upper hose hot, lower hose cold - S-10 Forum
post #1 of 12 Old 01-29-2011, 01:26 AM Thread Starter
User is: juavos00 is offline
What causes this issue? Radiator and heater core are less than a year old.
My Truck: '95 S10 originally a 2.2L now has '95 4.3L "W" CPI Engine, '01 Manual Transmission, Centerforce Dual Friction clutch. Crane Cams 1.6 rockers, OBX stainless steel headers with true duals; flowmasters dumped at the axle. K&N FIPK intake. Electric fan(s). Auburn posi with 3.73 gears and Cal-Tracs for traction.
juavos00 is offline
post #2 of 12 Old 01-29-2011, 01:29 AM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
User is: 1fast4by is offline
Send a message via AIM to 1fast4by
Re: upper hose hot, lower hose cold
thermostat
"The police cannot protect the citizen at this stage of our development, and they cannot even protect themselves in many cases. It is up to the private citizen to protect himself and his family, this is not only acceptable, but mandatory."
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #3 of 12 Old 01-29-2011, 01:50 AM
Sure why not.
rhygin's Avatar
User is: rhygin is offline
If the truck isnt overheating, a properly working radiator? lol. If your talking about the heater core hoses your core is clogged.
Originally Posted by itsalldownhill View Post
How do I post a question on this forum?
rhygin is offline
post #4 of 12 Old 01-29-2011, 02:01 AM Thread Starter
I am talking about the radiator hoses.
I can smell coolant so I bought the dye, and in the process of putting it in the radiator I noticed the top hose is hot, while the bottom hose is as cold as ambient temperature. I left it running for approx 30 minutes with same results.
juavos00 is offline
post #5 of 12 Old 01-29-2011, 03:19 AM
Fronk-en-Steen
mostizzle's Avatar
User is: mostizzle is offline
i agree with 1fast4by.
TelAmeriCorp
post #6 of 12 Old 01-29-2011, 10:49 AM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
Dont we all?
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #7 of 12 Old 01-29-2011, 10:17 PM Thread Starter
bought a new one from oreilly's earlier and changed that puppy out and it still seems that the lower hose is cooler than what it should be.
On a side note I believe we have found the coolant "leak" which is a freeze plug but I'm not sure which one yet.
juavos00 is offline
post #8 of 12 Old 01-29-2011, 11:26 PM
A CLEANMACHINE's Avatar
User is: A CLEANMACHINE is offline
Send a message via Yahoo to A CLEANMACHINE
it seems normal to me if the hot coolant leaves thermo into radiator and the air cools it off then starts the return back to water pump ,wouldn't that be how it was designed to operate.
99 ext cab auto, 7psi mitsu 14b turbo,ported and coated 2 1/2'' exhaust to turbo muffler,fake cat,underdrive pulley,efan,2.3 t/b,42lb racetronix inj,4.3 fuelpump,aem wideband,pyrometer,f/press guage,.lowered rear 2'',hhr seat , counsole,and finished fabbed cowl hood.
post #9 of 12 Old 01-30-2011, 12:46 AM
Tech Mod
beandip's Avatar
User is: beandip is offline
Originally Posted by 1fast4by View Post
Dont we all?
No
like it was said the post above me, the hot coolant leaves the thermostat and cool coolant enters the water pump.
-Jonathan
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #10 of 12 Old 01-30-2011, 12:58 AM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
Damnit Jon, yes you do!!!
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #11 of 12 Old 01-30-2011, 01:01 AM
Tech Mod
beandip's Avatar
haha you were wrong *points finger*
-Jonathan
beandip is offline
post #12 of 12 Old 01-31-2011, 07:16 PM
Sure why not.
rhygin's Avatar
Hmmm lol.
If your radiator is putting hot coolant back into the engine it is fail.
Thermostat opens hot stuff goes in the top runs down cooling passages turns into cold stuff, cold stuff goes back in through the bottom to get hot again. A vicious cycle.
rhygin is offline
