1984 S10 Blazer w/ 3.4l engine Won't Start! - S-10 Forum
post #1 of 9 Old 12-10-2008, 04:41 PM Thread Starter
User is: onecrazyfoo4u is offline
New to the forum hi all! Just bought this 84 about 2 months ago. It's all original, no engine modifications, stock 2BL carb, electronic fuel pump, etc. It's been running great all along until this morning it wouldn't start up. It caught for a second, and chugged for about 5 seconds (sounded like it was running only a couple cylinders) then died and won't start at all now.
The last owner told me he had a shop do a 1998 3.4l engine swap. This sounds like a really common swap, and you can't even tell the difference by looking at the engine from what I've seen. I'm trying to find some specifications on this engine. I have reciepts for it, but it doesn't tell me what car the engine was out of. Anybody have a link to general specifications for the 3.4l motor, like spark plugs, ignition, timing, etc.?
I'm just trying to troubleshoot and it's hard without specs for the 3.4l. Main thing I need, is what spark plugs are used for this engine (heat range + gap)? What's the timing supposed to be set at? And what are the fluid capacities? I can't think of any other reason why it wouldn't start, anybody? Thanks for the help!
post #2 of 9 Old 12-10-2008, 08:02 PM Thread Starter
Re: 1984 S10 Blazer w/ 3.4l engine Won't Start!
Well, I pulled the plugs, and they all smell like gas really bad. So, I'm guessing this means that the carb is flooding? How do I fix it? I'm not too knowledgable on carbuerators....always had fuel injected vehicles. Should I just let it sit for awhile and then try starting again? It just turns and turns, doesn't catch or even try to chug at all.
What spark plugs does this 3.4l engine take? Thanks.
post #3 of 9 Old 12-10-2008, 10:29 PM
YAY for Primer!
ShortyzKustomz's Avatar
User is: ShortyzKustomz is offline
Must be a crate motor if its a 98, Cause 98 Camaros had the the 3.8
-1994 Toyota Bagged, Suicides, 3.8 T5 Swap in the Works
-2006 Silverado 5/8 Drop on KMC 20s
-1992 S10 Longbed 4.3 3/4 drop (Beater)
post #4 of 9 Old 12-11-2008, 04:12 PM Thread Starter
I don't think it's a crate, looks too old. Is there a way to check the year or model of the eninge, is it stamped anywhere?
I bought new plugs and wires, just because it needed it....but I don''t know if I got the right spark plugs? Which ones should be used for a 3.4l carb''d engine? I doubt it will fix the start up problem though. Help please!
post #5 of 9 Old 12-11-2008, 09:40 PM
4x4 v6 blazer
neo71665's Avatar
User is: neo71665 is offline
Only years f bodies that had 3.4 were 93, 94, and 95.
87 blazer tahoe 2 door, 5.7, auto, sfa 4x4
91 noma reg cab, 3.4, 5speed, lowered
President of the Arkansas chapter Anti-bag Coalition
"Bags are for groceries"
Originally Posted by alarm_the_alarm View Post
Lift That Sh*t, Fat Girls Can't Jump
i just made love to your bowels......and then reported them.
neo71665 is offline
post #6 of 9 Old 12-12-2008, 02:02 AM Thread Starter
Cool, I think that's what it's out of. Where can I find the engine model number or vin number? I'm just having trouble finding the specs on this engine. Mainly, what spark plugs and gap should I be running? Any help is appreciated!
post #7 of 9 Old 12-13-2008, 12:22 AM
Wait, what?
Z28Camaro's Avatar
User is: Z28Camaro is offline
Have you checked for spark yet? Could be a coil possibly...
post #8 of 9 Old 12-17-2008, 12:22 PM Thread Starter
I got her started up the other day after messing around with the carb. I think it was just a stuck choke plate on the stock 2BBL carb. Is the rear plate the choke plate then (the bigger one)? And the plate should open up only for start right, should go back closed after a few minutes of idle? Both plates were pretty loose, but they work good now. Thanks!
post #9 of 9 Old 12-17-2008, 12:58 PM
bat
User is: bat is offline
You will start to have choke problems. I tied mine open. It should be close to fully closed and open up while running and stay open until it's turned off and cools down. A faulty choke will not close when cool or close when hot. I don't know the correct fix. A complete rebuild may or may not fix it.
bat is offline
