#51 |
joining 2.2l boosted club
Re: turbo build begins!!!
good news wastegate came a day early..so that was a nice suprise today!! its used but it looks like its in great condition and i just have to order some valve seats for it
and maybe dif springs he didnt send any but hey cant beat 61 bucks for a snyapse wg ill buy the springs later i havnt takn it apart to see what size is in it yet! heres a pic of it on the turbo header was checkn fitment to see if david got the right size flange and he did!! so thats great! money is being sent out tomorrow for the intercooler, im taking csextremes intercooler, hes swapping out for a bigger one i believe! and next week maybe i'll have it and order pipes next week!![]() ![]() |
#52 |
Been a whilesince i cheacked out this thread, awsome header!!! Also I see mention of Partriot Head, it will fit the 98+ 2.2's. I currently am running a Stage 3 on my 2000 S10.
#53 |
boosted 2.2L
are you sure that is a divided t3?
looks rather large |
#54 |
im pretty sure!! he asked me twice to be sure so it should be!
#55 |
cool!!! ![]() |
#56 |
i just got the dimensions of a t3 and they match up exactly as the size says a t3 is. 4.3"x2.75"
#57 |
LOOKS good!
#58 |
The wastegate isnt poking into anything? It looks like it comes a good bit away from the engine. It does look good though!
#59 |
hey i have been reading your guys post here and i have a few questions i am turboing my 1995 2.2 i got a turbo kit for 499 plus tax and shipping it comes with a turbo manifold, wastgate, oil return lines and a t3 t4 turbo with all parts needed to bolt right up i made a t3 t4 flange for my downpipe but i am looking for injectors do you guys know what the stock 2.2 comes with i have been told its like 14 but then i have also been told its 24lb but 24 lb sounds to big to be stock and then i need a fuel pump should i use a 190lph or a 255lph walbro pump? any suggestions or comments would be nice thanks.
#60 |
its around the 20 somthn i think...but not really sure! |
#61 |
AHHH GUTLING I HATE YOU!!! YOU JINXED ME!!! yea i got a prob with that, here i'll just show you if anyone has any ideas or if i could move these lines that are circled, like remount them another way somehow i could fit it there perfect but also i got some vacum line today and wanted to test out the wastegate to see if it works ok since it was ebay and used! i think i got a prob, hooked it up to port d and it lifts but you can hear air passing through the valve so thats prob not a good sign.. and its seeping through the brass port fitting too im gonna have to do some work before i put it on! heres a vid so u can see what i was saying as well!!![]() video link!!! http://www.youtube.com/watch?v=_kEK4Qak_IU |
#62 |
Lol damn, that is a tight fit. That wastegate looks big though, I know you like it but maybe a slimmer profile wastegate? Or can you not just bend that line a little? You got a shot of the manifold on the engine? like a little more to the left, where you can see the engine.
#63 |
And im not quit understanding your problem, is the air coming out the other port? What did you hook up to the other end of the vac line.
#64 |
yea hers a dif shot of the header!
#65 |
some of those lines are gonna be in the way of the dp thats why i fitted it up today to see what all problems id have to fix! so the oil line is gonna have to be redone and ill be moving alot of the cables back outta the way and have them zip tied there all just kinda hangin freely so thats why it looks like that right now!
im thinking i can get a elbow pipe for the wg so its not sticking in that direction! because theres alot more space in front of the header Last edited by 1tuffs10 : 05-08-2009 at 12:48 AM. |
#66 |
its leaking out the valve itself thats the air sound u hear in the video because im almost postive when its lifted u shouldnt hear any air noise, and its leaking the the screw in area of the port fitting of the bottom port the other ones seem to be fine on not leaking out the port but c&d seem to wanna leak through the valve stem! |
#67 |
boosted 2.2L
http://www.tialsport.com/prod_wg_mvs.htm http://www.atpturbo.com/Merchant2/me...egory_Code=FLS ![]() you could either use the listed adapter from atp or cut off that flange and use the supplied v band flange. cut and replace would give you the most room Last edited by cs xtreme : 05-08-2009 at 01:54 AM. |
#68 |
boosted 2.2L
doing a hydroboost conversion could give you some more room |
#69 |
yea i know its the brake lines thats why i put a big oh no there!! lol...i have a few ideasa before i think of buying a new one! if it doesnt work out then il have no other choice then to buy a smaller wg ![]() |
#70 |
boosted 2.2L
but its v band
I love v band ![]() its what I'll be using if I ever upgrade the header and turbine housing. just sucks David didn't realize this when adding the wg flange. Last edited by cs xtreme : 05-08-2009 at 11:07 AM. |
#71 |
vband for the win. you could probably sell yoru wastegate for what you paid for it on ebay, or find someone and swap with you.
