starter wont click or turn or anything
was workiing fine. till my tire rubbed the casing off some wires going into the ecm.. i seperated all the wires and it started fine, then one touched again and it freaked out when i tried starting it.. now i cant even get a click out of the starter.. ive tried cleaning all connections EXCEPT the actual starter and fuses and relays. everything.. when i turn the key nothin happens.. HELP PLZ?
joining 2.2l boosted club
Re: starter wont click or turn or anything
may of fried ur ecu unit when the wires touched...and since it touched u may have blown a fuse that relays to ur starter or starting process...check all ur fuses first!
check your altornator wires. Mine had the same problem and i took it to the mechanic and he said my alternator wires had burnt some how!!!
Moderator
Check the fuse and relays. Which wire was it that freaked out?
