what is the truth about all these head gasket rumors? - S-10 Forum
post #1 of 87 Old 01-20-2008, 08:08 PM Thread Starter
User is: luke87gt is offline
First off, I am looking into purchasing a 98+ S10 5 speed.
Everyone I talk to seems to warn me about the headgaskets. Is there any truth to it? What is the source of the problem? These are low compression 9:1 motors right?
Can anyone give me any real evidence of this? It seems like even my friends who own these cars said things to me like, "its got 100K with no HG problems yet"
lol
Also, how much better are the MPGs for a 2.2 5 speed vs a 4.3 5 speed?
Thanks guys!
'93 Coupe 5.0
UCLA - Electrical Engineer
http://www.mustangmotorsport.com
luke87gt is offline
post #2 of 87 Old 01-20-2008, 08:47 PM
2.2sleeper's Avatar
User is: 2.2sleeper is offline
Send a message via AIM to 2.2sleeper
Re: what is the truth about all these head gasket rumors?
the 2.2 and the 4.3 are notorious for headgasket to go.
2011 Chevrolet Colorado 3lt. V8 2wd ZQ8
post #3 of 87 Old 01-20-2008, 08:53 PM
Eight433's Avatar
User is: Eight433 is offline
my 97's HG was replaced under warranty at under 30k
-2011 Silverado Regular Cab Short Box 5.3 6 speed auto 4wd
-67 Cadillac Deville on air
-2000 RoadStar Silverado 1600
Eight433 is offline
post #4 of 87 Old 01-20-2008, 09:27 PM
Bored as hell
Petterle's Avatar
User is: Petterle is offline
Send a message via AIM to Petterle
i hear mixed things about head gaskets, mpg will be anywhere between 19-26 miles, dependant on how you drive of course
-Josh-
1993 Chevy 2500 350/4L80E 4.10s. New daily.
1988 Chevy 2500 350/700R4 4x4 SC/LB. RETIRED.
Petterle is offline
post #5 of 87 Old 01-20-2008, 09:29 PM
Banned
User is: SteveHH is offline
Send a message via AIM to SteveHH
I have heard so much shit I do not know what to believe...
Someone enlighten me.
SteveHH is offline
post #6 of 87 Old 01-20-2008, 09:29 PM
Smoke a little smoke
rwalker07's Avatar
User is: rwalker07 is offline
Send a message via AIM to rwalker07
Ryan
1994 S10 - Bagged, Shaved, 18" Panther Juice 5, 2 Tone Paint, 98+ Front End Swap, Chrome Bumper
1998 Audi A4 Quattro - Bone Stock, the Daily
My Myspace
post #7 of 87 Old 01-20-2008, 09:35 PM
I want you to drag or die
zqdime's Avatar
User is: zqdime is offline
I've got 199,800 miles on the original head gasket, and it still has great compression. Personally I think people must beat the living hell out of their trucks to make the head gasket pop at anything less then 125000 miles
1998 zq8 2.2 liter 5 speed. 225,000 miles and counting!
zqdime is offline
post #8 of 87 Old 01-20-2008, 09:41 PM
User is: SSBlazerV8 is offline
You have to change the coolant on a regular interval
post #9 of 87 Old 01-20-2008, 09:46 PM
Better post-em.
comics22's Avatar
User is: comics22 is offline
lol same 95 with stock headgasket at 140K miles later still runs like a champ
comics22 is offline
post #10 of 87 Old 01-20-2008, 10:51 PM
2005lm7's Avatar
User is: 2005lm7 is offline
I think dexcool had alot to do with most of the early failures. As posted earlier change your coolant regularly. Just because they say you can go 150k on the stuff dont make it so.
I have a question though. I wonder if someone makes a mls gasket for 2.2s like what lsx engines use.