#72 |
haha i know i like vband too, everything im doin is vband except the wg.. ![]() |
#73 |
as far as the wg leaking i called synapse and they are servicing it for free! well almost ill have to ship it to them. and ill be getting new valve seat and seal for a descent price! so at least it will be in full working condition if i have to sell it!
#74 |
if i can remember right air is suppose to come out of there cause when u lift off the gas its suppose to relieve the pressure off of the exhaust side like a bov does for the intake side. i could be wrong. it has been almost 3 or 4 years since i have built a turbo'd vehicle.
#75 |
boosted 2.2L
mvs and call it a day. I'm even looking at a tial stainless steel turbine housing so everything will be v band. |
#76 |
The doctor is in...
You can bend new brake lines so they won't be in the way, it isn't hard at all. You could also try switching out the reservoir for a slimmer unit. Also if you buy a second head you should get the valves I have for sell.
-Nate |
#77 |
#78 |
#79 |
The doctor is in...
I have a waste gate and BOV from JGS that is brand new in the box.
-Nate |
#80 |
#81 |
The doctor is in...
Sent you a PM.
-Nate |
#82 |
well some good news about my wg..lol i called synapse in cali and talked to peter the guy that runs or came up with the concept of the new products and he basicaly said if they see something wrong they cant fix then they will replace it free of charge with brand new one!! so im pleased!! either way it will be fully functioning when i get it back, and 30 dollars for both valve seats and copper seal! if i went to a distributer it would be like 60-80 so when i get it back ill test fit again and if it dont work then ill be selling it for more then what i bought it
another update:: two weeks from now ill be ordering my turbo! yay!! intercooler pipes should be on there way and intercooler soon too i imagine! Last edited by 1tuffs10 : 05-13-2009 at 12:01 AM. |
#83 |
update:
had a small scare the other day i was passing a vehicle and all a suddon i saw smoke comin out the back and then i see smoke coming out from my hood and im like &$&%& %%_%, so i pull over and quickly turn off the truck and i wait a bit for it to cool down and i see green all over, my radiator hose blew off when i was passing, that was a first..lol def gonna have to get a stronger clamp on that hose because i have a feeling if i get my turbo on its not gonna hold at all! but i was relieved when i saw it was just that thought, whew! thought i was gonna be back to square one for a sec though! Intercooler on its way! should have by next week sometime, wg sent out on wed. to synapse in ca with money order for new valve seats and copper seal. was also looking into getting a book on tuning since im new to forced induction, came across this book and wonder if its good book or not? ![]() |
#84 |
Registurd Userer
I'm excited for you. If I were you, I'd download that wastegate and get a TiAL MVS 38mm gate.
Good looking header! Good luck. |
#85 |
yea ive been hearing alot of downfall on the synapse wg, but in all the bad ive seen or read about the only problems is when i get to more then 15psi where a mbc is needed to increase the boost, i dont plan on that happeing fora long time so we will see how it holds up when i get it back in full working condition and put in! if it dont work out then tial it is!!
#86 |
one of a kind
its looking great so far
#87 |
ahh i just got a call from synapse today and apparently the wastegate i bought on ebay was one of the very first wg they made and only 25 were made..lol and i happend to have it he basicaly said it would be a souvenier and its pretty old, lol but that doesnt freakn help me any i still need a wg so he cut me a really great deal since i already bought that one, 90 dollars for brand new with boost connects and hoses so i guess im still happy they are gettn it sent out today!
#88 |
boosted 2.2L
if its one of the first you would think it would be worth more to them.
sounds like they just wanted one of their originals back. |
#89 |
heh yea you would think but oh well! 90 bucks is still good to me with hoses and connections
#90 |
boosted 2.2L
very true
and if you cant use it you could sell it for more. |
#91 |
yep!!
#92 |
got my fmic in today!!! looks really nice in good shape. i got it mounted and ill have pics later but atm im at my sis's house grilln out oh yea baby!!!! ribs, burgers, corn mmm..mmm..mmmm!
#93 |
i still need to get it leveld out a lil bit more and do a bit more triming on the front kit but overall it looks like it will mount up alright and so the fun begins
#94 |
no no no!!! its all wrong you gotta cover the intercooler up with a card board look-a-like intercooler! LOL jk looks good
#95 |
DAMNIT i knew i got ripped off with the metal one!!! lol thx.. |
#96 |
ok i posted before about the one i bought off ebay leaking well i finally got my brand new one that synapse swapped out for me for a hell of a price all this for 90 bucks got the promotional deal!! saweeeet!!!! and i tested this one and no leaks at all and rises right at about 4-5 psi on port c-d just like the manual says so its working
![]() just got tracking number for piping and boost gauge and a quick tap for just after the compressor housing so i dont have to drill and tap my turbo for schedule next week!! ![]() |
#97 |
my boost gauge came in it looks sweet at night!!! i like it
#98 |
#99 |
thx, my air/fuel gauge will be the same brand!!
#100 |
and im going another route at the moment cant wait for more pics! |
