n00b
Spark plug install
Hi, I went to autozone and got some NGK platinum spark plugs for my 01 S10. It's got 192K on it and the plugs haven't been replaced for a while now..Do I gap them at .040 or no? And what's the easiest way to take out the old plugs? I was maybe thyinking take off the air box that says 2200 or take off the belt and A/C compressor?
Any help is appreciated. Thanks, Nathan |
n00b
Re: Spark plug install
4 wheels aren't as fun
do what the sticker under the hood says. I do believe it says .060.
n00b
oh ok thank u..i just broke a wire trying to pull out the rubber part so it looks like we r gonna rerplace the wires too..this is a big PITA good thing my dad is a gearhead.
n00b
Ok went and got the wires and a feeler guage. It says gap them at .040. We are installing the plugs right now then doing the wires.
My Haynes Man. Says .040 But check the rad housing it should have a sticker with the correct gap.
n00b
I have no idea what happened but my SES light was on. I opened up the hood and one of the boot things was lose. Put it back on and now the SES light is still on??? What happened? I undid the positive on the battery for a min but it's still on? It's still running PERFECTLY so idk if it's just being dumb or if something is really messed up.
workin it !
something's ( SES light )that are not serious will clear after three restarts w/problem corrected
n00b
I just unplugged the positive part of the battery for 10 minutes and started it now the SES light is off! Runs better. Now I just need to replace the fuel filter and i'll be good to go.
O'Reilly R.S.S
Were these NGK plugs on sale?
n00b
^I'm not sure but they were $3.99 each. Or maybe $2.99 but i'm pretty sure it was $3.99. My dad uses NGK plugs in his cobra so we know they are good.
O'Reilly R.S.S
NGK is a good brand but like anything their not universal.
At work I sell plugs by OEM application. GM vehicles - AC Delco Ford - Motorcraft Nissan - NGK VW, Audi, Mercedes (any european) - Bosch Dodge, Chrysler - Champion Toyota - I send them to Autozone for Denso. I don't know why my company doesn't carry them. Autolite - for cheap people or older cars that we can't figure out what they used originally. Their not a bad brand but their not universal. Using OEM type plugs helps maintain OEM type gas mileage. Unless you add a turbo or supercharger, OEM plugs and ignition systems will work great. The NGK's shouldn't give you any problems. If something does get screwy, ACDelco platinums will be your best bet. |
GM also uses NGK
IMO Champion plugs are ONLY good for Poulan products, in everything else I regard them as trash/paperweights. I'm an NGK and Denso guy. best plugs on the market for use in 99% of vehicles. I run em in my bike, will be in my truck, and PROBABLY the samurai I'm lookin at.
Loves The MPG
i put NGK v-power plugs and i love them
n00b
^I'm not 100% sure but I think mine are G-power. Are the V-power plugs platinum?
REDFIRE
I Stand by NTI06's Statement 100%!
REDFIRE
No AC-Delco part has ever failed on me!
How did the old plugs look once you pull them out?
Just curious, I let mine go way over they didn't look too good. |
n00b
They were mostly black at the bottom part by the threads (pretty gross). I HIGHLY recommend getting compressed air and blow down where the plugs are to get out all the dirt before you do anything. You don't want anything falling down into the engine.
Also when you are routing the new plug wires through the engine bay, I twisted some metal wire around the rubber part that goes onto the cap so I can feed the metal wire down to someone then they can pull the wire down to get the actual rubber wire. Makes it SO much easier. |
Changing the wires for the first time on it were tricky but once you figure it out it can be really easy.
#24 |
Drive it like ya stole it
#25 |
n00b
#26 |
Loves The MPG
#27 |
Moderator
I agree wit AC Delco plugs and wires.
However, MSD(8.5, not 10.2) and Taylor wires are good as well. I've used both and it was as good as Delco, just nicer looking and a bit bigger. |
