symptoms of clogged fuel filter? - S-10 Forum
post #1 of 20 Old 06-05-2008, 10:44 PM Thread Starter
DailyDrivenDime's Avatar
User is: DailyDrivenDime is offline
what are some symptoms of a clogged fuel filter?
i know they are cheap enough to replace anyways but my truck is having some trouble cranking after it gets hot but if i give it some gas it works fine..
i had three codes jump on me the other night...misfire cylinder 3...crankshaft position sensor and some other one i had my buddy clear them to see if it would come back on and two days later still no check engine light? but still hot cranking problems
idk what the deal is just trying to perform some troubleshooting
B-rett
yo
post #2 of 20 Old 06-06-2008, 12:59 PM
mechanicix's Avatar
User is: mechanicix is offline
Re: symptoms of clogged fuel filter?
The check engine light will probably come back on, it requires you to drive for about 50 miles for the computer to recognize engine problems. It sounds like you need a tune up. It would be easier if you could tell what the last code it threw was.
post #3 of 20 Old 06-06-2008, 02:46 PM Thread Starter
it was manufacturer specific and wasnt in the book...i have drove way more than fifty miles about 75 or more atleast
B-rett
yo
post #4 of 20 Old 06-06-2008, 03:47 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
A clogged filter is just the same as running out of gas. Not much response from the gas pedal (way down on power).
Teamsters Local 1150
SH-60B is offline
post #5 of 20 Old 06-07-2008, 09:46 AM Thread Starter
thanks for the help
i think i figured out my problem was leaving a buddies house last night and went to crank it and he said it looked like the 4th of july under my truck sparking so i am goin tto check today to see if the starter wire is loose or if the starter is junk
B-rett
yo
post #6 of 20 Old 06-07-2008, 09:55 AM
I'm slap happy, bitches!
User is: Deeze49686 is offline
dont try to fix the misfire untill you fix the crank sensor code first. the misfire monitor test uses the crank sensor to read crank speed, and if the sensor is faulty it can send a misfire code off. fuel filter test..... pull truck into manual one, and let her rip, if you can get it to shift into 2nd on overspeed, you dont have a bad filter, a bad cat, or a bad mass air flow sensor.
post #7 of 20 Old 06-07-2008, 09:59 AM
Local Tech
ls1s10onair's Avatar
User is: ls1s10onair is offline
i had a very similar problem with mine when it had the 2.2..... after all the headaches, it was the heated oxygen sensor causing it.... but id def be doing the crank sensor first, cuz thats a breakdown waiting to happen
post #8 of 20 Old 06-07-2008, 10:29 AM
Slow Sonoma
Toadz's Avatar
User is: Toadz is offline
Send a message via MSN to Toadz
I thought that was just from the 4 cylinder underneath the hood.
2000 GMC Sierra 5.3L V8
1996 GMC Sonoma 2.2L 4 Cylinder 5-spd
Toadz is offline
post #9 of 20 Old 08-31-2010, 04:26 AM
User is: clarkperez2334 is offline
Hey, hope these one will help
Symptoms of a Clogged Fuel Filter:
(1) Trouble in starting the engine
(2) vehicle stops and refuses to start
(3) Speed of the vehicle is the same (no acceleration)
(4) Engine is not anymore fuel efficient and is not behaving erratically
(5) Sound of vehicle engine has changed and it is misfiring
(6) Car exhausts foul smelling fumes
post #10 of 20 Old 08-31-2010, 02:15 PM
It's "Neanderthal"
SH-60B's Avatar
This thread is 2 years old , I think he figured it out by now.
SH-60B is offline
post #11 of 20 Old 08-31-2010, 07:24 PM
Dropped'01's Avatar
User is: Dropped'01 is offline
Whats the life span of the stock fuel filter? Replace every X amount of miles??? thanks
'01 S10 2.2L 5 speed, 3"-4" drop, K&N FIPK, Flowmaster, 56mm TB, OBX header, STS Pulleys, Cavi Seats, envoy handles, 8k HID Headlights & Fog Lights, SS Mirrors & Gen III bumper cover, 18" 225's.
post #12 of 20 Old 09-07-2010, 10:52 PM
Yah!
post #13 of 20 Old 04-06-2013, 01:25 AM
User is: Howard1289 is offline
I recently purchased a 94 2.2L S10 as a commuting truck to keep my Z from bankrupting me in fuel. I'm almost positive i have a clogged fuel filter or a failing fuel pump (if its even possible for a pump to go out and come back to life??) It started by giving me trouble starting on day and cranking up only to die out when i shifted into drive. That was a week ago and the past few days it has only started once or twice after trying severall times throughout the day. Today it was at its worse once started i went for a test drive and it acted as if it was running out of gas i had to pump the gas pedal to keep it moving along. I know a replacement filter is a cheap fix but i just want to get your guys opinion to see if it could be something more like a fuel pump. Also im all about saving a dollar is there a way to clean out filter to get a few more months out of it? any help would be greatly appreiciated...thanks
post #14 of 20 Old 04-06-2013, 02:59 AM
AWD V8's Avatar
User is: AWD V8 is online now
A clogged fuel filter will almost certainly act the same way at all times. If your truck is hard starting sometimes, and others not, it's not the fuel filter. And once running after hard starting, if it runs strong it's not the fuel filter.
You need to have the fuel pressure checked before you guess as to what to replace.
3 year old thread
post #15 of 20 Old 04-08-2013, 05:11 PM
User is: SicOne is offline
IT IS NEVER THE FUEL FILTER IN A FUEL INJECTED VEHICLE!!! Fuel injected cars are pushing 40-45 Psi unlike carbs 5-8Psi. Unless you are dumping sand in the tank every fill up. I know it's old but people will see it and read it. The problem is not the filter
SicOne is offline
post #16 of 20 Old 04-08-2013, 06:47 PM
Better post-em.
comics22's Avatar
User is: comics22 is offline
yea filter sposta be changed like every 30 or 60K or something like that...
comics22 is offline
post #17 of 20 Old 04-09-2013, 07:10 PM
User is: ivybandit is offline
30k
post #18 of 20 Old 04-10-2013, 04:15 PM
User is: Jmk321789 is offline
Angry Re: symptoms of clogged fuel filter?
see I'm having similar problems but the fuel filter was replaced about a month ago. I also replaced the fuel pump. It ran fine for about four days. But, now it's like I'm running on two cyl instead of four.Also it sounds like something rattling around in catalytic conver. Barely touch the gas and almost no compression whatsover
post #19 of 20 Old 04-10-2013, 04:39 PM
It's "Neanderthal"
SH-60B's Avatar
The converter flow is probably blocked by the crumbled honeycomb inside, that'll choke the motor. Does it idle smooth?
SH-60B is offline
post #20 of 20 Old 04-11-2013, 02:52 AM
User is: Ed98 is offline
A completely clogged fuel filter will cause a no-start condition.
But a partially clogged filter will cause cutting out when you try to pass someone or accelerate hard.
Labor Rates: $35/Hr. If you watch: $45. If you help: $55 If you tried to fix it yourself first: $95
Ed98 is offline
