what the hell is wrong with my engine
Old 07-02-2008, 07:28 PM   #1
chrisisdashiznt's Avatar
chrisisdashiznt can only hope to improve
when i put it in first it takes off and idles normal but when i gas it it sputters and jerks like somethin is about to blow up i don't know what is wrong any input would be helpful
Old 07-02-2008, 07:32 PM   #2
Minitrucker
CrEaPeR's Avatar
CrEaPeR is on a distinguished road
Re: what the hell is wrong with my engine
check your spark plugs. what kind do you have in there?
Old 07-02-2008, 08:21 PM   #3
IBSpoolin's Avatar
IBSpoolin is on a distinguished road
I am having somewhat the same problem with my truck. Its almost like under a certain load and certain rpm it will not fire for a split second. I am leaning toward a ICM. I have no codes and watched everything with a Snap On scanner and nothing shows up.
Old 07-02-2008, 08:30 PM   #4
Minitrucker
CrEaPeR's Avatar
if you have anything other than Delco plugs in i would change them out to Delco's. I put some Boshe plugs in mine and they lasted about 2000 miles before they fouled up and started to make my engine hesitate under load.
Old 07-03-2008, 12:36 AM   #5
i just put new ones in about 200- 300 miles ago and it acts like it is misfiring i wanted to get the bosch with the 4 prongs on them but i guess i'll get delco's i just put splitfire plugs in their tho and i can't see through my cat and their were semicircle metal rings when i took it off to look at it
Old 07-03-2008, 11:30 AM   #6
Minitrucker
CrEaPeR's Avatar
only thing i can think of is it is either your plugs, wires and/or coils. i would start out by replacing the plugs with delco's and check your wires to make sure they are not damaged.
Old 07-03-2008, 11:49 AM   #7
ight thanks
Old 07-03-2008, 03:36 PM   #8
well now it is idling very rough backfiring all kinds of crap could the oil have anything to do with it and i added something called seafoam to my tank all my friends used it and their trucks ran 1000 times better could it be the seafoam or something else
Old 07-03-2008, 03:41 PM   #9
and it smells funny
Old 07-03-2008, 07:25 PM   #10
whiteSdime03 is on a distinguished road
I'm having the same problem. SES light says #4 missfire, the plugs, wires, and coils are new changed about 4k miles ago.
Old 07-04-2008, 02:28 AM   #11
Mrpotatohead922's Avatar
Mrpotatohead922 is on a distinguished road
i would check you wires again, i had the same problem on a pair of new wires. it ended up grounding out on the engine causing it to misfire.
Old 07-04-2008, 06:49 PM   #12
Gallon of Fuel is on a distinguished road
I had a similar issue last summer, only on really hot days. my scenario was this: if it was 90+ outside, you'd have to accelerate with 20% throttle or less, otherwise it would basically bog down and not accelerate. I changed the coils and saw no improvement. i then popped the plugs out, which were less than a year old, inspected, and regapped them. some were tight, some were loose, but that fixed the problem. whether that was the actual problem or not, i dont know. in the process of taking it apart i may have fixed something else.
Old 07-05-2008, 04:35 AM   #13
AMnova is on a distinguished road
I gotta check my spark plugs then. I have the same similar problems and well i changed my plugs less than half a year ago...while i am at it ima change the wires..
Old 07-05-2008, 04:42 AM   #14
It's gonna be fAIMous
colbye32's Avatar
colbye32 is on a distinguished road
My 98 s10 2.2 is doing the same thing, its got brand new plugs, wires, both coil packs, and a clean k&n drop in filter. NO codes what so ever.
When i take off from a stop sign or light it will bog down like a quick misfire, then will continue to run fine. mine seems to only do it when i take off, or when i let it de accelerate for a few seconds and then hit it, it will misfire, or bog down. WTF is wrong with this thing??
Old 07-05-2008, 12:25 PM   #15
Mine will sputter at take off and #4 is dead at WOT until about 3500 rpm's then it comes back in every gear.I'm leaning torwards a fuel problem instead of ignition, any $.02?
Old 07-05-2008, 12:40 PM   #16
str8dman78 is on a distinguished road
I had the same problem with my blazer. It ended up being the spider to the fuel injectors. Try replacing that
Old 07-05-2008, 12:42 PM   #17
I've also had to replace the entire distributor to a brand new one and i stopped having the problem altogether.
Old 07-05-2008, 07:11 PM   #18
tu-tu guru
Chris0nllyn's Avatar
Chris0nllyn is on a distinguished road
this is the 2.2 section
Old 07-06-2008, 02:33 PM   #19
dunes_ny is on a distinguished road
I have the same problem. My 2.2 L has 85,000 miles and 9 years on it so I decided to change out the plugs (was running great before I tuned it up lol).
