S10 98 - no Idle - S-10 Forum
post #1 of 7 Old 04-19-2017, 10:58 AM Thread Starter
User is: sirdan is offline
S10 98 - no Idle
Hi everyone
I've got no more idle on my truck, There's 270,000 km, all the engine is ok but don't have any idle anymore. I checked the IAC valve, removed it and cleaned it but still don't have any idle, any suggestions?
sirdan is offline
post #2 of 7 Old 04-19-2017, 11:31 AM
oldeerslayer's Avatar
User is: oldeerslayer is online now
Re: S10 98 - no Idle
Any DTC's? Done a fuel pressure and engine vacuum check?
post #3 of 7 Old 04-19-2017, 07:36 PM Thread Starter
Hi Oldeer
DTC?
Engine vacuum check? What do I need to do that?
sirdan is offline
post #4 of 7 Old 04-19-2017, 09:45 PM
TakeiT's Avatar
User is: TakeiT is offline
battery loose?
I ain't as good as I once was, but I'm as good once, as I ever was.
TakeiT is offline
post #5 of 7 Old 04-20-2017, 12:00 AM
He's right, it wouldn't hurt to make sure the battery cables are clean and tight.
Diagnostic Trouble Code. If your service engine light is on that means that a DTC has been set. You need a cheap scanner to read engine codes.
All you need to check engine vacuum is a vacuum gauge. Just unplug the vacuum line running to your heater controls off the engine and plug the gauge into the line. Some even have a tee in them depending on accessories. Gauge should read 16-20 inches at idle and steady. If you have to hold it slightly above idle to keep it running the numbers will go down a bit, but still be steady. I'm looking for a vacuum leak here. That will kill an engine at idle, but should also set a bunch of DTC's. Check to be sure all hoses off the engine aren't off, loose or cracked. I often forget the one on the back of the air duct above the throttle body on 4.3's. That one isn't a vacuum hose but will throw the ecm in to convulsions because a bunch of air is entering after the MAF.
Look right behind the ABS module at the vacuum lines in that area. Those hoses tend to crack and come loose. Especially at the mileage yours has.
Cleaning the IAC won't help if it's electronics took a dump, but they are usually pretty reliable.
There are many possibilities for your problem, but this should get you started. Is yours a 4 or 6?
post #6 of 7 Old 04-20-2017, 10:09 AM Thread Starter
Originally Posted by TakeiT View Post
battery loose?
It's the first thing I have checked, there's was rust at the end of the ground cable, cleaned it and the problem not solved.
sirdan is offline
post #7 of 7 Old 04-20-2017, 10:16 AM Thread Starter
I have ordered a new IAC valve, I'm gonna change it and look to buy a scanner.
Thank you folks. I'll come back later to let you feed back.
sirdan is offline
