Seafoam Ruined My Engine?? - S-10 Forum
post #1 of 60 Old 07-06-2008, 03:00 AM Thread Starter
Valued Customer
eatdogmeat's Avatar
User is: eatdogmeat is offline
Hey everyone! I have a question. My truck just hit 90k and about 150 miles before I changed my oil, I threw a little SeaFoam in the crankcase. Immediately after changing my oil, I developed a knock at idle and at light acceleration (~2000-2500RPMs). Could the SeaFoam have possibly washed out my bearings and caused my motor to end up in a horrible sad state, or could it have possibly loosened up some carbon and sludge inside that just needs to be "worked out?" Ever since I developed the knock, I stopped using my S-10 as my daily. I drive it once a week to work which is a 12 mile drive each way. Tonight when I got home, the knocking stopped. I am totally confused. Does anyone have any insight? My 2.2 has always had her oil changed at ~3000 by both myself and her previous owner. I'm totally confused!
2000 S-10 2.2L 5spd 3/3
post #2 of 60 Old 07-06-2008, 03:18 AM
square body newbie
Derek1387's Avatar
User is: Derek1387 is offline
Send a message via AIM to Derek1387 Send a message via MSN to Derek1387 Send a message via Yahoo to Derek1387
Re: Seafoam Ruined My Engine??
seafoam made my truck run like a top.... so i dunno man...
90 Reg Cab S10-SD 5 link, SD arms, daily dragger
PROJECT THREAD!
post #3 of 60 Old 07-06-2008, 03:33 AM
Adapt And Overcome!
Jadesmarine's Avatar
User is: Jadesmarine is offline
Send a message via Yahoo to Jadesmarine
i doubt seafoam messed anything up. if anything i bet it clean some nasty parts!!!! if you worried change your oil again and use thicker oil get rid of noise
post #4 of 60 Old 07-06-2008, 05:00 AM
Better post-em.
comics22's Avatar
User is: comics22 is offline
how much seafoam did you put in? shoulda only been a 1/3 or less of the can...
comics22 is offline
post #5 of 60 Old 07-06-2008, 05:40 AM
AcrophobiA
layinlow88's Avatar
User is: layinlow88 is offline
lets think logically...since sea foam is apparently a god around here
yes....sea foam cleans....but wait....where does all the crap go?? it just doesn't magically leave the engine...most of the time it will sit in the bottom of the oil pan....but yes...it can wash out bearings and the oil pump can def suck some of that crap up and clog it
i have seen a few engines ruined b/c of the stuff.....altho i have used it to clean injectors or anything that will allow the stuff to be burned and pushed ouf of the engine....you wont catch me putting it in the crankcase....sure people do it all the time....but...its not a cure all in a can...it can ruin things
if your engine knocks or ticks...the only REAL way to fix it is to replace the problem
EDIT: ok that came off kinda harsh....wasn't meaning to be...just trying to put a point across..lol
Get With it,
Brandt
post #6 of 60 Old 07-06-2008, 10:08 AM
damned 4banger
Noremac's Avatar
User is: Noremac is offline
Send a message via MSN to Noremac Send a message via Yahoo to Noremac
i ran it through my truck, 1/3 in gas tank, 1/3 in vacuum line, and 1/3 in crankcase... mine ran great afterwards...
btw, i ran seafoam through it at around 115,000 miles.. i am 124xxx miles now...
2001 pewter s10 2.2L 5 speed. (SOLD)
2006 Dodge Magnum SRT8
Noremac is offline
post #7 of 60 Old 07-06-2008, 01:15 PM
Better post-em.
comics22's Avatar
heck i just did it to my truck for the 3rd time in the crankcase at 142k miles.
i dump it in then drive it around (like 20 miles) then come back, pull up on the ramps and then change the oil while its hot so whatever was broken loose didnt have time to stick or settle to the bottom of the pan.
comics22 is offline
post #8 of 60 Old 07-06-2008, 06:20 PM
Jonny_00's Avatar
User is: Jonny_00 is offline
its not meant as an additive.......... your supposed to pour it in,,,run it ,,, then drain it,,
its not meant to be left in the engine
Jonny_00 is offline
post #9 of 60 Old 07-06-2008, 06:28 PM
AKA DavidAndSomeNumbers
David12460's Avatar
User is: David12460 is offline
How much did you put in the crankcase?
