What is normal operating temp on the coolant temp guage - S-10 Forum
post #1 of 10 Old 05-25-2008, 05:27 PM Thread Starter
User is: skipster is offline
Hey guys,
I am wondering what you all refer to as normal operating temperature as referenced on the coolant temperature guage for 2001 S-10s. Mine was running two tick marks to the left of 210, now runs 210 straight up almost all the time. I have had the coolant flushed and a new radiator installed (previous one leaked). I am also hearling a squealing from the front on the vehicle that stops with increased RPM. Nothing is coming out of the water pump weep hole, but I wonder if this aquealign is the water pump bearing going south.
Any help you guys have would be greatly appreciated.
skipster is offline
post #2 of 10 Old 05-25-2008, 05:56 PM
Outlaws's Avatar
User is: Outlaws is offline
Re: What is normal operating temp on the coolant temp guage
If it doesn't go over half way, you should be fine, but it really shouldn't even be half way unless you are stuck in traffic on a really hot day, and it should drop down a bit when you start moving for more than a few moments.
Might wanna get a new thermostat and see if that fixes the problem.
Outlaws is offline
post #3 of 10 Old 05-26-2008, 01:48 PM
Currently Spoolin
702s10's Avatar
User is: 702s10 is offline
Send a message via AIM to 702s10
well it depends on the temperature outside and how you are driving it, i live in vegas and during a hot day ( i have a 180* thermostat ) it will run about about where you are saying yours used to run. depending on my driving it will go up to the 210 mark when it's 90 and above temp outside.
2000 s10 5 speed - 2003 2.2 bored .050,Mahle pistons,Eagle H-beam rods,Garrett GT3071R turbo .63 TiAL SS 3" Vband hotside,ported compressor housing 4" inlet,2.5" outlet,TiAL MVS WG,TiAL Q BOV,BEGI FMU,Siemens 80# injectors,Treadstone TR8 Intercooler,Vibrant filter,Full 3" exhaust,Aero Turbine muffler,Spec Stage3+ clutch,Hurst shifter,ASP pullies,FlexALite efan,Aeromotive A750 Fuel Pump
702s10 is offline
post #4 of 10 Old 05-26-2008, 03:01 PM
Better post-em.
comics22's Avatar
User is: comics22 is offline
well if its above or near 210 its bad for the s-10 engines i know...
mine floats maybe 190 ish.
yes that squeal could be your water pump or the serpentine belt could just be old...
what color is your coolant and is it full?
comics22 is offline
post #5 of 10 Old 05-26-2008, 03:10 PM
Outlaws's Avatar
If it is at 210 when it is only 90 outside you also have a problem. I am in Phoenix and I don't get half way unless I am at a stop light and it is 110 outside.
Your thermostat should open at the rated temp and cycle new water though. In order for the temp to read 210 you either have nothing but 210 coolant in the whole system (which at 90 outside means your radiator is not working) or your thermostat is not opening up at the proper temp and then closes at the improper temp if it never gets back to the rated temperature.
Outlaws is offline
post #6 of 10 Old 05-26-2008, 10:01 PM
Currently Spoolin
702s10's Avatar
Okay I over exaggerated a bit on that one. The only time I saw it get to 210 was when hit hit triple digits here about a week and a half ago. today it was in the mid 70s and the farthest it got was the tick after the quarter bold line.
702s10 is offline
post #7 of 10 Old 05-27-2008, 12:37 AM
Better post-em.
comics22's Avatar
replace your thermostat, sounds like its bad. if it was working that needle would go over that 1/4 tick line then the T stat should open and you will see ti drop well below it and then even back out around the line below the 1/4 tick
comics22 is offline
post #8 of 10 Old 05-27-2008, 01:36 PM
got me some 20s
rockyroad217's Avatar
User is: rockyroad217 is offline
yea mine ran at 210 for a year before i thought to myself it was kinda high...replaced the thermostat and it sits down where it should be now..which i guess is around 185 or so
-Ryan
1996 S10 2.2 5 speed, kinda low
http://www.waylayedinc.com
Posting Nothing- Please Wait
post #9 of 10 Old 05-27-2008, 08:22 PM
registered offender
derricklane72's Avatar
User is: derricklane72 is offline
mie always rides a couple of clicks above 1/4.
post #10 of 10 Old 05-27-2008, 09:39 PM
Currently Spoolin
702s10's Avatar
same
702s10 is offline
