TEO4H turbo? - S-10 Forum
post #1 of 10 Old 09-15-2008, 12:42 PM Thread Starter
Buoyant
Buoyant's Avatar
User is: Buoyant is offline
TEO4H turbo?
picked one up for $10.00 today. took it off the manifold and it spins freely. fixin on doing a small boost setup for my 2.2, dont want 9million horsepower, just a project to do in my spare time. anyone ever delt with this turbo?
Buoyant is offline
post #2 of 10 Old 09-15-2008, 06:20 PM
tu-tu guru
Chris0nllyn's Avatar
User is: Chris0nllyn is offline
Send a message via AIM to Chris0nllyn
Re: TEO4H turbo?
looks like a 14g or somethin
Everything you need to know about the 2.2L- http://www.s10forum.com/forum/f105/2...-pains-321784/
post #3 of 10 Old 09-15-2008, 10:45 PM
2.2L turbo
idriz's Avatar
User is: idriz is offline
Re: TEO4H turbo?
did that come of a laberon by any chance,, i think it looks looks like it not sure thoe
idriz is offline
post #4 of 10 Old 09-15-2008, 11:02 PM
2.2L turbo
idriz's Avatar
Re: TEO4H turbo?
sorry not a 14b = TD05H-14B
idriz is offline
post #5 of 10 Old 09-15-2008, 11:18 PM Thread Starter
Buoyant
Buoyant's Avatar
Re: TEO4H turbo?
I think it did. it was still on the manifold n such pulled out of a pile of manifolds.
Buoyant is offline
post #6 of 10 Old 09-15-2008, 11:41 PM
tu-tu guru
Re: TEO4H turbo?
whered you get it for 10 bucks...lol
post #7 of 10 Old 09-15-2008, 11:44 PM
tu-tu guru
Re: TEO4H turbo?
heres what google says
In 1988 Mopar went to a small, fast spooling turbocharger for their non-intercooled engines, boost was 7 to 9 pounds depending on the application. In 1989 the mitsu turbo received a larger exhaust outlet for better exhaust flow. My Mopar literature for 1989 states that the mitsu turbo used on the 2.5 had internal mods for more airflow, perhaps the larger exhaust housing is what they were referring to. No parts are interchangeable between the Garretts and the coolant & oil lines are different as well. The mounting flange bolt pattern is the same however (same exhaust manifold) and the exhaust donut is in the same location.
post #8 of 10 Old 09-15-2008, 11:44 PM
tu-tu guru
Re: TEO4H turbo?
heres what it also says....not so good...lol
For performance use I cannot recommend a stock Mitsubishi turbo AT ALL! It has a much smaller compressor, the shaft bearings are a third the size of a Garretts and the exhaust housing is a major restriction! The backpressure at high boost levels must be obscene, the picture above shows the difference in exhaust housing passage sizes. The mitsu's is about the size of ONE 2.2 exhaust port!
post #9 of 10 Old 09-15-2008, 11:50 PM Thread Starter
Buoyant
Buoyant's Avatar
Re: TEO4H turbo?
I live in po-dunk. stopped by the local repair shop, asked if he knew where i could get a turbo that needs rebuilt or something. he had it sitting in a pallet crate of manifolds.....
as for chrisonllyn
o well, it was 10 bucks, ill just screw around n see what i can come up with. maybe i can make it work, maybe not. thanks for the reasearch, i read that page you showed but wasnt sure if they was the same or not.
Buoyant is offline
post #10 of 10 Old 09-16-2008, 12:34 AM
boosted 2.2L
cs xtreme's Avatar
User is: cs xtreme is offline
Send a message via AIM to cs xtreme
Re: TEO4H turbo?
as for chrisonllyn
i was going to start with a cheap turbo (14b) that is untill they said the cartridge was shot and would cost 500 for a new one
