Temp gauge goes up only a Quarter of the way! - S-10 Forum
post #1 of 34 Old 01-04-2012, 03:06 AM Thread Starter
User is: 1994ricers-10 is offline
Hey everyone, so my 1994 s10 2.2 has been running without a thermostat for years before i got it.
i put one in after i rebuilt the engine and the temp gauge only goes a quarter of the way, is that normal?
The thermostat is the stock oem standard one, not the colder ones.
before my thermostat, synthetic oil, rebuilt engine, and a tune up (spark plug wires, gaps, clean fuel injectors, brakes, the whole nine yards) i was getting 15 mpg city
Now after all that im getting 20mpg city is that good?
thanks!
post #2 of 34 Old 01-04-2012, 03:26 AM
monkeytruckin's Avatar
User is: monkeytruckin is offline
Re: Temp gauge goes up only a Quarter of the way!
You might have installed it backwards. I'd try flipping it around and see if that helps.
86 Blazer 4x4 2 Dr Tahoe... Clean DD...
'97 Blazer 4x4 4 door... parts are being gathered...
post #3 of 34 Old 01-04-2012, 03:32 AM Thread Starter
I dont Think so cuz it doesnt fit the other way. does anyone elses temp gauge do the same thing?
post #4 of 34 Old 01-04-2012, 03:58 AM
I Prefer Payne
payne4life's Avatar
User is: payne4life is offline
if its a cheap one it could be stuck open.
also, when my heater core was clogged, my temp gauge only went up about a quarter the way too.
and 20 mpgs is ok. i get 21. it all depends on how you drive, or if its auto or stick, or your rear end gear. there are other factors too but if its moslty stock 20 isnt bad.
2000 SAAB 9-3 2.0t hatchback 5-speed. 145k miles - CURRENTLY ON JACK STANDS
2000 s10 LS X-cab 2.2 flex fuel auto. 170k miles
MODS: 56mm TB, Ebay CAI with K&N filter, E-fan, ZQ8 sway bars, GC steering box, steering shaft u-joint
http://www.cardomain.com/id/brandomonium12
post #5 of 34 Old 01-04-2012, 04:12 AM
User is: Ed98 is offline
sounds good to me. Putting the thermo in backwards would put it in the red.
Ed98 is offline
post #6 of 34 Old 01-04-2012, 11:58 AM
4 wheels aren't as fun
serpentracer's Avatar
User is: serpentracer is offline
yeah mine only goes about that far. the mark between 100 and 210 about. but a live data scan tool says it' running a lot warmer than what the guage shows. I put a new temp sensor in it and it never changed. I'm going with it's just a shitty guage.
02 sonoma 4.3L auto
97 sonoma 2.2L manual
post #7 of 34 Old 01-04-2012, 02:03 PM
Mine runs 1.5 to 2 marks below the straight up 210
Ed98 is offline
post #8 of 34 Old 01-04-2012, 02:25 PM
User is: Ntrain2k is offline
Ditto
Ntrain2k is offline
post #9 of 34 Old 01-05-2012, 10:52 AM
Likes MOAR Low
LoRollinLS's Avatar
User is: LoRollinLS is offline
Send a message via AIM to LoRollinLS
What size thermostat did you put in? Its supposed to have a 195 Degree.
'02 Dime
post #10 of 34 Old 01-06-2012, 08:32 PM
izzy(s10)'s Avatar
User is: izzy(s10) is offline
Send a message via MSN to izzy(s10)
my truck used to run just like that on the quater mark, i rust change the water pump and thermostat and now is always running just below the 210 mark just like 3 or 2 lines down. i hope it does just the same with my a/c on during summer
post #11 of 34 Old 01-13-2012, 05:10 PM Thread Starter
i put the oem replacement 195 degree thermotat. it wasnt the cheapest thermostat, i went with the midrage one to avoid things like that. i just rebuilt my engine and i replaced everything but the water pump, but it seems to be working fine.
post #12 of 34 Old 01-13-2012, 05:37 PM Thread Starter
here u go
Name:	temp gauge.jpg
post #13 of 34 Old 01-13-2012, 05:47 PM
You think your fan clutch may be stuck on? Does it have a roaring noise from under the hood as you accelerate? That would support the complaint of lower gas mileage as well-
Ed98 is offline
post #14 of 34 Old 01-13-2012, 05:59 PM Thread Starter
well shouldnt it be on while im excelerating? my fan is always on (i only see it when its stopped and its at idle)
post #15 of 34 Old 01-13-2012, 06:05 PM
A. Does it have a roaring noise from under the hood as you accelerate?
B. (With the engine off) turn the fan blades with your hand. Does it spin pretty easily? Or does it feel rough and grating? Is it kind of hard to turn? It should be really easy.
