TORQUE SPECIFICATIONS-1994-2001 CHEVY S10’s & GMC SONOMA’s - S-10 Forum
post #1 of 9 Old 03-07-2014, 10:34 PM Thread Starter
2Low2Tow
GmcNoma95's Avatar
User is: GmcNoma95 is offline
Post TORQUE SPECIFICATIONS-1994-2001 CHEVY S10’s & GMC SONOMA’s
**Ft-lbs (Unless otherwise indicated)**
FOR 1994-2001 CHEVY S10’s & GMC SONOMA’s
**ALL TORQUE SPECS ARE PER GM FACTORY & HAYNES MANUAL**
2.2L FOUR CYLINDER ENGINE:
Camshaft sprocket bolt 96
Camshaft thrust Plate bolts 106 in-lbs
Crankshaft Pulley to Hub Bolts 37
Crankshaft Pulley to Crankshaft bolt 77
Connecting Rod Cap Nuts 38
Crankshaft Main Bearing Cap Bolts 70
Crankshaft Sensor 97 in-lbs
Coolant Drain plug- Cylinder Block
*(Driverside of Engine block-below Freeze plugs) 11
Coolant Pump 18
Coolant inlet bolts 18
Coolant Outlet Adapter Bolts 89 in-lbs
Coolant Outlet Nuts 89 in-lbs
Electronic Ignition System Coil Assy 18
EGR Valve Nuts 12
EGR Valve Adapter Bolts 97 in-lbs
EGR Valve Solenoid Bolt
*(Which is mounted between upper 22
intake manifold and fuel rail under TPS Sensor)
Engine Coolant Temp Sensor 106 in-lbs
Engine Lift Bracket Nut/Bolt 37
Exhaust Manifold Nuts 115 in-lbs
Exhaust Manifold Studs 89 in-lbs
Exhaust Pipe To Manifold Nuts 18
EVAP Emissions Canister Purge Valve Nuts 18
Fly Wheel Bolts- AUTOMATIC TRANSAXLE 55
Fly Wheel Bolts- MANUAL TRANSAXLE 55
Fuel Injector Retainer Bolts 15
Fuel Outlet Pipe to Fuel Pressure Regulator Nut 21
Heater Hose Fitting-Upper Intake Manifold 24
Intake (Lower) Manifold Nuts (thru 1998) 24
**1999+Later Torque Nuts and Bolts to 17**
Intake (Lower) Manifold Studs 89 in-lbs
Intake (Upper) Manifold Bolts 22
Knock Sensor 14
Map Sensor 27 in-lbs
Oil Fill Tube Nut 106 in-lbs
Oil Filter Connector 26
Oil Filter ¾ to One turn after gasket “Oring” contact
Oil Level Sensor 16
Oil Pan Nuts & Bolts 89 in-lbs
Oil Pan Drain Plug 33
Oil Pan Studs 89 in-lbs
Oil Pressure Sensor 115 in-lbs
Oil Pump Cover bolts 89 in-lbs
Oil Pump Drive Assy. 18
Oil Pump Mounting Bolt 32
Oxygen Sensor 31
Pressure Plate Bolts 28
Cylinder head bolts:
STEP 1: LONG BOLTS 46
SHORT BOLTS (Exhaust manifold side) 43
STEP 2: Tighthen ALL BOLTS an additional 90 degrees
Engine mount-to-engine bolts 39
Engine mount through-bolts 38
Engine mount bracket-to-frame bolts 33
Lifter Guide retainer-to-block stud 97 in-lbs
Oil Pan bolts 89 in-lbs
Oil Pump-to-block bolt 32
Rocker Arm Studs 37
Rocker-arm nuts (Bolts on 1999 and later) 19 to 22
Timing Chain cover bolts 97 in-lbs
Timing Chain Tensioner Torx Style Bolts 18
Sparkplugs 13
Valve Cover bolts 89 in-lbs
Accelerator Cable mounting Bracket 18
Accessory Bracket Assy. to Block 37
***EVEN THOUGH THE 4.3 TORQUE SPECS BELONG IN THE
262ciforum, I didn’t want our big brothers to feel left out***
4.3L V6 Engine Ft-lbs (Unless otherwise indicated)
Valve cover bolts:
1994 and 1995 90 in-lbs
1996 On 106 in-lbs
Intake manifold bolts
1994 and 1995
VIN Z (SEE ILLUSTRATION)
All, except bolt 7 in intial tightening sequence 35
Bolt 7 41
**Bolt 7 becomes bolt 6 in final tightening Sequence.**
Intake manifold torque sequence-4.3L (VIN Z) throttle body fuel injection
VIN W (FOR ALL INTAKE MANIFOLD BOLTS) 35
1996 On (See illustration For Intake Manifold Tightening Sequence)
Step 1: 26 in-lbs
Step 2: 106 in-lbs
Step 3: 132 in-lbs
Exhaust Manifold bolts/studs
Step 1: 132 in-lbs
Step 2: 22
Cylinder Head Bolts
1994 and 1995 65
1996 On (See illustration)
Step 1 (All bolts): 22
Step 2:
Short bolts Tighten an additional 55 degrees
