Tried cavalier pcm - S-10 Forum
post #1 of 11 Old 01-17-2004, 02:21 PM Thread Starter
Justin's Avatar
User is: Justin is offline
Send a message via AIM to Justin
Tried cavalier pcm
It did'nt work! I pluged it up, started the engine and it cut off right after it turned over. So i am thinking there is some different fuel delivery problem or spark problem. Or maybe the pcm is bad. It did look like it was sitting on a shelf for a while. If you guys have any ideas how to bypass these problems or a place where i can test the computer. let me know.
Justin is offline
post #2 of 11 Old 01-17-2004, 04:52 PM
8.31@164
Black X's Avatar
User is: Black X is offline
what do you have??? i have an extra ECM
408"LS, 88MM Turbo, 275 Radial, 8.31@164
Black X is offline
post #3 of 11 Old 01-17-2004, 10:33 PM
Registered Stepsider!!!!!
minilowz's Avatar
User is: minilowz is offline
Send a message via AIM to minilowz
I tried one out of a mid-90's Beretta, and the truck run a little rich(fuel pouring out tailpipe/smoke) I also tried one out of a 98 2.2 Auto, and it worked fine in my 5 speed.
99 Black Xtreme Ext Cab Stepside 2.2L 5 Speed(Gone on 6-17-04)
04 Electric Blue Dodge SRT-4 w/Sunroof(Gone Feb 06)
Current: 99 Grand Prix GTP
minilowz is offline
post #4 of 11 Old 01-17-2004, 11:01 PM
Zq-8_dawg's Avatar
User is: Zq-8_dawg is offline
aintskr8pin what year is your truck, and what year was the PCM out of? The 94-95 engines are different in the fact that they are not SFI (sequential fuel injection) this is probably why Minilowz was running rich. and the 98 is different from the 99+ in the fact that in 99 the EGR valve was removed. It might also mean that the PCM could have been damaged. On car-part.com they show the PCM for 96+ working on all the current 2.2L Could the PCM have been out of a 2.4L cavalier and not the 2.2L?
Minilowz after you installed the 98 PCM were you able to get over the 94-95 MPH mark?
post #5 of 11 Old 01-17-2004, 11:04 PM
minilowz's Avatar
nope still cut off at 93mph just like the original, I bought it to send to ASE to get it reburned, But I'm debating on a new truck right now. So I have a few spare ECM's laying around.
minilowz is offline
post #6 of 11 Old 01-18-2004, 01:01 AM
BigRey's Avatar
User is: BigRey is offline
Send a message via Yahoo to BigRey
aintskr8pin, that sounds like what would happen if you took the cluster out of the cavalier. It's the anti-theft device that is programed into them. Try waiting with the key on engine off for 10 to 15 minutes after you installed the PCM, that may get around the securety feature.
My Last ride... She will be missed.
BigRey is offline
post #7 of 11 Old 01-18-2004, 08:03 PM Thread Starter
Justin's Avatar
Re: Tried cavalier pcm
My truck is a 97 5-speed and the cavi pcm is from a 97. Hopefully it is not damaged, but I will try to leave the key in run for a few minutes to see if i can disable the security feature.
Justin is offline
post #8 of 11 Old 01-19-2004, 02:32 PM Thread Starter
Justin's Avatar
alright, so heres the deal. I tried what you said bigrey, no luck. Is'nt the security feature programed into the bcm? I tried to find the feature on a pcm pinout map of a cavi that has been posted here before, but no luck. It will turnover, but imediatly turn off. And every time after that it just rotates and won't turn over. Unless you turn the key off and wait a few secs, then the process just starts all over as if it is reseting itself. I opened the computer and all the circuits and solders look fine, so i don't think the computer is faulty. Any suggestions would help to get this thing rollin. I
Justin is offline
post #9 of 11 Old 01-19-2004, 10:12 PM
BigRey's Avatar
Possible bcm nocomm? That turning on and shuting off emediatly sounds like a fuel cut. What I can remember when working at my local chevy is when you removed the intsrument cluster from a cavy, they do exacly what you say it's doing. So maybe you'r going to have to get a bcm, or wire your truck like a cavy, or something to do with the ignition key? Just ideas.
BigRey is offline
post #10 of 11 Old 01-20-2004, 12:12 AM
former title junky mod
Futuresweets10's Avatar
User is: Futuresweets10 is offline
Send a message via AIM to Futuresweets10
Not to sound like an idiot, but what does putting a cavi PCM in our trucks do?
01 F-250- Daily driver
Originally Posted by Futuresweets10 View Post
Jan. 20, 2009- R.I.P AMERICA
post #11 of 11 Old 01-20-2004, 12:39 AM Thread Starter
Justin's Avatar
If i have to rewire my truck like a cavi, forget it. I'm not willing to spend anymore money if this is not going to work with little mods. I will prolly take it back to the junkyard and exchange it for an e-fan. Besides, i am working on getting a programer so i can reflash my computer.
108 speed limiter instead of 96. It only cost 65 bucks rather than 300 with ase.
Justin is offline
