Moderator
Swapping 96-97 Cam in 98+
ASASN8
Re: Swapping 95-97 Cam in 98+
well if you look at a sealed power camshaft, there used to be 2 different numbers for 94-97 and 98-02 but now the cam number is cs1579 for the cam, and kc1567 for the cam kit with lifters and such.
Location: Terre Haute, IN / Fort Wayne, IN User is: OffLine |
94 and 95 cams are not notched for sequential fuel injection.
Sik-98
Re: Swapping 96-97 Cam in 98+
does this mean that a 96,97 cam in a 98+ motor is better than the cam it comes with?
tu-tu guru
omg, way to bring up an old post
heres the deal, 94-97 motors had a big cam with small lifters 98+ had a smaller cam with bigger lifter for "low-end tourque" |
insane asphalt ballet
so... can you use the newer lifters in the older motors? or should i just crawl back into the dark and keep whittling my custom blower cam module....
tu-tu guru
use the same year lifters, you dont need 98+ lifters
HAND MADE
I know this is an old thread but I still don't SEE the answer here. Are you guys putting the older cams in the 98+ trucks or putting the newer into older?
I'm trying to find a better cam for my 2000 so I'd like to know what's happening here. |
man it is a old thread back from the dead
. i don't think they are inerchangeable beacause the notches on the crank are in different places, and your timing will be off or sumthin' like that. from what i've seen and read the only thing u can do is have a regrind done on ur factory cam. |
HAND MADE
ok thanks, was just checking to see if there was something I wasn't seeing.
tu-tu guru
no, 96-97 cams are notched in the same place as 98+ cams
the cam specs are what different |
oh, ok. i wasn't sure, but i knew sumthin' was different between them
ados egnaro
Location: Floyds Knobs/Clarksville, IN User is: OffLine |
wow this is an old thread. but man thats cool ill have to watch and find a cam out of a 94-97 engine.
tu-tu guru
94-95 werent notched |
Happy with ugly truck
I still haven't seen anyone say "96-97 cam will give you power". How much power?
ados egnaro
ah, ok ill have to look for that then, that could have potentialy cost me money, thanks man.
tu-tu guru
id assume id be like a small cam....maybe 5hp
HAND MADE
OK, so that's the mod, a 96-97 cam in my 2000 correct?
tu-tu guru
yep
Laying hard on zq8s!
may have already been covered... but - would the 96-97 cam add more power than getting a regrind done?
it depends on what you had done to your stock cam
it wont make more power than a regrind. its basically a very small hp increase. its not worth it unless your engine was taken apart and you happened to have a 96-97 cam sitting in your lap. otherwise the cost/labor involved makes it not worth it at all.
Moderator
its been done but I don't recall the member that did it and said it was well worth the difference. Best to do when you have motor out than to do this mod ONLY
#24 |
HAND MADE
Well my motor is completely apart and a stock GM cam for the 96-97 is easy to come by so I may be going ahead and ordering one.
Thanks for clearing this up for me guys. |
#25 |
so what cam will give a 95 more power?
#26 |
tu-tu guru
a custom one
#27 |
so basically another useless thread take it off the performance sticky jeeezus