C. (With the engine off) next try to wobble the fan front to back. Does it wobble more than 1/4"?
Ed98 is offline
post #16 of 34 Old 01-15-2012, 10:34 PM
TC-S10's Avatar
User is: TC-S10 is offline
This is as high as my temp goes.
TC-S10 is offline
post #17 of 34 Old 01-15-2012, 10:52 PM
Electrical Mod
deathphoenix99's Avatar
could be an incorrrect sensor or the gauge out of calibration...hard to say.
You need a tachometer though.
post #18 of 34 Old 01-17-2012, 01:22 AM Thread Starter
This is excatly how mine is. is that normal?
post #19 of 34 Old 01-17-2012, 01:23 AM Thread Starter
i have an aftermarket tach.... hows the tach going to help here tho?
post #20 of 34 Old 01-17-2012, 01:24 AM Thread Starter
its pretty easy to move, its not rough or hard at all. it has no forward, backward play
post #21 of 34 Old 01-17-2012, 08:29 AM
Well then your fan does not seem to be overcooling your water.
It is the job of your thermostat to regulate the temperature at any given point.
Either your thermostat is stuck open, or your coolant is slightly low.
If you open your radiator cap when cold, at any time, the radiator should be brimming full. A non submerged temperature sender or sometimes non-submerged temperature sender is going to give a low reading.
If your coolant is low, top it off with the proper mix of concentrate and water. Be sure the plastic bottle also has the mix in there between the marks.
If your coolant is low again later, find out why. Check the cap. A bad cap could fail to let coolant be drawn from the bottle.
There are something called tempil sticks that melt at given temperature.
You can rub a 188* stick and a 206* stick on the thermostat housing and observe what happens. With your complaint, neither will melt.
Ed98 is offline
post #22 of 34 Old 01-17-2012, 03:30 PM
User is: dan33klein is offline
are the termostats located in the front or the side of the engine?
upper or lower hose?
post #23 of 34 Old 01-17-2012, 03:32 PM
It is at the end of the upper hose where it bolts to the engine.
Labor Rates: $35/Hr. If you watch: $45. If you help: $55 If you tried to fix it yourself first: $95
Ed98 is offline
post #24 of 34 Old 01-17-2012, 07:11 PM
TC-S10's Avatar
I have been told by more than one person on this forum that it's normal. I have not had any problems.
TC-S10 is offline
post #25 of 34 Old 01-17-2012, 07:29 PM
I can't make head or tails out of the marks on the S-10 temperature gauge.
It starts at 100, it's midpoint is 210 and the right side is 260.
So from the middle to the left is 110 degrees; and the middle to the right is 50 degrees. And there are 8 divisions on both sides of center. (You can scroll up and see an IP cluster.)
I didn't notice this until lately.
When I have time, I'll figure out what it is actually running at with a thermometer.
Ed98 is offline
post #26 of 34 Old 01-17-2012, 08:04 PM
If I remember I'll check mine with the ultragauge tomorrow.
Ntrain2k is offline
post #27 of 34 Old 01-17-2012, 08:39 PM
always something new
S10dude's Avatar
User is: S10dude is offline
use a lazer temp gauge on radiator hose
All truck pics
S10dude is offline
post #28 of 34 Old 01-17-2012, 11:49 PM
My ultragauge reads direct from the OBD2 data stream. Close enough for me.
Ntrain2k is offline
post #29 of 34 Old 01-18-2012, 02:18 AM
User is: nstoolman1 is offline
Mine sits right between the gauge needle and the 210 at operating temp with a 180 stat and an E-fan. My fan switch turns on at 197 and off at 185. It is an 03 2.2.
post #30 of 34 Old 01-18-2012, 02:42 PM Thread Starter
My coolant is always full, i check it twice a week.
i dont think the thermostat is stuck open because its new and if it were stuck open it wouldnt build temp. it would stay at 100 (my truck had no thermostat when i got it and it wouldnt lift off 100)
my cap holds pressure, and i dont have any coolant leaks.
Does your s10 stop a quarter way or right before 210?
post #31 of 34 Old 01-18-2012, 04:21 PM
If it's hot it is 1.5 marks left of 210. If it's cool, it's 2 marks left of 210.
That's its cut-in/cut out range.
It is never 4 marks to the left of 210 once warmed up.
I'm going to go scorch my face and measure the maximum heater temperature now. And my heater core is new, and my cooling system pristine. Be right back.
Ed98 is offline
post #32 of 34 Old 01-18-2012, 05:17 PM
174 degrees is as hot as I can get the heater output @ 3400 rpms.
Ed98 is offline
post #33 of 34 Old 01-18-2012, 08:00 PM
Pics:
Ntrain2k is offline
post #34 of 34 Old 01-18-2012, 11:22 PM
I just drove to Subway, and when my gauge got 1/2 way to 210, I tried to imagine what it would be like if it got no hotter... And I think I'd be complaining about inadequate heat.
I usually still have my control on full hot and the fan on hi at that point.
Ed98 is offline
