vacuum line info on 99 s10 - S-10 Forum
post #1 of 4 Old 09-21-2010, 07:17 PM Thread Starter
A CLEANMACHINE's Avatar
User is: A CLEANMACHINE is offline
Send a message via Yahoo to A CLEANMACHINE
need some help, in the left corner of firewall area is a vac tee[also is a checkvalve]. one from t/b second to a bundle down by fender,third is 5'' long ????? can't find the connection.was working in that corner moved that checkvalve around out of my way,went to start little to no vac.found the line goes nowhere i can see.any ideas.
99 ext cab auto, 7psi mitsu 14b turbo,ported and coated 2 1/2'' exhaust to turbo muffler,fake cat,underdrive pulley,efan,2.3 t/b,42lb racetronix inj,4.3 fuelpump,aem wideband,pyrometer,f/press guage,.lowered rear 2'',hhr seat , counsole,and finished fabbed cowl hood.
post #2 of 4 Old 09-21-2010, 09:02 PM
User is: osmandius is offline
Re: vacuum line info on 99 s10
There is a little connection on the fender between the thing for the breaks and the fuse box (from memory). I really couldn't see mine until I removed the "thing" for the breaks but if you fell around you should be able to feel it. I can take a pic if you need (it was a pain to find). Mine is a '99 Sonoma
post #3 of 4 Old 09-21-2010, 09:17 PM
300k's Avatar
User is: 300k is offline
There is a vacuum storage tank in between the fender and the inner fender bolted in.
1999 S10 2.2 Ex-cab 5-sp Turbo
Build Thread: http://www.s10forum.com/forum/f105/2...-build-621114/
1998 S10 2.2L Auto Turbo
Build Thread: http://www.s10forum.com/forum/f105/u...-build-402312/
2005 Yamaha R6 Raven edition
1965 MG-M resto-mod fully restored
2000 Honda S2000
300k is offline
post #4 of 4 Old 09-21-2010, 09:54 PM Thread Starter
thanks guys i found it just before i read your replys and i couldn't belive that was it cuz it felt like a bolt sticking out so i put the hose on it and we got vacuum.glad i checked thread. thanks again
