Very Slow turning over? - S-10 Forum
post #1 of 19 Old 06-17-2010, 02:06 PM Thread Starter
Dropped'01's Avatar
User is: Dropped'01 is offline
I put a brand new starter in my 01 S10 and the battery is good. The only thing i haven't replaced yet are the battery cables. When i go to turn the truck on it turns over very slowly, Sometimes picks up speed and starts and sometime doesnt then starts clicking.
Could it be anything else other then battery cables? They are original and i got 99k on the truck now.
Thanks
'01 S10 2.2L 5 speed, 3"-4" drop, K&N FIPK, Flowmaster, 56mm TB, OBX header, STS Pulleys, Cavi Seats, envoy handles, 8k HID Headlights & Fog Lights, SS Mirrors & Gen III bumper cover, 18" 225's.
post #2 of 19 Old 06-17-2010, 05:13 PM Thread Starter
Dropped'01's Avatar
Re: Very Slow turning over?
Bump...Any help?
post #3 of 19 Old 06-17-2010, 05:29 PM
It's a 4. something
scriptedmind's Avatar
User is: scriptedmind is offline
My truck did that but I have no idea why. It was working fine, then started that crap. I jumped the truck off and it cranked fine and then I drove it and have been driving it daily and so far no more issues. Though I haven't let it sit for two days straight again.
If the battery is good and the starter is good then def check the cables and cable ends. Make sure it's getting a good connection.
97 S10 RCSB 4.8 V8, 4L60E swap. (Speed)
99 Blazer ZR2 4.3 auto. (Mud/Winter)
2000 Trailblazer edition, 2wd, graphite interior.
13 Ford Fusion Titanium (Wife's DD)
co-owner of S10s Unlimited Inc.
post #4 of 19 Old 06-17-2010, 06:45 PM
Pussy Wrangler
AK49BWL's Avatar
User is: AK49BWL is offline
First thought after reading is cable end corrosion, either at the battery or the starter.
Brandon
1999 4x4 4dr Blazer - Sold! But not forgotten.
Now the happy driver of a GMT400!
AK49BWL is offline
post #5 of 19 Old 06-17-2010, 08:23 PM Thread Starter
Dropped'01's Avatar
Cool i just wanted to make sure there wasnt some other component that was causing this.
I cleaned all the cable ends and there is also a box where the positive cable attaches underneath the battery box. I opened that up and there was alot of corrosion in there but after cleaning all that up now it starts like normal
Thanks
post #6 of 19 Old 07-04-2010, 02:31 PM Thread Starter
Dropped'01's Avatar
Ok well i thought i fixed the problem but its still doing this. It still seems to struggle when starting up.
The starter is brand new from autozone.
We put my battery in my dads silverado and his truck started up fine w/out any problems so i dont think its the battery (even though its 3yrs old)
I cleaned the connections also.
When the motor gets hot after i have been driving for awhile (especially w/ the hot weather lately) it will turn over really slow or turns over one revolution and then the starter will click.
When this happens ive hooked up the jumper cables and got it to start.
Any one have or had this problem?
post #7 of 19 Old 07-04-2010, 05:10 PM
300k's Avatar
User is: 300k is offline
Battery. If you can jump it and it starts fine your battery is toast.
1999 S10 2.2 Ex-cab 5-sp Turbo
Build Thread: http://www.s10forum.com/forum/f105/2...-build-621114/
1998 S10 2.2L Auto Turbo
Build Thread: http://www.s10forum.com/forum/f105/u...-build-402312/
2005 Yamaha R6 Raven edition
1965 MG-M resto-mod fully restored
2000 Honda S2000
300k is offline
post #8 of 19 Old 07-06-2010, 02:56 PM
User is: S10 Guru is offline
My truck was doing this until I realized that when I put my engine back in I forgot to replace the heat shield that was on the starter. Make sure yours is in tact.
S10 Guru is offline
post #9 of 19 Old 07-07-2010, 11:03 AM
NOT AN S10
tg900's Avatar
User is: tg900 is offline
Send a message via AIM to tg900
if it's easy enough...i'd say have the starter checked. I know most of the starters i've had to change were cranking really slow and eventually didn't crank at all. that's really odd though since it's brand new, but maybe you got one in a million bad starters
Originally Posted by hedgehog View Post
..... I know the truck better than my wife and have also found it to be more dependable than my wife.