2005lm7 is offline
post #11 of 87 Old 01-21-2008, 12:24 AM
Better post-em.
comics22's Avatar
i dunno what some ppl have with dexcool, its what was in it when i swapped it out at 100K with new dexcool and no problems in the last 40K miles
comics22 is offline
post #12 of 87 Old 01-21-2008, 07:40 AM
Forum Dictator
What?'s Avatar
User is: What? is offline
Yes, head gaskets are known HOWEVER,can be prevented with easy maintaince
replace water pump 60-80k
use 180* TStat, 15* cooler actually help prolong 2.2L top end life because stock tstat puts average of 200-220* without-with a/see in variety of condition. With 180*, it'll never see over 205* I have yet to hear blown gasket with 180*tstat and coolant cleaning/replacing every 80-100k. I got 134k on my 2.2L with 180* and several mods, half of its life was driven high rpm and other half just low rpm, took top end apart, everything was just fine and compressions are great. had several minitruckers here in az that had blown gasket with stock tstat, switched over 180* after top end rebuild, NO problem and healthy
180*stat or lower is NOT a mod, it just works at certain temp for cooling temp preference, 160* too cold for stock-modded and 180* is best overall, however with in cold winter, can put 195* in since it wouldnt go over 200* unless you heavy footing
as for dexcool,there are several variable that can mess up, I see no problem with it as long you use dexcool and dexcool cleaning procedure and it'll be allright, its either all dexcool or all prestone, simple, if its not working well, stop and take it chevy and fork out the extra cost to fix your error and no worries for enxt 80-100k
if its $ a problem, just buy walmart dexcool and shits with it, take it 2 chevy and tell them just do this and that way you pay for labor and not ridiclous part cost
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #13 of 87 Old 01-21-2008, 09:31 AM
boosted 2.2L
cs xtreme's Avatar
User is: cs xtreme is offline
Send a message via AIM to cs xtreme
let me put it this way, my truck has seen 14psi of boost and 10-11 regularly and had no failures.
not sure how long it would of lasted because I decided to build the motor this winter
post #14 of 87 Old 01-21-2008, 12:36 PM
User is: ivybandit is offline
If the 2.2 head gaskets didn't leak, how did all the stories get started. I had a 2.2 leak at 80K.
post #15 of 87 Old 01-21-2008, 01:21 PM
boosted 2.2L
cs xtreme's Avatar
i've seen in on the older engines but not soo much on the 98+
there were a few bad apples but its definately not a an all are going to leak thing
post #16 of 87 Old 01-21-2008, 03:12 PM
Forum Dictator
What?'s Avatar
that's right. Gm had 2.2L head design changed including improved for cooling or less head gasket blown for the 98+, just like cs xtreme said, few bad apples
What? is offline
post #17 of 87 Old 01-21-2008, 08:22 PM
User is: fishindabay is offline
Send a message via AIM to fishindabay
similar to the old quad-four engines, (2.4 liter dohc), it all depends on how the vehicle is driven. aluminum heads and iron blocks expand at different rates. trucks/cars that take short trips do not allow sufficient warming of the engine, while long trips get everything warm and expanded, and everything works out.
this is a theory a teacher had when i was in GM ASEP training. it makes sense to me, most of the premature headgasket failures we saw on these in the dealer are little
old ladies who drive 2 miles a day. the long trip/highway drivers maintain original head gaskets up to and past 200k miles
post #18 of 87 Old 01-21-2008, 08:40 PM
goin broke but n style
S15vortecpwr's Avatar
I have 180k on mine know and it is all original. timing chain and head gskt. It even had the orig valve cover gskt until 170k. It all depends on the truck. these engine were massed produced, so some probably had excessive clearance on the gskt surface. I also work in a shop that services Nissan. The nissan tech just did an 07 Altima 4 cyl head gskt and it only had 7500 miles. I diag one last week that blew at 100k. It is all in luck in what you get.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #19 of 87 Old 01-21-2008, 08:56 PM
User is: LXtasy is offline
120k+ on the 96 2.2 and same headgasket. But had to replace water pump at 115k though. But I do not run the gm antifreeze. Regular antifreeze myself. I beat on it. But not as hard as a "race car". Remember 2.2 and merging with traffic. lol
Daily Driver -2004 Ecsb Silverado
Wifes Ride - 07 Yukon Denali
Taking up garage space- 1998 4door blazer
2001 Blazer Fun track toy
1997 s-10 lq4 nitrous motor project
LXtasy is offline
post #20 of 87 Old 01-21-2008, 10:28 PM
User is: sdimedragginbody is offline
on my 95 it seeped out the back of the head... i never knew it untill i bodydropped it.... never showed any signes of anything
post #21 of 87 Old 01-22-2008, 12:31 AM
Better post-em.
