1985 2.8 knocking
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 09-22-2009, 12:26 AM   #1
under construction
sdimewisher's Avatar
1985 2.8 knocking
ok..I just scored a 1985 4wd blazer for 200 bux..only catch is that there is a small rod knock.
my question is:
can I pull the oil pan off with the engine still in the truck?
If not, what do I need to do in order to pull the pan off?
Im planning on pulling the pan, and putting in new rod bearings to see if its just a bad bearing...if not, im swapping engines....
I was also told that 1985 was notorious for cracking cranks.....any truth??
I can get a 89 camaro 2.8 to swap in for fairly cheap....what do I need to do to swap in the camaro engine. I know its mpi and my truck is carb'd. can I just swap intakes, and oil pans/pumps?
I just sold my 93 with the 4.3, so the 2.8 is a whole new ballgame for me
Old 09-22-2009, 12:46 AM   #2
4x4 v6 blazer
neo71665's Avatar
Re: 1985 2.8 knocking
Gonna have to pull the engine unless you figure out something I aint.
Anything 85 and before had smaller mains and its said they are bad about cracking cranks.
To put the 89 f-body engine in all you do is use your intake and oil pan/pump.
Old 09-22-2009, 07:42 PM   #3
blown up .....again
Shaggem's Avatar
neo is right on pulling the engine out. 85 2.8's had lots of problems with cranks due to the main journal size and some balancing issues. if your truck has a mechanical pump which I think but not sure 85 model did and the 89 camaro block has that portion of the block blocked off. you will need an inline electric fuel pump and dont ever reuse an used oil pump. buy a new one for the year of the vehicle you are swapping into. you will need to strip the donor engine down to the long block and use the 85's valve covers, intake/carb, exhaust, sensors, 87 or later s10 flywheel and balance, pulleys, accessories, front timing cover, oil pan and like I said before purcahse a NEW oil pump pick up tube(your has shavings in it) for the 85 engine. the oil pumps are the same and you will also need the distributor off the 85 as well. I have a 87 camaro 2.8 in my 89 truck.
Old 09-22-2009, 10:52 PM   #4
under construction
could I thoereticly purchase a 86 2.8, and drop it in? would the 86 not have the crank issues, AND bolt right in?
Old 09-22-2009, 11:12 PM   #5
4x4 v6 blazer
neo71665's Avatar
82-85 used a v-belt set up, the front cover, and accessory drives, oil pan
86 (maybe some late 85s) had a combo v-belt and serpentine belt, front cover very specific, oil pan
87-93 had all serpentine belt dive, front cover, oil pan
I forgot about the oil pan being year/front cover specific. You can still use the 89 motor you just have to use front cover, oil pan, intake, and exhaust manifolds off your truck on it. I'm trying to remember but I'm almost sure the 85 had a mechanical fuel pump and you'll have to change to an electric one is you use any block 86+ (the improved blocks). Swapping everything over really aint that hard and gives you a good excuse to change the timing chain.
Old 09-23-2009, 01:49 PM   #6
blown up .....again
Shaggem's Avatar
do yourself a favor and soak the exhaust bolts with some penetrating oil for a few hours then spray them down again, start the truck and let it run til the exhaust is hot then shut off and the bolts should, not always, but should come out easier. or you can just use a torch to heat them up.
Old 09-27-2009, 11:59 PM   #7
under construction
well....I replaced the rod bearings, put fresh oil in her, and fired her up...the knock is quieter, no knock at idle, but driving, there is still a slap, slap, slap...quiet, but still there...
Old 10-20-2009, 10:47 PM   #8
How's your timing on it? You got a timing light?
Old 10-21-2009, 02:47 AM   #9
under construction
havent checked the timing...engine is coming out, aand gettin rebuilt...ho hum.......
Old 10-21-2009, 11:32 AM   #10
hehehe, understood... it's a non-issue at this point then. Good luck with the rebuild!