ELTC NEPA
tg900 is offline
post #10 of 19 Old 07-07-2010, 07:09 PM
is a fungineer
ka_jd7and1's Avatar
User is: ka_jd7and1 is offline
Send a message via AIM to ka_jd7and1
When you say the starter is "brand new from Autozone", do you mean it's brand new, or new to the truck/you? If it's a remanufactured starter, have it checked out.
Vehicles may be subject to change......
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons BLOWN UP, looking for a motor (PM me)
1968 Chevy C10 longbed, currently undergoing a heart transplant- 3/5 drop, the new tow pig/cruiser/project
post #11 of 19 Old 07-07-2010, 08:32 PM Thread Starter
Dropped'01's Avatar
no i just bought the starter about a week ago and it was the brand new one not the re-manufactured one. The heat shield is in tact. Im thinking there must be more corrosion inside the battery cables so i think im going to try replacing the whole positive cable.
Possibly that i did get a bad starter from autozone even though it was brand new. Just not sure what else it could be besides the positive battery cable including cable that goes to the starter. It seems to be getting progressively worse.
post #12 of 19 Old 07-07-2010, 09:12 PM
4 wheels aren't as fun
serpentracer's Avatar
User is: serpentracer is offline
it's hard to really say since you have a autozone starter...yikes. so yes, it's more than likely it's just a pos starter. but getting another one from them isn't going to solve anything. buying a name brand starter might. I never buy autozone stuff.
at least get your battery load tested.
02 sonoma 4.3L auto
97 sonoma 2.2L manual
post #13 of 19 Old 07-07-2010, 09:29 PM Thread Starter
Dropped'01's Avatar
Already load tested my battery and it passed fine. I buy stuff all the time from autozone without any problems
post #14 of 19 Old 07-07-2010, 09:38 PM
I've never had anything from them that actually worked like the stock part did.
the alt never ever last more than a few years for me.
starters about the same. the one starter I put on my Z-28 wouldn't turn the motor over when the engine was hot.
bought a powermaster starter from advance autoparts and never had a problem since.
http://www.powermastermotorsports.com/starters.html
when you buy a china part, expect china reliability
02 sonoma 4.3L auto
post #15 of 19 Old 07-19-2010, 02:23 PM Thread Starter
Dropped'01's Avatar
Fixed it.
The positive cable including the cable that goes to the starter had corrosion in it. So i went to a napa and had them cut me some different length of battery cable, bought some ends, and made my own positive cable. I just copied the stock one because an AC delco replacement positive cable is around $85. I made mine for $30.
Also where the negative cable connects to the block had a lot of grease and oil all over the ends so i cleaned them up really well.
Now it starts like normal.
post #16 of 19 Old 07-21-2010, 02:54 PM
User is: juavos00 is offline
Originally Posted by Dropped'01 View Post
Fixed it.
Do you happen to have the GM part number for that cable? Thanks
My Truck: '95 S10 originally a 2.2L now has '95 4.3L "W" CPI Engine, '01 Manual Transmission, Centerforce Dual Friction clutch. Crane Cams 1.6 rockers, OBX stainless steel headers with true duals; flowmasters dumped at the axle. K&N FIPK intake. Electric fan(s). Auburn posi with 3.73 gears and Cal-Tracs for traction.
juavos00 is offline
post #17 of 19 Old 07-21-2010, 08:11 PM Thread Starter
Dropped'01's Avatar
This is it on ebay and its a little bit cheaper but its pretty easy if you want to make your own
http://cgi.ebay.com/ebaymotors/02-CHEVROLET-S10-PICKUP-Battery-Cable-ACDELCO-2FS722F1S-_W0QQcmdZViewItemQQhashZitem2c558dd420QQitemZ19041 3919264QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
You can also find it here
http://parts-catalog.acdelco.com/cat...log_search.php
post #18 of 19 Old 07-21-2010, 09:22 PM
thanks for that info, and with it I found it even cheaper..
http://www.amazon.com/ACDelco-2FS72-.../dp/B000C9KKTA
juavos00 is offline
post #19 of 19 Old 07-22-2010, 07:35 AM
User is: mrbrace is offline
I have done the big 3 on most of my vehicles with audio power and ground cables...used 0 gauge and made sure the ends were nice and wrapped, works perfect for me. Getting ready to do this on the sonoma though.
mrbrace is offline