I installed AC Delco plugs but in the process I pulled the clip off the wire closest to the firewall. I carefully repaired the wire/clip and re-attached to the new plug.
The day after I replaced the plugs, the truck started sputtering and hesitating and generally has very poor get up and go at lower rpm's. Higher rpm's it seems to be ok. It sounds like it's running on 4 cylinders, but poorly.
So yesterday I replaced the coils. No difference.
Since I did such a nice job reapairing the wire I don't think that's the problem. I believe changing out the plugs changed the resistance in the circuit and it caused some other electrical component to fail. I could get new wires but that might be a waste of money.
Any thoughts? Thanks.
Old 07-06-2008, 05:10 PM   #20
Jonny_00's Avatar
Jonny_00 is on a distinguished road
for the most part bosche plugs are junk the platinum +4 will do nothing in a 2.2 except burn off the electrodes and fall into your cylinder i would avoid them stick with factory delcos they work the best for the engine
Old 07-06-2008, 06:49 PM   #21
s10bbagged is on a distinguished road
i think yhat you might have a clogged fuel filter and its not given enough under a load but will allow it to run while at idle
Old 07-06-2008, 08:08 PM   #22
Mine got replaced 2K miles ago.
Old 07-06-2008, 11:30 PM   #23
jeffery_843's Avatar
jeffery_843 is on a distinguished road
i have a 98, and had problems just like these and sometimes it would throw the #4 cylinder code. i changed the plugs, wires, coils, and fuel filter. no help. i ended up taking the fuel pump out. 98 and up is the one piece pump and sending unit so its very expensive. what i did was use a siphon pump to get the gas out the tank(had a little trash in it) i didn't feel like trying to drop the tank so i used a shop vac and sucked the tank clean. i carefully took the pump/sending unit half way apart. it is all inside a big plastic case with a strainer on the bottom. the bad thing is the strainer is not removable. if you take it out of that casing you can use a shop vac to get the strainer clean. also when you take it out the pump is still in another case with a strainer on it. that one is really hard to get clean. mine had a lot of stuff in it. i spent about an hour with the shop vac trying to get the trash sucked out. put it back together and haven't had another problem with it. that was probably 3000 miles ago.
Old 07-06-2008, 11:31 PM   #24
also if it is the pump there are some good threads on here about how to install an inline pump and leave your stock one in the tank and still use the sending unit on it so your gas gauge works. i think it only runs around $100
Old 07-07-2008, 02:19 AM   #25
Trackside Support Vehicle
S-10Driver's Avatar
S-10Driver is on a distinguished road
the stutter problem on my truck was caused by the vacuum line that runs from the throttle body to the vac canister in teh drivers fender. w/ only 84k on it the hose was all cracked and rotten.
how did you put the seafoam in the truck? if its in teh crankcase, you're only supposed to put it in for like 15 mins then change the oil. for upper cylinders you supposed to pour it into a vac source on the throttle body. and then teh rest goes into the gas tank. use a 1/3 of the can for each...but i've never done the oil. if you pour seafoam into the vac source, you're suppose to do it while its running. and it will smell horrible and probably smoke really badly for that day.
Old 07-07-2008, 09:02 PM   #26
I just checked the same vaccuum hose and yes mine also was cracked and rotten also. I taped it and it still misfired a little, so I won't know if that's causing my ignition problems until I get a new hose, as I don't think the tape job can really hold vaccuum.
Old 07-09-2008, 01:03 PM   #27
id ended up being the sparkplug wires and i put the seafoam in my tank 1 oz per gallon 16 gallon tank 16oz bottle
Old 07-09-2008, 01:12 PM   #28
Useless posting member
Wrkn prgs's Avatar
Wrkn prgs is on a distinguished road
Mine would cut out under acceleration, then my fuel pump went out after a while. I replaced that and my sending unit, and all was well.. but then again, I went ahead and did plugs/wires, and fuel filter at the same time.
Old 07-09-2008, 04:07 PM   #29
I ended up being the sparkplug wires and i put the seafoam in my tank 1 oz per gallon 16 gallon tank 16oz bottle
So you just installed new wires and the problem was gone? Did the old wires look damaged?
I fixed my vaccuum hoses but I'm still getting the misfire after I shift gears and try to accelerate. It's much worse in the morning compared to when it's warmed up.
Did you have to take any parts off to get the wires installed? It looks a bit tight.
Old 07-09-2008, 05:15 PM   #30
S-10Driver's Avatar
http://www.s10forum.com/how_to_plugs_wires_on_a_98_2_2
it is pretty tight fit between the alt and motor...but they fit. lol
Old 07-09-2008, 08:10 PM   #31
Neighborhood IceKream Man
Dr.pRymer's Avatar
Dr.pRymer is an unknown quantity at this point
and it smells funny
could be a clogged catalyic converter
Page generated in 0.22561 seconds with 11 queries
