Where does this vacuum line go? - S-10 Forum
post #1 of 13 Old 08-01-2011, 12:00 AM Thread Starter
slick203's Avatar
User is: slick203 is offline
Trying to find whhat component (s) this vacuum tee feeds into? One side is currently tee'd into the throttle body... the other remains a mystery
slick203 is offline
post #2 of 13 Old 08-01-2011, 12:19 AM
always something new
S10dude's Avatar
User is: S10dude is online now
Re: Where does this vacuum line go?
...............to the vaccuum accumulator located in drivers fender just behind ABS unit . good luck finding it and re-attaching it
All truck pics
post #3 of 13 Old 08-01-2011, 12:23 AM
User is: dan33klein is offline
Is that accumulator required? Or can you just plug the line?
post #4 of 13 Old 08-01-2011, 12:45 AM
metalhdmatt's Avatar
User is: metalhdmatt is offline
yeah... id like to know this Q: as well.. lol, i looked for ****ing days for this, had no idea there was something in the fender so i just plugged it... lol what does it do and does it need to be put back in???
post #5 of 13 Old 08-01-2011, 01:08 PM
Pony's got a nice rear
ratrace2's Avatar
User is: ratrace2 is offline
S10DUDE is correct.
The vacum acumulator allows the cooling vents--vacum activated--to work properly by supply a reserve supply of vacuum when the engine has a "low" vacum state.
Older S10 vacuum reserves were like a "ball" and hung from the underside of the hood.
TO RE-ATTACH:
It's realy simple, the vacum accumulator is bolted to the drivers side (left) fender just behind the ABS--like S10DUDE said--and, it is bolted flush with the fender on the inside. SO, just feel around for the "nipple"
and push the vacum hose back on......
Damn. That is Loud !!
ratrace2 is offline
post #6 of 13 Old 08-01-2011, 02:06 PM
iLongboard
insaneredrooster's Avatar
User is: insaneredrooster is offline
Mine is very exposed
The collision center just left it there after they repaired my fender.
Just thought I'd throw in a pic of what it looks like...
INSANEREDROOSTER
post #7 of 13 Old 08-01-2011, 07:18 PM
Does plugging the line hurt the engine any performance wise
post #8 of 13 Old 08-02-2011, 04:20 PM
BEAVER50's Avatar
User is: BEAVER50 is offline
I plugged mine a couple months back.It didnt hurt a thing.It helped my A/C controls.Like was said it for the controls.the older ones had the ball.Go ahead and and plug it wont hurt nothing.
BEAVER!!!
BEAVER50 is offline
post #9 of 13 Old 08-03-2011, 01:09 AM
Tech Mod
beandip's Avatar
User is: beandip is offline
Dont plug it up, just connect it.
-Jonathan
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #10 of 13 Old 08-05-2011, 09:08 PM
Registered Un-dependent
Mechnix's Avatar
User is: Mechnix is offline
If it didn't do something worthwhile why would they put it on there?
Mine became disconnected and my air controls wouldn't work, I was happy to just put it back!
Mechnix is offline
post #11 of 13 Old 10-03-2011, 03:45 PM
User is: motobruce is offline
I bought my 99 s10 5 days ago and it has a few problems so while nosing around i found that where this pipe connects to the throttle body it had broken so i have replaced the whole pipe and the two from the T valve.
I now know the connector on the inner wing is for the vacum accumulator but what does the other pipe that goes in to cab with the wiring loom do?
Thanks, Dan.
post #12 of 13 Old 10-03-2011, 04:06 PM
User is: nstoolman1 is offline
Thanks, Dan.
It is the supply line for the Heating/cooling system inside of the cab.
post #13 of 13 Old 10-03-2011, 06:06 PM
Thank you, Will get my Aircon regassed and see how it works now ive repaired the vacuum pipe..