2003 S10 Ext Cab ZQ8 - SOLD
2000 S10 Reg cab- SOLD
post #10 of 60 Old 07-07-2008, 02:15 AM Thread Starter
Valued Customer
eatdogmeat's Avatar
I put 1/3 of the bottle, ran the truck for ~150 miles and then changed the oil. The knock started right after I changed the oil. I don't get it. I always made sure the oil was changed at 3000. Oh well. Update. The knocking started again so I'm at a loss. It sounds like someone shaking marbles in a glass half full of water. It's hard to describe. It honestly doesn't sound like rod knock or a bearing noise, but I don't know what else to think. I know if I take it to a mechanic they're going to try to put one in my pooper.
post #11 of 60 Old 07-07-2008, 04:33 AM
Currently Spoolin
702s10's Avatar
User is: 702s10 is offline
Send a message via AIM to 702s10
I think 150 miles was a little too long to have it in there. From what I've read somewhere on here it breaks the oil down quick..
2000 s10 5 speed - 2003 2.2 bored .050,Mahle pistons,Eagle H-beam rods,Garrett GT3071R turbo .63 TiAL SS 3" Vband hotside,ported compressor housing 4" inlet,2.5" outlet,TiAL MVS WG,TiAL Q BOV,BEGI FMU,Siemens 80# injectors,Treadstone TR8 Intercooler,Vibrant filter,Full 3" exhaust,Aero Turbine muffler,Spec Stage3+ clutch,Hurst shifter,ASP pullies,FlexALite efan,Aeromotive A750 Fuel Pump
702s10 is offline
post #12 of 60 Old 07-07-2008, 07:33 AM
Registered Abuser
Merritt's Avatar
User is: Merritt is offline
i wouldn't put seafoam in the crankcase just for that reason, i've run it in the brake booster and gas tank, but i'm a little weary of pouring it in my oil
-James
2006 Time Magazine Person of the Year
Merritt is offline
post #13 of 60 Old 07-07-2008, 07:50 AM
Currently Spoolin
702s10's Avatar
x2
702s10 is offline
post #14 of 60 Old 07-07-2008, 11:27 AM
WFO2.2's Avatar
User is: WFO2.2 is offline
You ran it too long, that's most likely what caused the problem. Get someone with a trained ear (someone you trust) to listen to it and go from there
WFO2.2 is offline
post #15 of 60 Old 07-07-2008, 11:33 AM
cevtv's Avatar
User is: cevtv is offline
That's brilliant.......
cevtv is offline
post #16 of 60 Old 07-07-2008, 01:12 PM
jhankinson's Avatar
User is: jhankinson is offline
Also I have seen it make lifters stick...causing them to tap loud. When you added the Seafoam for 150miles you can break down the oil enough to cause issues with hydraulic lifters. If they free themself the tap/knock will stop. So it could be minimal...but never the less...I would get someone trained to look at it. I have used Seafoam in dozens of vehicles, but i never run it linger than about 40 miles in the crankcase. Then change as soon as I stop.
1994 S10 - was a 2.2l 5sp terd...now is LS1 4l60e with 8.5/Detroit Tru-trac disk brake rear, ZQ8 suspension, tore down to the frame and rebuilt.
PICS AND VIDS HERE
post #17 of 60 Old 07-07-2008, 02:41 PM
User is: ride and destroy is offline
i had this same issue. i was told by my mechanic to run the seafoam in my oil for 500 kilometers. i just had to get my crankshaft reground and get new bearings. had to go 30/60 on my rods/mains. im wondering if this was the issue
Originally Posted by 442typhoondude View Post
The stereo sounds like my ass after a binge at a burrito bar too.
post #18 of 60 Old 07-07-2008, 02:57 PM
White trash minitrucker
User is: Jake is offline
I am not a fan of using anything in the crankcase other than oil. I have seen stuff like seafoam wash the cylinder walls after someone left it in for a week instead of draining the oil after 5 min like your supposed to. The end result was that he lost compression in not one but two cylinders. So yes it will clean, but use it responsibly.
1997 Regular cab 2.2l 5spd Project truck/daily driver
1997 Extended cab 2.2l 5spd beater/backup truck
1983 K5 blazer 350 4spd Love of my life.
Originally Posted by K Dawg ONE View Post
you broke the interweb!