comics22's Avatar
mines had dexcool all its life and still origional waterpump, i did replace my valve cover gasket at 120 K, didnt really NEED need it but it was either fix it while it was letting a little oil seep out now or have it blow out later
right now my current issue is a leaky PS pump, its leaking out the shaft (not very much at all but since its out of the shaft is sprays everywhere!!!) so add a tiny ammount liek every few months, lust loks like crap from all the spray
comics22 is offline
post #22 of 87 Old 01-22-2008, 02:11 AM
swtlownoma's Avatar
User is: swtlownoma is offline
Send a message via AIM to swtlownoma
i just did a head gasket rebuild on a rebuilt 2.2l and the engine prolly has less then 30k on it, but it was a mechanical thing also, the thermastat i found out was 3/4 gone, and my tstat sensor was the wrong temp. for my truck so my gauge wasnt even reading any temp change.
how bout this solution, just take care of ur truck and it will take care of you, do the necisary changes and all the manual says to do wen it says to do it, and you should be ok.
post #23 of 87 Old 01-22-2008, 09:59 AM
IBSpoolin's Avatar
User is: IBSpoolin is offline
Almost 90K on my 2.2 with Nitrous for awhile and now 30K miles of boost and much drag strip use. Still on the stock headgasket(knock on wood). Now, there was stuff done like cooler thermostat, griffin radiator, efans, changing the antifreeze. Just do the preventive stuff and you should be fine.
98 ZQ8 2.2 Underdrive Pulleys, E-Fan, Magnaflow converter, Hooker Aerochamber muffler, 59 MM TB, Lowered 2" and 3", T3/T4 8psi Rocking hard!
Build it don't buy it...Anyone can buy warranty then they are just another brick in the wall....
post #24 of 87 Old 01-22-2008, 12:33 PM
My HG leak was on a 94 2.2, my 99 has not leaked yet, only 53K.
post #25 of 87 Old 01-22-2008, 04:05 PM
Forum Dictator
What?'s Avatar
Actually Fishindabay, your GM ASEP teacher is about right
We all know gotta go easy on vehicle when you have it built/rebuild so it'll break in properly
Whenever vehicle is brought out to dealership, the detailers/lot attendant will have to drive them to park/detail/etch sticker, etc. This is pretty common, A/C on maxium and floor it all over to their location, this continues until vehicle is sold, this easily puts the motor enough time and go over 210* from the start
this isn't always the cause, but the designs of how it was build, they could gone with larger radiator which auto store now have bigger radiator which is change of design and helps prevent blown HG
Id still highly recommend 180* for those who are pushing 200*-210* daily BUT its NOT problem solver
What? is offline
post #26 of 87 Old 01-25-2008, 11:26 AM
Powder Coat Specialist
xtrememeasures10's Avatar
User is: xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
I just did my head gasket eariler this month w/ around 160,000. Honestly the gasket doesnt have a crack anywhere. The head bolts just backed out enough for it to start leaking coolant out the side of the motor. But the fact that i changed the head gasket doesnt matter anymore. Put it all back together and found out i have a cracked head above the number 3 spark plug. Never overheated the motor or ran it dry on any fluid.
97' w/ 03' Front end, Too many mods to list....
