1992 s10 blazer no power to fuel pump - S-10 Forum
post #1 of 7 Old 04-25-2010, 07:36 PM Thread Starter
User is: S10HelleruD is offline
changed pump think relay is ok what else could be wrong? grounds are all good! how do you check to see if a relay is good again?
post #2 of 7 Old 04-25-2010, 07:59 PM
Mr. SQ
bobditts's Avatar
User is: bobditts is offline
Re: 1992 s10 blazer no power to fuel pump
check the fuses. To check the relay, run power to the pigtail that is coming off of the relay.
bobditts is offline
post #3 of 7 Old 04-26-2010, 03:02 AM Thread Starter
Thank you i figured it out twas my buddys dumb self that when he replaced the fuel pump for me he didt plug it in!!!!! but anyone know if they had black interior in any s10 blazer?? and would a 94 dash fit into a 92
post #4 of 7 Old 04-26-2010, 08:24 AM
Mr. SQ
bobditts's Avatar
yes there was a black interior for s10 blazers. Have no idea about the dash.
bobditts is offline
post #5 of 7 Old 05-02-2010, 10:47 PM
Older Than Dirt
compmikey's Avatar
User is: compmikey is offline
check those fuses! "ECM-B" comes to mind, but check as many as you can.
post #6 of 7 Old 05-04-2010, 05:23 AM
User is: secondgencamaro is offline
Definitely check this one in particular.
'76 Camaro 400ci - TH-350 - 3.08:1 - 3,760lbs w/o driver
'93 S-10 3.4L - std cab - short bed
post #7 of 7 Old 05-04-2010, 05:32 AM
Equinsu Ocha!
350X's Avatar
User is: 350X is offline
Go hook up with this guys n help each other.
Same year GM and he can't get his FP to turn off
http://www.s10forum.com/forum/f135/t...unning-439793/
Like a bad reese's pieces commercial
350X is offline