Jake is offline
post #19 of 60 Old 07-08-2008, 12:03 AM
Forum Dictator
What?'s Avatar
User is: What? is offline
Too long imo, I never had it over 50miles(3days)
Is this knocking coming from TOP of motor or BOTTOM of motor, it makes a difference
Other than that, have good mechanic to inspect for you if you cannot figure out
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #20 of 60 Old 07-08-2008, 12:20 AM
NOBAMA NOBAMA
96Dropped-dime's Avatar
User is: 96Dropped-dime is offline
run some marvel mystery oil or lucas oil additive and see it stops
post #21 of 60 Old 07-08-2008, 12:25 AM
Useless posting member
Wrkn prgs's Avatar
User is: Wrkn prgs is offline
Send a message via AIM to Wrkn prgs Send a message via MSN to Wrkn prgs Send a message via Yahoo to Wrkn prgs
Lucas will stop it.. until you stop using it.
post #22 of 60 Old 07-09-2008, 01:22 AM Thread Starter
Valued Customer
eatdogmeat's Avatar
Definitely coming from the bottom of the motor. I just find it odd that it will be there one day and will disappear the next. It happens between 2000 and 2500 RPM's. I'm taking it in to a mechanic this week. If I get bad news, I'll just add Lucas and drive the car until it explodes.
post #23 of 60 Old 07-09-2008, 01:27 AM
where's my chippy?
lee-mill's Avatar
User is: lee-mill is offline
Send a message via AIM to lee-mill
x3
lee-mill is offline
post #24 of 60 Old 07-09-2008, 10:13 PM
Forum Dictator
What?'s Avatar
does it do it in neutral as well?
What? is offline
post #25 of 60 Old 07-09-2008, 11:44 PM Thread Starter
Valued Customer
eatdogmeat's Avatar
No it doesn't, which is why I am totally confused. I keep thinking cat, but my gut says bottom end.
post #26 of 60 Old 07-10-2008, 02:16 AM
Better post-em.
comics22's Avatar
hmm could he have broken up enough intake stuff to have clogged the cat? maybe the severe vibrations of half stallign the engine with seafoam rattled somehting loose...
comics22 is offline
post #27 of 60 Old 07-10-2008, 02:22 AM
AcrophobiA
layinlow88's Avatar
glad other people agree that seafoam is not a magic cureall in a can
Get With it,
Brandt
post #28 of 60 Old 07-10-2008, 02:28 AM
jeffery_843's Avatar
User is: jeffery_843 is offline
if it was the cat, it would still do it in neutral.
Originally Posted by 2Lo4aFatHoe View Post
cause putting a ford part on a chevy is like having sex with a fat chick. sure, you got your jollies off and she did the job.....but you don't want to go telling your friends what happened.
post #29 of 60 Old 07-10-2008, 03:37 AM
User is: Matt80539 is offline
IMO the fact that it doesn't do it in neutral means nothing. Problems are typically more obvious when there is a load on the engine.
post #30 of 60 Old 07-10-2008, 12:58 PM
thats a good point
post #31 of 60 Old 07-10-2008, 01:21 PM
User is: grillen85 is offline
I know aton of the lt1/ls1 guys run it .. an in fact for the amount of time you left it in , it could have gotten into a lifter a collapsed a lifter by breaking down the oil . I wouldnt think it to be a rod knock with it comming a going . I would say more like piston slap from cylinder wash .That would explain the comming an going of the noise to ..
Thats just my .02
post #32 of 60 Old 07-10-2008, 04:03 PM
Forum Dictator
What?'s Avatar
load or no load, the engine still can make problem with or without neutral
have someone go under the truck and check the noise specifically whether more toward engine or tranny/exhaust
What? is offline
post #33 of 60 Old 07-10-2008, 09:25 PM
User is: Stache is offline
.... and use thicker oil get rid of noise
Also there is a little knob on the left side of the radio that when turned clockwise seems to make bad sounds disappear.
Stache is offline
post #34 of 60 Old 07-11-2008, 02:16 AM
00' S10 Owner
Sandite5's Avatar
User is: Sandite5 is offline
Is it sad that sometimes I turn the radio up loud because I'm afraid if I turn it down, I'll hear something bad?
Sandite5 is offline
post #35 of 60 Old 07-11-2008, 03:03 AM
Sucker for Blondes
Bmanxer's Avatar
User is: Bmanxer is offline
I'm guilty
'91 Regular Cab ShortBox DO WORK SON!
Quote: Originally Posted by lance_martz
When two trucks pull up to an intersection, all pneumatic hell can break loose.
I'll remember that phrase forever
Quote: Originally posted by Vox:
Find a girl that adores you for you, not that sexy ass truck or that big ol' dick of yours.
Bmanxer is offline
post #36 of 60 Old 05-30-2010, 11:34 PM
User is: tuckster14 is offline
I was just wondering what the mechanic said when you took it to them....I am having the same exact problem now due to seafoam. Thanks
post #37 of 60 Old 05-30-2010, 11:45 PM
4 wheels aren't as fun
serpentracer's Avatar
User is: serpentracer is offline
probably thinking do it again, I need the extra money
my advise is never put any "cleaners" in a crankcase. that includes that motor flush garbage.