2.2L Build and Powder Coat Project
http://www.s10forum.com/forum/f105/2...ernals-486082/
Check out my Business Powder Coating work.
http://www.facebook.com/makpowdercoating
post #27 of 87 Old 01-25-2008, 10:54 PM
has no indigoblue2kdime.
indigoblue2kdime's Avatar
User is: indigoblue2kdime is offline
30k boosted! that's awesome man!
had a blue truck, now i have a red one.
post #28 of 87 Old 01-29-2008, 02:20 AM
S-series abuser
User is: minitrucker83 is offline
Getting ready to tackle this task in the next few weeks. Mine has been seeping coolant down the back of the engine/side of the bellhousing for a few months. Never really went through alot of coolant but now its started to get worse. 188k miles and im pretty sure its never been apart besides for the timing chain.
post #29 of 87 Old 01-29-2008, 04:18 AM
Too damn old for this sh*
Pharacyde's Avatar
User is: Pharacyde is offline
Send a message via AIM to Pharacyde Send a message via MSN to Pharacyde Send a message via Yahoo to Pharacyde
98 2.2
198k
no change yet...
post #30 of 87 Old 01-29-2008, 01:20 PM
Diesel Tech
richarddhoward's Avatar
User is: richarddhoward is offline
Send a message via MSN to richarddhoward
99 2.2l 5 speed that I rod the ever loving piss out of, intake exhaust, with exhaust leak, done all the maintenance and then some and its still going strong at 95,000. That's not saying much for miles but the truck hauls stuff every weekend and regularly sees 1500 miles a month. I've heard the same rumor over and over but I haven't seen anything with it. We did have 2 Pontiac Sunfires (think Pontiac Cavalier) and those I know have had problems but they don't cool as efficiently as out trucks do. We blew one on our 99 Sunfire after I took it out for a shall we say test drive and I was playing with a mustang. Ate it alive. Anyway just keep the maintenance up and watch your temp and that and it should be fine. I'm headed for Montana in August and I'm putting a new head on my truck, the I believe Patriot? head for some better performance in the mountains over there and changing the gears so I'll see what happens. I'm also switching in e-fans instead of the clutched fan thats on it.
1999 GMC Sonoma SLS - 2.2l 5 speed 2wd, LIFTED! 31x10.50/15's Wild Country XTX Sport Radials, on Baja -8 Style wheels, Doestch 3 inch lift spindles, Crown Suspension 2" lift shackles, Hella 500's
Build Thread: http://www.s10forum.com/forum/f30/pr...-to-it-494071/
OutCast Racing
post #31 of 87 Old 01-29-2008, 08:46 PM
Ginger army
nvious's Avatar
User is: nvious is offline
Send a message via AIM to nvious
have a 96 with 171K and Im about to replace the HG.
nvious is offline
post #32 of 87 Old 01-31-2008, 02:26 PM
User is: mrivera989 is offline
I have a 01 with 93k and the head gasket just went out!
post #33 of 87 Old 01-31-2008, 02:44 PM
viperstd's Avatar
User is: viperstd is offline
99 with 165k on the original... and I rev it to the limiter and bounce the limiter when driving down the highway (Im not speeding THAT much, I have smaller tires and the limit is higher here) How could it hold up better than that? I beat the piss out of my engine. I tow too... I love my little tutu.
1999 S-10 Ext.Cab | 167k Miles | 2.2L | 5 spd | 4.10s
viperstd is offline
post #34 of 87 Old 02-02-2008, 08:57 PM
User is: TrailTamer is offline
i had my HG blew at 115k, letting lot of coolant into the #4 cylinder and left it in the garage for a month or so and then finally open it up and that #4 cylinder's full of rust! has to scrap lot of the rust off and clean up lot, but in last it ran really great again, no bad idle and now on, im gonna to run the "green" coolant, not the damn dexcoolant
post #35 of 87 Old 02-04-2008, 11:17 PM
IBSpoolin's Avatar
On the note of dexcool, mine has the green stuff in it and has for awhile. I have just pulled too many cars out the woods that have sit there for 30 years and the stuff still working to believe in dexcool that tends to turn to jelly when not maintained excessively.
post #36 of 87 Old 02-04-2008, 11:38 PM
I'm a huge ass
4.3Xtreme's Avatar
User is: 4.3Xtreme is offline
I've never once heard anything about these engines having problems with head gaskets.
-Ryan -My Space-
Need a muffler? Get a SpinTech
Ditched the kit to get it closer to the ground...
