timing chain. what are signs of it going bad? - S-10 Forum
post #1 of 16 Old 05-29-2009, 03:45 PM Thread Starter
blazed00's Avatar
User is: blazed00 is offline
Send a message via AIM to blazed00
what are the signs of the timing chain going bad??? i have a weird knock commin from the bottom pulley and my truck is
misfiring a few second after its started up on cylinder 3.
seems like i lost alot of power.
ive replaced coils, plugs, wires, fpr, fuel filer, injectors.....
Why overkill... because overkill never left you stranded
Keegan
blazed00 is offline
post #2 of 16 Old 05-29-2009, 04:16 PM
User is: hartman009 is offline
Re: timing chain. what are signs of it going bad?
the only way i know how to check is to take the front of the motor apart and take the cover off exposing the timing chain, thats what i did anyway.
post #3 of 16 Old 05-29-2009, 04:23 PM
User is: Gutling is offline
Send a message via MSN to Gutling
Sometimes it will start to rattle when its getting bad, not much else way to tell besides pulling the cover and measuring its play. It would not cause a misfire on a single cylinder though. Have you did a compression test?
2003 S-10
5.3/4l60e 320hp/327tq
Gutling is offline
post #4 of 16 Old 05-29-2009, 04:56 PM Thread Starter
blazed00's Avatar
yes i have checked the compression. i was getting between 133-150psi on all
Keegan
blazed00 is offline
post #5 of 16 Old 05-29-2009, 07:15 PM
A CLEANMACHINE's Avatar
User is: A CLEANMACHINE is offline
Send a message via Yahoo to A CLEANMACHINE
someone else had this same problem and the fix was #3 injector plug has bad connection and it seemed that atleast three others had this also good luck
post #6 of 16 Old 05-30-2009, 02:40 AM
joining 2.2l boosted club
1tuffs10's Avatar
User is: 1tuffs10 is offline
yea i just asked a similar question a few days ago, im getting a small engine tick only when im at idle and after about 1 min after warming up...had it looked at and the shop told me mine was nothing to worry about as its not that loud if it gets louder then ill have a problem! guess its kinda common but always safe to get it checked out rather then be sorry later on!
2000 xtreme top mount twin scroll t3 header/custom 2.5" straight pipe/ac-delete/56mmtb/lowered 4"/ 44lb injectors/hptuners software tuning/baby blue H.I.D kit/carbon fiber ram air hood/ electric fan conversion/ Turboed with T3/T4 running at 9psi e-85/msd ignition/nkg plugs 2 steps colder/.63 ar hot/50 cold compressor
1tuffs10 is offline
post #7 of 16 Old 05-30-2009, 11:43 AM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
Or just remove the rocker cover. Put a wrench on the crank and roll the motor a little each way while watching the rockers. It would give you and idea of how much slack is in it.
Teamsters Local 1150
SH-60B is offline
post #8 of 16 Old 05-30-2009, 03:22 PM
Broke down
User is: black2002ls is offline
Originally Posted by A CLEANMACHINE View Post
someone else had this same problem and the fix was #3 injector plug has bad connection and it seemed that at least three others had this also good luck
Yep, I chased a cyl3 miss fire for a couple of years. Finally took it to a dealership where I had a connection and it turned out to be a compromised wire on the pigtail for cylinder number 3. If you can, check all of the wires for the injector plugs.
Is this a constant miss fire? Is it a dead miss? Have you looked at the spark plug? Try and give us some more details, does it come and go?
post #9 of 16 Old 05-30-2009, 11:55 PM Thread Starter
blazed00's Avatar
its not a dead. it is not throwing a code but i can take the wire off the plug and watch it miss every few seconds. it will randomly miss on the same plug but every other plug has a strong constent spark. Idk if its a faulty wire. even tho there new, or if its the ignition control module. the coils are also new.
Keegan
blazed00 is offline
post #10 of 16 Old 05-31-2009, 02:55 PM
Broke down
odd that its not throwing a code. It shouldn't be the ICM that was one of my last options when I was having my issue. If it were the ICM it shouldn't be an isolated cylinder missfire, you should get a random cylinder missfire, I would think, and that was the consensus of all of my tech friends. When you say its not a dead miss, have you pulled the plug wire with the truck running? If so, do you notice any difference?
post #11 of 16 Old 05-31-2009, 08:35 PM Thread Starter
blazed00's Avatar
when the plug comes off while its running it just makes it ru a little worse. if i pull each one off they have a strong spark and a constent spark. the one has a weeker spark and you can see the missfire when ground the end of the spark plug against the AC comp. it will spark ok then start missing a few times then spark good for about 10 seconds than miss again for about 5 seconds. the ignition module is my last bet ive replaced everything else unless the coils i just put on are faulty.
Keegan
blazed00 is offline
post #12 of 16 Old 05-31-2009, 08:45 PM
did you check the injection harness at #3 see if there's a bad connection.
post #13 of 16 Old 05-31-2009, 09:06 PM
Broke down
Here is the thing with that. If he has proven that it is on the electrical side of things, there should be no need to check the wiring harness. If he has compared the spark to the spark of the other cylinders and there is a noticeable difference, there is no need to mess with the fuel side.
I seriously doubt it is the ICM but I have been known to be wrong. I've got a brand new fuel injector sitting here that I don't. My .02 is to go to a GM dealer and have them do some diagnostics. I know they are going to charge close to $100 but only authorize them for an hour. Say here, give me an hour of diagnostics, no more. Tell them what the truck is doing and what you have done so far. At this point, with all of the parts you have replaced, you could have paid for the diagnostic and be in a better position
post #14 of 16 Old 06-01-2009, 05:21 PM
2Low2Tow
GmcNoma95's Avatar
User is: GmcNoma95 is offline
Usually if your timing chain goes your truck will definitely not start, and the engine will jump. Ive seen my friends s10s do the same thing which are to major symptoms of a timing chain gone bad. Ive replaced a dozen on older and newer 2.2L & 4.3L (1994-2004). Depending on the years, at least for the old ones mid '90s you can just take off the timing chain cover and radiator shroud and fan etc. with out taken out the engine!
PROJECT NOMA ~UNDER DE-CONSTRUCTION!~
1) 2/3 DrOp Kit
2) Rebuilt 4L60E Trans. W/ Performance Parts.
3) Rebuilding a 2.2L into a Stroker motor
Re: Driveshaft vibration when pulling out???? Quote: Originally Posted by s10xtremist Stop pulling out.
Originally Posted by rimara View Post
People are willing to help you...they just don't want to burp and diaper you.
post #15 of 16 Old 06-02-2009, 10:30 PM
Dr. Mike
CRX304's Avatar
User is: CRX304 is offline
swap the coils and see if the misfire changes to a diff cyl... I've seen NEW faulty coils.
CRX304 is offline
post #16 of 16 Old 06-02-2009, 11:41 PM
300k's Avatar
User is: 300k is offline
ICM's can't drop one cyl. Because of the wasted spark. The pack either works or doesn't.
1999 S10 2.2 Ex-cab 5-sp Turbo
Build Thread: http://www.s10forum.com/forum/f105/2...-build-621114/
1998 S10 2.2L Auto Turbo
Build Thread: http://www.s10forum.com/forum/f105/u...-build-402312/
2005 Yamaha R6 Raven edition
1965 MG-M resto-mod fully restored
2000 Honda S2000
300k is offline
