Vin 5 head casting number
Old 09-28-2008, 06:44 PM   #1
lostsoul is on a distinguished road
Hi
does anyone know what the head casting number is for 2001 2.2 S10 with the vin number of 5...mine blew the head gasket to the point where compression gasses will blow coolant out the radiator if the cap is off, just like its overheating when cold...I want to get a rebuilt head and do the whole job in one day instead of sending the current head out to be redone
thanks any help is appreciated
Old 09-29-2008, 02:37 PM   #2
94 2.2, feel the power?
deathphoenix99 is on a distinguished road
Re: Vin 5 head casting number
I don't know what the Vin 5 casting number is, but you can look for the Vin 4 also because they have the same heads. The only difference between the 4 and the 5 is that 5 means flex fuel. but the heads are still the same.
Old 09-29-2008, 11:16 PM   #3
2000S10GA is on a distinguished road
You just need to get a head with the same casting number.The number is located under the valve cover around the valve springs.
Old 10-01-2008, 01:44 PM   #4
Xtreme Measures
xtrememeasures10's Avatar
xtrememeasures10 is on a distinguished road
As was said pull your valve cover and look at the casting number.
Anyone you order it from will tell you to do so. The Vin is not a 100% accurate method of determining what casting you have. As i learned when i ordered my head. The guy looked it up by my vin and it said one thing then he told me to verify it on the head and it turned out being the other head.
Old 10-01-2008, 05:17 PM   #5
tu-tu guru
Chris0nllyn's Avatar
Chris0nllyn is on a distinguished road
im pretty sure the casting number should be
24575507
Page generated in 0.10947 seconds with 11 queries
