strange sound from fan area
Old 07-02-2009, 08:35 PM   #1
Ok so the truck is still running perfect, except for a strange sound that started out of the blue. It's like a loud whirring sounds that gets louder with engine speed. I'm not sure you can even hear it. But up higher in the rev range it's fairly loud. I think I'm maybe even hearing some light metal sounds as well. Is my fan done? Anyone?
Old 07-02-2009, 09:26 PM   #2
Re: strange sound from fan area
ok after doing a search I think it's probably the fan clutch. Should I be able to turn the fan by hand when the engine is off? because I can't.
Old 07-02-2009, 09:59 PM   #3
Sounds like a roar when the clutch is stuck and it gets really loud when first driving off.
Old 07-02-2009, 10:05 PM   #4
yup, that's it.
Old 07-03-2009, 04:11 PM   #5
Just turned 18
x2 on your fan clutch being shot. You should be able to turn it with the truck being off and cool.
Old 07-03-2009, 06:04 PM   #6
my 95 makes the same noise that your describing, when i take off from a stop the thing sounds like a transport. gets worse in higher rpms, i have a glass pack muffler and the noise is way louder than it but my fan spins fine when the truck is not running. i plan on putting in an e fan and a set of underdrive pulleys soon.
Old 07-14-2009, 03:04 AM   #7
I have the same sound but its off and on i can drive fine one day next it makes noise till it seems engine warms up and it stops?
I have a automatic do i have a fan clutch, im 17 this is my first car....
Old 07-14-2009, 10:35 PM   #8
Has Training Wheels
beaniebmx's Avatar
my 00 jimmy did the same, sounded like a jet taking off for a second or two then it went away.
parents blazer was the same when that had low miles on it
i just took that peice of junk off and replaced it with an electric fan.
i have a 2.2 so i got a 2.2 cavy fan and it stays the same temp and cools pretty good for the $20 i spent
Page generated in 0.57015 seconds with 31 queries
[Output: 61.74 Kb. compressed to 58.06 Kb. by saving 3.67 Kb. (5.95%)]
