turbo build begins!!!
Old 10-20-2009, 06:20 PM   #201
Re: turbo build begins!!!
Man do you know how many hourses is your truck at right now!
Old 10-20-2009, 09:51 PM   #202
ados egnaro
NevurMind85's Avatar
man now im thinking of running a turbo. Cant quite decide but a turbo is cool and probly easier due to set up do to i wouldnt have to fab anything for very little as opposed to a super charger
Old 10-20-2009, 11:07 PM   #203
joining 2.2l boosted club
1tuffs10's Avatar
i dont know i just know i love it...and the turbo is much easier imo because im not to familiar with sc systems and sc is belt driven.
as for hp, im prolly close to 200hp give or take, thats with everything pretty much stock still! havnt had time to get it on a dyno!
here is the new air inlet location! fits better under the hood too!
Old 10-21-2009, 12:13 AM   #204
ados egnaro
Looks good.
Old 10-24-2009, 05:05 PM   #205
I have been running a boosted 2.2 for almost 7 years now and I still enjoy driving it as much now as I did the first time I took it out... actually it's more fun now because it's faster than ever!
Your air filter set up looks much better now, at the very least you should be running much safer IAT's and consequently lower EGT's. Have you switched to colder plugs yet?
Old 10-29-2009, 11:43 PM   #206
1tuffs10's Avatar
what do u mean by colder plugs sorry some stuff is still new to me yet...but im hoping to learn alot in the next year as im going to uti in chicago, but anyway plugs are just some i bought a while back from autozone...ive been wanting to change out the coil packs as well either msd, or accel, and same for wires but dont know which would work better!
Old 10-30-2009, 04:25 AM   #207
The plugs heat range basically refers to how far into the combustion chamber the plug sits. A colder plug is built so that it doesn't protrude into the cylinder as far as a hotter plug would. You'll probably learn a lot more details in school but it'll keep the engine from detonating. Throw some ngk 4554 copper series plugs in if you get a chance.
Old 11-02-2009, 11:56 PM   #208
1tuffs10's Avatar
alright ill look into it tomorrow when i get my oil, in need of an oil change!! yea im sure i will im pretty excited to start!!!
Old 11-03-2009, 04:16 PM   #209
Just turned 18
Is your truck flex fuel? Just wondering what you did with your fuel pump setup.
Old 11-03-2009, 09:58 PM   #210
1tuffs10's Avatar
min is flex..fuel pump is stock the flex fuel pump works just fine, all i really need is bigger injectors, and a good engine build and ill be really happy!
Old 11-03-2009, 11:09 PM   #211
Just turned 18
I figured, cause I've read through yours completely and wasn't sure if I skipped over you buying an aftermarket pump or not.
Old 11-07-2009, 03:20 PM   #212
1tuffs10's Avatar
i got thsoe ngk plugs turbos10 and i have to say that was a good tip...the truck felt a noticable diffrerence right away, but i think i messed up one of my plug wires when i was pulling the boot off the old plug, so you got any suggestions for wires?
Old 11-07-2009, 08:54 PM   #213
I don't have a favorite wire brand... msd, accell, any of the name brands should be fine. I think "performance distributer" might have a pre made set but you'll probably have to get a universal four cylinder set and custom fit them from anyone else. I don't think the big names make them for the 2.2l yet. Does anyone else know?
Old 11-07-2009, 09:00 PM   #214
Just turned 18
http://www.summitracing.com/parts/MSD-32779
Taylor makes wires specific to our trucks as well.
Old 11-10-2009, 08:20 PM   #215
1tuffs10's Avatar
oh somthing else i was gonna ask, with turbo being installed should the gap of the plugs be changed? i set them to .40 when i put them in..
Old 11-10-2009, 09:52 PM   #216
A CLEANMACHINE's Avatar
set the gap to .35 and you can get magnecor pre made 8mm or 10mm ithink just google them. i'm also going to go to that plug few more weeks.like your setup good job just a thought about the iat location,been doing alot of research and many turbo builds relocate the iat into 12-14'' before throttle body as it monitors charge temp and will help retard timing slightly as your boosting.i'm running 2 bungs one each location so i can go between to check which is better but all say put by t/b.
Old 11-10-2009, 10:52 PM   #217
theoretically the closer the better but it doesn't make that much difference with the 2.2l ecu's... especially on low boost with premium fuel (or E85) and the colder plugs. We just retune what the computer is supposed to do with the iat once the engines are built and boost starts to be increased. Sometimes it can be a hassle to keep the iat installed in an intercooler pipe!
Old 11-12-2009, 11:57 PM   #218
1tuffs10's Avatar
yea id be afraid of it poppin out on boost or somthing!
Old 11-13-2009, 05:35 PM   #219
boosted 2.2L
cs xtreme's Avatar
GM does have one on different models that threads in.
the push in ones will leak boost up through the connector.
but personally mine is on the intake to the turbo.
Old 11-13-2009, 10:14 PM   #220
yes they do have threaded version i picked one up few months back,check it out.
http://www.bmotorsports.com/shop/pro...oducts_id/1597
Page generated in 0.58824 seconds with 31 queries
[Output: 106.89 Kb. compressed to 98.91 Kb. by saving 7.98 Kb. (7.46%)]
