turns over won't start - S-10 Forum
post #1 of 6 Old 02-07-2013, 04:31 PM Thread Starter
User is: mothballeater is offline
I have a 98 2.2L manual. it will turn over but wont run. the check engine light stays on. I have replaced the starter less than two months ago i bought the truck in october and since have replaced the fuel tank, filler neck, and straps, pump and sending unit, sending and return lines as well as fuel filter. i have a brand new air filter and have cleaned all the box units from the intake to the filter. it also has a brand new battery. So heres the thing it runs on starting fluid but then shortly dies. I have fuel pressure to the shredder valve and the pump whur's when the key is turned. I have checked every fuse in the cab and under the hood and swapped relays to rule them out. I tested all of the terminals with my test light and found that my ECMb fuse terminal as well as my TBSI fuse terminal and my LDLEV fuse terminal are all dead. I got my hands on a $400 plus dollar computer reader and sure enough would not pull a code i just get a flashing EV symbol and a big fat goose egg on the screen. I figured my way to the intake manifold sensor and the two throttle body sensors and the wiring in between to fuse box. I did have to sauder and broken wire in the harness when I replaced the gas tank. checking the plugs for corrosion found nothing so i plugged them back in and and sure enough the truck fired right up and runs like a charm with no check engine light. drove it 5 or so miles and shut it off starts right back up? I plugged the computer reader back in and still got the same EV flashing signal? just to be sure i plugged it into my buick lesabre which doesnt have it's check engine light on and it actually works and shows results. Im very confused as to what the issue is. i would also like to disclaim that the ignition switch has been pulled apart as the little black piece is missing and the key is clearly aftermarket from some axxess company. any insight would help i suck with electrical problems
post #2 of 6 Old 02-07-2013, 04:34 PM Thread Starter
Re: turns over won't start
also the security light comes on and off randomly. i did however notice that when the truck finally did start the security light on the dash was infact off
post #3 of 6 Old 02-08-2013, 12:59 AM
Ratchety thing
tCstump's Avatar
User is: tCstump is offline
If you pulled your ignition switch you probably need to reset your BCM. If security is on, don't start the truck but crank the truck once then leave the key in the run position for about 10 mins. The security light will go off. Turn they key off for 5 seconds. Then repeat this 2 more times. This will relearn your BCM to your ignition and it should start. That is if security is you problem.
tCstump is offline
post #4 of 6 Old 02-08-2013, 02:56 PM Thread Starter
alright. sure enough this morning the truck would not start. I did the procedure you described and on the third and final time instead of the security light dissappearing after it flashes it simply stayed on. by the third crank it turned over and in running. thank you for all your help. atleast if its not a permanant fix it will get me out of the woods if it happens to continue. but all in all it worked so thank you
post #5 of 6 Old 02-08-2013, 02:58 PM Thread Starter
i never actually pulled the ignition but when i bought the truck it had clear evidence that someone had messed with it. hopefully a new ignition switch will stop it if it continues
post #6 of 6 Old 02-08-2013, 11:04 PM
Ratchety thing
tCstump's Avatar
No prob man, glad it worked for ya. If you do change the igntion cylinder just repeat the BCM again and all should be good. I swapped to a tilt wheel the other day and didn't change the ignitioin cylinder. My truck wouldn't start and it had me freaking out. haha
tCstump is offline