Medium Bolts Tighten an additional 65 degrees
Long Bolts Tighten an additional 75 degrees
Timing chain cover bolts
1994 124 in-lbs
1995 On 106 in-lbs
Camshaft Sprocket Bolts 21
Balance Shaft retainer bolts 106 in-lbs
Driven gear bolt
Step 1: 15
Step 2: Tigthen an additional 35 degrees
Drive gear retaining stud 144 in-lbs
Rocker Arm nuts (bolts on 1999 and later) 20
Vibration damper bolt 70
Hydraulic Lifter retainer bolts 144 in-lbs
Oil Pan
1994 and 1995
Bolts 100 in-lbs
Nuts 204 in-lbs
1996-1998
Bolts 204 in-lbs
Nuts 216 in-lbs
1999 and later (All) 18
Oil pump Bolt 65
Rear main oil seal retainer bolts 132 in-lbs
Flywheel/drive plate bolts 75
PROJECT NOMA ~UNDER DE-CONSTRUCTION!~
1) 2/3 DrOp Kit
2) Rebuilt 4L60E Trans. W/ Performance Parts.
3) Rebuilding a 2.2L into a Stroker motor
Re: Driveshaft vibration when pulling out???? Quote: Originally Posted by s10xtremist Stop pulling out.
Originally Posted by rimara View Post
People are willing to help you...they just don't want to burp and diaper you.
post #2 of 9 Old 03-08-2014, 09:59 AM Thread Starter
2Low2Tow
GmcNoma95's Avatar
Re: TORQUE SPECIFICATIONS-1994-2001 CHEVY S10’s & GMC SONOMA’s
The illustrations I had listed with 4.3 specs aren't showing will try to make a 2nd attempt to post them shortly.
1) 2/3 DrOp Kit
post #3 of 9 Old 03-09-2014, 09:51 AM Thread Starter
2Low2Tow
GmcNoma95's Avatar
**First Picture is the tightening sequence for VIN Z 4.3L Intake Manifold Bolts 1994-1995**
**Second Picture is for 1996 & Newer-Intake Manifold Tightening Sequence**
**Third picture is for the tightening sequence of Cylinder head bolts on 1996+Newer models.
ID:	163985   Click image for larger version
ID:	163993   Click image for larger version
1) 2/3 DrOp Kit
post #4 of 9 Old 10-26-2014, 03:08 PM
User is: 98s10,2.2 is offline
What is the torque value on the tensioner bolt on a 98 s10 2.2? I have the Haynes repair manual and it doesn't say..
post #5 of 9 Old 04-19-2015, 12:12 PM
code_red63366's Avatar
User is: code_red63366 is offline
It would also be nice to correct the mis guided Haynes and store bought chiltons manual on torque specs for the pinion shaft yoke to u joint strap "bolts". Their book says 180 ft. lbs of torque which i know cannot be right. I have already busted off 3 bolts in the past attempting this (and yes they were all grade 8 or higher bolts). With those size bolts...your lucky to see 75 ft. lbs before they twist and break.
Mike...... 2001 S10 2.2, Flex fuel, 5 speed, base model, all stock
2nd vehicle.......2003 Ford Excursion, 5.4, gas, 4 wheel drive, all stock
post #6 of 9 Old 04-19-2015, 12:26 PM
post #7 of 9 Old 04-19-2015, 04:28 PM
jayyk31's Avatar
User is: jayyk31 is offline
The Haynes book says "180 inch lbs"... Thats only about 15 lbs/ft. ??? Confused???
- '92 S10 Extended Cab 2.8 5 speed: new daily driver.
http://www.s10forum.com/forum/f135/m...d-92-a-776930/
-2000 RCSB 2.2 5 speed. Cam swap, Roller rockers, etc... previous DD
:Project '89 S10 Extended Cab 408 LSX, T56 Magnum
Build thread-
http://www.s10forum.com/forum/f213/l...56-n-a-665850/
jayyk31 is offline
post #8 of 9 Old 04-19-2015, 07:14 PM
Brain fart here...it was late last night when i read this.
post #9 of 9 Old 05-16-2016, 08:14 PM
User is: MK Ryder Appling is offline
I need to know the torque specs on the fuel meter body to tbi body those three little bolts. because I broke the front bracket on my fuel meter body and don't want to do it again.
Can someone help me please?