02 sonoma 4.3L auto
97 sonoma 2.2L manual
post #38 of 60 Old 05-31-2010, 12:15 AM
Ford guy stuck w/ chebby
n8rsk8r's Avatar
User is: n8rsk8r is offline
in the future drain a quart of oil (before changing it) and add a quart of ATF fluid into your crankcase. Run the engine for 15-20 min and shut off, change the oil. It will do the cleaning and a lot more safely. I have done this in my mustang and sho for years, I learned it while working at Jiffy Lube back in the day.
1999 2WD Automatic S10 standard cab.
I have nearly rebuilt this damn truck 100%!!
n8rsk8r is offline
post #39 of 60 Old 05-31-2010, 01:41 AM
Forum Dictator
What?'s Avatar
Almost 2 years old thread, way to go!
Once again, you need to understand that oil pumps through fast, it really isn't needed to be in engine long. 5 minute of it idling is good enough, dump it completely and do another oil change.
What? is offline
post #40 of 60 Old 05-31-2010, 02:29 AM
n8rsk8r's Avatar
I hear you on the shit chevy engine. On my 3rd in just 250K
n8rsk8r is offline
post #41 of 60 Old 05-31-2010, 12:50 PM
Registered Un-dependent
Mechnix's Avatar
User is: Mechnix is offline
SeaFoam...snake oil... There us always somebody that has some product that can cure something chronic...but only lightens your wallet at best, at worst ...
Mechnix is offline
post #42 of 60 Old 05-31-2010, 04:03 PM
I put the seafoam in thru the vacuum line that goes to the break booster, the next day it started knocking. I changed the oil and it still continues to do it. It only happens when the motor winds up right before i shift, its def not a rod, Im thinking it might be a lifter with sum crud on it making it not seal........
any advice?
post #43 of 60 Old 05-31-2010, 04:11 PM
Truckin_S_10's Avatar
User is: Truckin_S_10 is offline
It's not a silver bullet.. but I know first hand it solves some problems. I failed an emissions test, found out about seafoam on here, ran some through a vaccum line, enjoyed the smoke display, went back 2 days later to the same garage for a second etest, and passed with flying colours. I failed on Nitrous Oxides--seafoam drastically lowered my NOx score. I don't recall it doing much for the other gasses, but those wern't out of line to begin with.
post #44 of 60 Old 05-31-2010, 04:25 PM
User is: jc71corvette is offline
I never put seafoam in my crankcase untill my recent oil change. I changed the oil after 50 miles.
Is fine now
post #45 of 60 Old 05-31-2010, 08:46 PM
Forum Dictator
What?'s Avatar
any advice?
How much did you put it through?
What? is offline
post #46 of 60 Old 06-01-2010, 01:01 PM
bout a 3rd of a can like everyone says to...
post #47 of 60 Old 06-01-2010, 07:04 PM
I don't understand what is going on....I pulled out two of the spark plugs and changed them and they needed it badly. I couldn't get the other two out, gunna have to wait to get to my gradpa's shop since i don't wanna strip the threads out of the head and not be able to re-thread them. It only knocks when the motor winds up right before the shift and when its between 2200 to 2700 rpm, usually when i give it a lil bit of gas it goes away. I have no clue what is going on.....
Any advice anyone?
post #48 of 60 Old 06-01-2010, 08:26 PM
alright well its gotten worse alot worse now....Im just not going to drive it i guess until i can figure out whats going on. Its gone from a lil knock when it winds up to what sounds pretty close to a rod knock now, F**k seafoam
post #49 of 60 Old 06-01-2010, 09:45 PM
your rod bearing is spun my friend.
mine didn't knock until I revved the engine up. (it didn't do it at idle)
http://www.youtube.com/user/blue03r6#p/u/7/1NPAWF420UQ
don't keep driving it. if you buy a rebuilt engine the core for your old one is about $500. you won't get it back if you put the rod through the block.
02 sonoma 4.3L auto
post #50 of 60 Old 06-01-2010, 09:59 PM
A CLEANMACHINE's Avatar
User is: A CLEANMACHINE is offline
Send a message via Yahoo to A CLEANMACHINE
it says it's 100%petroleum product,safe in crankcase,doesn't have a time factor.i had a sticky lifter put it in a few months ago in synthetic and so far no problem.the advertised rate to add is 1 1/2 oz per quart.
99 ext cab auto, 7psi mitsu 14b turbo,ported and coated 2 1/2'' exhaust to turbo muffler,fake cat,underdrive pulley,efan,2.3 t/b,42lb racetronix inj,4.3 fuelpump,aem wideband,pyrometer,f/press guage,.lowered rear 2'',hhr seat , counsole,and finished fabbed cowl hood.
