1986 2.8L TBI Fuel Pressure? - S-10 Forum
post #1 of 11 Old 01-05-2009, 12:54 PM Thread Starter
User is: jregezeino is offline
What should my fuel pressure be with the TBI on the 2.8? My pump is only putting out about 5 psi and then quickly drops back to zero when the key is 'on' and the pump is priming. Does this indicate a bad pump?
post #2 of 11 Old 01-05-2009, 01:40 PM
34blazer's Avatar
User is: 34blazer is offline
Re: 1986 2.8L TBI Fuel Pressure?
11-15 psi, id say you have a bad pump or regulator
USAF
'86 Grand National - LZ9 swap(in progress)
'97 Ram SS/T 360/.030 over.
34blazer is offline
post #3 of 11 Old 01-05-2009, 02:41 PM Thread Starter
ok. although, it does seem to be running rich...would that be the TB trying to compensate for the low pressure?
post #4 of 11 Old 01-05-2009, 03:45 PM
34blazer's Avatar
check to see if one(or both) of the injectors are leaking.
USAF
34blazer is offline
post #5 of 11 Old 01-05-2009, 05:51 PM
taylordoege's Avatar
User is: taylordoege is offline
more info. if you can what kind of tbi, year of your truck.
cuz i have a 93 s10 with a 220 tbi and it has no fuel pressure till you turn the key to start it. it should run from 9-14 psi. the 220 model tbi is different than all of the others because of this. if you have it you can see two lines for fuel one is bigger than the other, 3/8, and the other is 5/16, the big is the main and the 5/16 is the return line.
post #6 of 11 Old 01-05-2009, 05:56 PM
and yea if you get 5 when it runs( if it does) then what 34blazer said, fuel pump and regulator. and i know that it sounds funny but have you checked your fuel filter, it can get cloged if you get gunk in your tank and you run it on E. that gunk can get in your lines and clog it.
post #7 of 11 Old 01-06-2009, 11:11 AM Thread Starter
Yeah, i have replaced the fuel filter, and both of my injectors have been swapped out with a combination of four other used ones, all ending up with the same result. It seems as though they are spitting way to much fuel when running (as if they were leaking), but i wouldnt think that out of 6 injectors they would all be bad. I will try the regulator first then pump and let know. Im not sure of the TB model # but it is on an '86 S10 2wd 2.8 litre.
post #8 of 11 Old 01-06-2009, 12:13 PM
4x4 v6 blazer
neo71665's Avatar
User is: neo71665 is offline
Sounds like a bad reg. Its allowing the fuel pump to push too much past and flooding the engine.
87 blazer tahoe 2 door, 5.7, auto, sfa 4x4
91 noma reg cab, 3.4, 5speed, lowered
President of the Arkansas chapter Anti-bag Coalition
"Bags are for groceries"
Originally Posted by alarm_the_alarm View Post
Lift That Sh*t, Fat Girls Can't Jump
i just made love to your bowels......and then reported them.
neo71665 is offline
post #9 of 11 Old 01-06-2009, 04:40 PM Thread Starter
Thats what i was thinking too. I had a spare regulator and slapped it on last week, it immediately fired up and ran great. After I ran it for awhile and fired it back up though it was stumbling again.. I have one more that im gonna try in there to see what happens. The only regulator is the one on top of the TB right?
post #10 of 11 Old 01-06-2009, 05:21 PM Thread Starter
....Although i have tried pinching off the return line to see how it runs. Doesnt this act as eliminating the regulator?
post #11 of 11 Old 01-06-2009, 05:36 PM
34blazer's Avatar
if you pinch the line you are restricting the flow of fuel, the pressure will spike. also called dead heading the fuel pump.
USAF
34blazer is offline