Originally Posted by Chilloutski
...and you wouldn't know funny if it gave you a blumpkin in an outhouse.
post #37 of 87 Old 02-05-2008, 11:24 PM
Works too much!
laydout97's Avatar
User is: laydout97 is offline
97 s10 with a 2.2 124k orignal miles and no problems. 92 s10 with a 4.3 with 226,504 original miles, still running strong. Both trucks have had regular maintence.
post #38 of 87 Old 02-26-2008, 10:26 PM
Useless posting member
Wrkn prgs's Avatar
User is: Wrkn prgs is offline
Send a message via AIM to Wrkn prgs Send a message via MSN to Wrkn prgs Send a message via Yahoo to Wrkn prgs
What's a reasonable price for a shop to charge me to replace the head gasket on my '95 2.2? It also has A/C.
post #39 of 87 Old 02-26-2008, 11:42 PM
S-series abuser
At my shop it pays 7.2 hours x $75/perhour= $540 for labor only on a 95 w/ac. Add in the headgasket set, head bolts, cyl head resurfacing/check for cracks, I would probably tell a customer $750-$800ish total if they wanted an estimate.
post #40 of 87 Old 02-27-2008, 01:15 PM
Wrkn prgs's Avatar
Man, that's awesome since my truck is blue booked at maybe a grand.
post #41 of 87 Old 02-28-2008, 08:45 PM
Forum Dictator
What?'s Avatar
meh for the cost, might as well buy a reman motor w core change and 2yr/50k warranty or pay couple hundreds more for them to install it with 5 yr/100k warranty(based on az shop cost)
What? is offline
post #42 of 87 Old 02-28-2008, 10:44 PM
Wrkn prgs's Avatar
I'll probably change it out myself with a lot of help from a friend.
post #43 of 87 Old 02-29-2008, 12:14 AM
4 Bangin'
User is: Curtis2k is offline
I bought my 99, head gasket was leaking bad, but the gasket itself was good when I replaced it, the bolts on the head were actually just loose. This happened as a result of them cracking the radiator and driving the truck until it overheated.
Curtis2k is offline
post #44 of 87 Old 02-29-2008, 12:11 PM
Has to be a miracle, no cracked head.
post #45 of 87 Old 02-29-2008, 01:49 PM
4 Bangin'
I really was quite suprised the heads were in good shape, I have a parts truck with half as many miles on it so I wasn't too concerned though. Truck runs like a top, never seen the highway for more than 10 miles until I got it and I've put 7k since then. Up to 150k miles now
Curtis2k is offline
post #46 of 87 Old 03-02-2008, 08:48 AM
User is: mmliljoker is offline
230k 100 miles a day never had a head gasket problem!
post #47 of 87 Old 03-02-2008, 09:54 PM
Project Piece By Piece
double dimes's Avatar
User is: double dimes is offline
I have 2 94 trucks and both have had blown head gaskets. As a matter of fact I am getting ready to fix one now, and I don't dog the hell out of the motor either.
post #48 of 87 Old 03-03-2008, 09:00 PM
2.2X-10's Avatar
User is: 2.2X-10 is offline
you just buy them blown up..lol
what else can I do?
Borrowed Ideas project
Originally Posted by scrapin_low
Rusitn aint got a lot of tools he has a lot of determination
2.2X-10 is offline
post #49 of 87 Old 04-05-2008, 06:26 PM
down to one truck..WTF?
xiffa2003's Avatar
User is: xiffa2003 is offline
Send a message via AIM to xiffa2003 Send a message via MSN to xiffa2003 Send a message via Yahoo to xiffa2003
I'm not knocking the 2.2!!! I actually am deeply in love with my 98 dime but the biotch is on the second engine. The first one spun a bearing and the second blew a head gasket. I'm getting it fixed as im typing. BTW I beat the shit out of my truck and between the two motors ive had the truck for five years. Its worth it.
Court
Jimmy noSTART but still my shit!
post #50 of 87 Old 04-05-2008, 06:36 PM
don
don's Avatar
User is: don is offline
on a good note you can change a head gasket on a 2.2 in a few hours so who cares if the blow.
--------1995 CHEVY S10 REG CAB 2.2 5speed--------
--------2005 suzuki sv650s -------
don is offline
