barrel haha.
1985 S10 2.8
2010 Cobalt SS
1972 Honda CB100
post #18 of 32 Old 02-23-2010, 10:38 PM
joed's Avatar
There ya go, this reply should help ya. He's going to get a 4-barrel for stop and go traffic.
So your all set Steve!
Rochester 2se carb
joed is offline
post #19 of 32 Old 02-23-2010, 10:41 PM Thread Starter
thanx joed I will post up tomorrow night and let you guys know what I come up with
post #20 of 32 Old 02-23-2010, 10:46 PM
joed's Avatar
Another cheap-cheap but def worth replacing - the vac lines. They ok?
In fact, I'd do each in order of least expensive on up.
Check out www.rockauto.com btw for parts (excell service imo).
Rochester 2se carb
joed is offline
post #21 of 32 Old 02-23-2010, 10:56 PM
joed's Avatar
Doh, sorry - don't mean to add to your cost and work, but don't forget the vacuum pulloffs (yep, they go bad as well).
So carbwise, if it comes down to this as a culprit...maybe weigh in on the cost of a reman ($180-190 at the link I sent, good company btw) vs. rebuilding and more parts (pulloffs, choke, float, etc) yourself?
Might be cheaper, less time consuming to get the reman.
Replace the mech fuel pump for piece of mind yourself, espec if I suspected it was orig. ACdelco or even a Carter... to a cheap airtex to get ya by (since you might be upgrading it all anyways).
Rochester 2se carb
joed is offline
post #22 of 32 Old 02-24-2010, 10:40 AM
heeter_33's Avatar
lol we dont really have stop and go traffic here, so it shouldnt be too bad
1985 S10 2.8
2010 Cobalt SS
1972 Honda CB100
post #23 of 32 Old 02-24-2010, 06:02 PM Thread Starter
well i replaced the fuel filter and it fired right up.
but she still needs work
I started ripping everything off the extirior badge ,wing,mouldings stuff like that.
but here is what it looked like when i bought it.I did run into a huge problem found out that the front of the roof had been caved in at the windsheild and the roof has a ass ton of bondo in it. I might have to cut it off and get a donor
post #24 of 32 Old 02-24-2010, 06:09 PM
It's "Neanderthal"
SH-60B's Avatar
That was easy.
SH-60B is offline
post #25 of 32 Old 02-24-2010, 06:16 PM
heeter_33's Avatar
how hard was it changing that filter?
1985 S10 2.8
2010 Cobalt SS
1972 Honda CB100
post #26 of 32 Old 02-24-2010, 07:56 PM Thread Starter
not to bad could of been easier if the line nut was not stripped to hell.
post #27 of 32 Old 02-24-2010, 08:11 PM
joed's Avatar
Bamm - $2.00 part!
Cool. I'd replace it once a year min maybe.
* if it were me I'd still consider a carb clean or at least run some seafoam or Lucas fuel sys cleaner, replace the bad float you mentioned, and I'd check or flat out replace the mech fuel pump for piece of mind.
I hear ya on the inlet/line nuts. I pipe cut my fuel hardline end, got a different fuel inlet with a tapered end (screws into carb, holds spring and paper fuel filter), and routed fuel line around and back into the carb (even added a 2nd larger fuel filter inline). Less fighting for clearance in getting that inlet out to change fuel filter).
Rochester 2se carb
joed is offline
post #28 of 32 Old 02-24-2010, 08:45 PM Thread Starter
Bamm - $2.00 part!
well im not sure the float is bad.my buddy just mentioned it might be bad.
post #29 of 32 Old 02-25-2010, 10:24 PM
Bamm - $2.00 part!
Yeah, that stock carb inlet is a real f*cker. I remember having that issue with mine and cutting it like Joe did. I think I might hae actually had a pinhole in it....That's been so long ago I can't remember.
Joe....I love you man! We gotta get together one day, have a beer or two and argue about our carburetors. Then I'll let you drive my truck. . Nah, you are probably right on. He probably is better off rebuilding it anyway...You are right, it is a lot cheaper. I wasn't "advocating" that really. It's just an option. I probably wouldn't do it either if I was on a budget, or wasn't really looking for an upgrade in performance. I'll admit it was more expensive, but I have no regrets because I wanted better performance and the mileage didn't suffer. I knew I'd be putting 3.4 and spending some $ on this truck, so I didn't mind. Check out this video before I pulled the 2.8 with the leaky freeze plugs. This is pretty much a cold start with the Holley.
http://www.youtube.com/watch?v=-draPb2oiiI
For the record, it wasn't really that hard putting it on. There wasn't really any "rigging". The biggest problem I ran into was the sh*tty instructions that came with it. I had to cut a little groove into the throttle bracket to make it work and find a throttle cable that was a shorter working length. It would have been nice if they had included that info. Otherwise it wasn't really hard at all. It came with all the necessary goodies and even told you the right kickdown cable you would need.
I would still like to see how the stock carburetor does on that Edelbrock intake. As I go along, I might even do away with the carburetor all together and go EFI and slap a throttle body on top of that intake...That might be really cool!!
Joe, we gotta do that beer sometime....seriously!
post #30 of 32 Old 02-26-2010, 09:53 PM
joed's Avatar
Yo JimmyKick...I do know one thing - I ain't gonna try and race ya with my stocker. You got me there!
I do like beer ...maybe we can one day
Rochester 2se carb
joed is offline
post #31 of 32 Old 02-26-2010, 09:55 PM
joed's Avatar
Well, I'd at least look at it, they get old and crusty/fall apart bit by bit (don't want bits in bowl).
Rochester 2se carb
joed is offline
post #32 of 32 Old 02-28-2010, 09:48 PM
Yeah, maybe we'll do some homebrew I have. Don't worry, it's from a "kit", and it is actually pretty damn good.
As far as the truck is concerned, it's still no racecar, but it does get down the road real well. Even with the 3.4 that's not what I am after. I just want a neat/nice old truck that drives like a new one. One that has some mild mods and is streetable. Hence the reason I didn't put a V8 in it. Now that is some rigging I don't want any part of. I hope that the the performance is really good when the 3.4 project is complete. I'm really starting to get excited about it too. I'm almost done cleaning the frame, and next week will probably start wiring up my fuel pump if I am satisfied with how clean the body is under there. I really am planning on taking my time with it though. I've got way too much money and time in it now to slap it together.
