what trans does a 98 s10 2.2 automatic have? - S-10 Forum
post #1 of 17 Old 01-20-2009, 07:29 PM Thread Starter
User is: JR0CK is offline
hi, i'm trying to buy a new tranny for my truck. it 98 s10 with automatic trans. do any of you guys what tranny s10 come with?
JR0CK is offline
post #2 of 17 Old 01-20-2009, 07:31 PM
Works too much!
laydout97's Avatar
User is: laydout97 is offline
Re: what trans does a 98 s10 2.2 automatic have?
4l60e
92 4.3/700r4 315k- ole red
2011 altima- daily ride
post #3 of 17 Old 01-20-2009, 07:52 PM
'Stevie Joe'
HighrollerII's Avatar
User is: HighrollerII is offline
Send a message via AIM to HighrollerII
yea but good luck finding one...i need one too
Steve
SCR8PFEST 13
^ ^ INFO ^ ^
Best show on the east coast!
Bagless again
post #4 of 17 Old 01-20-2009, 08:47 PM
Electrical Mod
deathphoenix99's Avatar
I find them everywhere, there was a truck in Indy this weekend that had the 2.2 and auto. It was either a 98 or 99.
Question: Will the 4l60E that's in the 2.2 bolt up to other engines with the same engine and vice versa?
post #5 of 17 Old 01-20-2009, 09:18 PM
2001 S-Dime
01LilRed's Avatar
User is: 01LilRed is offline
Send a message via AIM to 01LilRed
yes the 4l60e is the same tranny tht came in auto camaros/firebirds....its also thje same in the 4.3 trucks it will both up to a v8
01LilRed is offline
post #6 of 17 Old 01-20-2009, 09:22 PM
Works too much!
laydout97's Avatar
no, your wrong to a point. The 2.2 4l60e is different from the 4.3 4l60e. Hold please so I can find out the exact differences
post #7 of 17 Old 01-20-2009, 09:28 PM
User is: poconojoe is offline
They're not even close to the same trannies. They share some internal parts, but they far from interchange. Even the convertors are differant on the 2.2's
I should have one in late April, early May with around 60K on it, when I scrap my daily beater, because of rust
post #8 of 17 Old 01-20-2009, 09:28 PM
stockchevy1983's Avatar
User is: stockchevy1983 is offline
i gotta 4l60e in my 98 yukon. dont know differences though
Jeff
1994 K1500 - 5.7 tbi, magnaflow y pipe, spintech prostreet, leveled on 265/75/16 tw wardens
post #9 of 17 Old 01-20-2009, 09:30 PM
It would be easier to list the things that are the same. Lets see, OH yea, the name
post #10 of 17 Old 01-20-2009, 09:31 PM
Works too much!
laydout97's Avatar
be paitent old fart...
the 2.2 and the 4.3 are not interchangeable due to the fact the input shaft on the 2.2 is shorter by hald an inch, and has a different hub spline pattern in the torque convertor, and many differences in the physical characteristics of the 2,2 convertor , the internals besides that are similar, but there are servo and very subtle calibration differences in the valve body.
the 2.2 used a code 554 servo whereas the 4.3 uses a 553 servo
the 2.2 valve body is also calibrated with a b or c coded 1-2 accumulator
whereas the 4.3 can have anything from a b code (the zr2 trucks) to the d code (the 4 door sonoma 2wd with 3.42 gears) there are also different lock up valve spring calibrations beween the 2, and the 4.3 generally has a bigger EPC feed hole in the pressure regulator valve.
you can not swap these 2 as complete units, and i would not reccommend cross swapping parts between the 2, as you can cause a bunch of mismatched parts problems. i usually preach its best to fix what you have unless you have a direct replacement, and this is where i stand again
post #11 of 17 Old 01-20-2009, 10:11 PM
User is: Stevo92z28 is offline
Right so about the only thing the same is the name like poconojoe said...
1998 Pewter S10 ExtCab 2.2/Auto DD
2/3 Drop, 17" Edelbrock 454s, GM Rollpan
post #12 of 17 Old 01-20-2009, 10:17 PM
Works too much!
laydout97's Avatar
Basically
post #13 of 17 Old 01-20-2009, 10:19 PM Thread Starter
thank you guys for the info.
JR0CK is offline
post #14 of 17 Old 01-21-2009, 12:52 AM
Electrical Mod
I figured they were different...just like the Borgwarner T5's that came in my truck versus the mustangs and a ton of other vehicles. Thanks laydout for the info.
post #15 of 17 Old 09-19-2012, 01:46 AM
prymdym's Avatar
User is: prymdym is offline
Aside from 4l60e, is there a specific code to search for when on the hunt to mate one to a 2.2 specifically? We just bagged my girlfriends 2001 and she wants an auto but loves the driveability of the 2.2.
prymdym is offline
post #16 of 17 Old 09-19-2012, 01:12 PM
Electrical Mod
You'll have to find an auto from a 2.2 S10/Sonoma/Hombre. And you'll need the wiring/computer to get everything to work. It won't be an easy conversion, but it's possible. You'll want to verify what year 4L60E's will work because there are differences between the electronics throughout the s10 history.
post #17 of 17 Old 09-21-2012, 03:13 AM
prymdym's Avatar
Thanks so much!
prymdym is offline
