Revised List of Performance Parts *Look Before Posting*
LinkBack (2) Thread Tools
Old 02-06-2004, 01:52 PM   2 links from elsewhere to this Post. Click to view. #1
Zq-8_dawg's Avatar
Post [B]*LOOK BEFORE POSTING!* Revised List of Performance Parts[/B]
This is a pretty complete list of performance modifications for the 2.2L engine.
Please if you have anything to add send Moderators/Forum Director a PM
Other good links for engine information:
http://www.tomorrowstechnician.com/tt/tt30216.htm
http://www.ny-jbodies.org/
Cavalier and S10 2.2(not 2.4 Cavalier) are similar in some parts
Pistons, Rods, Camshaft, Roller Rockers/Studs, Crankshaft, Ignition Coils
Air Intake Modifications:
Air Intake Kit:
K&N *
Volant *
AEM *
STS Performance
Hot Shot
APC
Weapon-R
Home Made
TYPE HOMEMADE, HOME MADE INTAKE to find homemade intake thread, much cheaper to buy ebay intake from Store ChromeIntakes
Drop in Air Filter:
K&N Drop-In Performance Air Filter(Not necessarily worth to buy, better off buying ChromeIntake intake on ebay
Throttle Body:
56mm 2.3L GM Quad 4 (early 90’s available at most junkyards) fit for 98+
59mm RSM Racing
62mm RSM Racing
www.RSMRacing.com
Local Machinst Shop, be sure to investigate and check with other local members that has used the shop so you do not get ripped off
94-97 STS performance
98+ STS performance
http://www.stsperformance.com/produc...otherperf.html
(for discount from STS performance, contact Jay and inform him you are from s10forum, he will give you discounts, email address: Jay@sportruckspecialties.com )
Throttle Body Spacer: Helix Power Tower, Etc. NO GAINS, gives whistle sound, Dont Buy Dont Ask Why
Exhaust Modifications:
Cat Back:
Gibson
Magnaflow
Custom Exhaust
Header:
Al’s Header Al's Headers
2831 E White Star Ave Ste E
Anaheim, CA 92806-2520
Phone: 800-875-2112
Kamikaze http://kamikazeperformance.com/
www.bigjoshracing.com
Pacesetter(good fitting for 94-97, highly recommend ceramic coating)
(poor fitting for 98-2003 but still able to bolt on, will have bad flow due to inaccurate exhaust port hole to motor)
If using black paint header, its RECOMMEND to put header wrap to reduce heat in the header surrounding to protect wires and cables from melting)
ALSO have to add longer wire to o2 sensor since its short by 6"
High Flow Cat:
CATCO Catalytic Converter
Magnaflow Cataltic Converter
CARSOUND Direct Fit, OBDII High-Flow Catalytic Converter http://www.truckperformance.com/prod...ions/sf5_2.2l/
Oxygen Simulator:
Casper Electronics
Part Number part number 104046
https://www.casperselectronics.com/M...ateg ory_Code
Performance Chip:
HPTuners www.hptuners.com (97-00 Only)
www.wait4meperformance.com
Super Chips (94-95 Only) www.superchips.com
ASE CHIPS www.asechips.com(more information available when contact them through email/phone)
These are highly untested and unrated for the 2.2. Though they say it add how ever much power it has been tested by many menbers and deemed a waste.
Jet Chip Stage 1
Jet Chip Stage 2 (requires 180* thermostat and premium fuel)
Venom 400
Drive Line:
Center Force Clutch AVAILABLE FOR 96-03 http://www.centerforce.com/clutches....ion=clutche s
Lightweight Flywheel (Fidanza
Posi Trac Unit (Zexel, Ect.)
B&M Short Shifter
Hurst Short Shifter
Corvette Servo (auto trans only)
Leaf Spring Clamps (helps with traction)
Hop Shock (helps with traction)
__________________________________________________ ______________________
Electric Fan:
Flex-A-Lite "Black Magic" FLX-60
Taurus, Camaro, (many other E-fans also work well)
Universal Adjustable Thermostat for E-fan
Look into E-fan mod in this following link http://www.s10forum.com/forum/f105/electric-fan-116754/
Ignition:
MSD DIS-2 Ignition Box
ACCEL DIS Super Coils
MSD DIS Coils
Jacobs Coils
Taylor Wires
Magnacore Wires
Vitek Wires
Fire Power www.performancedistributors.com/s10ignition.htm
Accel 300+ Ferro-Spiral ThunderSport Wires
Cylinder Head:
http://www.headsonly.com/
Port and Polish http://sites.reachtheworld.tv/waterN...05242&DID=1225
Stainless Steel Valves
Full Roller Rockers (1.6 ratio)
You can find these at www.howellautomotive.com
Engine Internals:
Cyro: http://www.s10forum.com/forum/showth...highlight=Cyro
Pistons
Clevite Rod and Main Bearings
Eagle Forges Rods
Pushrods
Camshaft
www.mantapart.com
Pulleys:
ASP Power Crank Pulley www.aspracing.com www.truckperformance.com
(dealership)
Ask for belt of your make, model, year, 2.2L and request it this length
Without A/C 61"
With A/C 75"
IF YOU HAVE ALTERNATOR PULLEY, USE SAME NUMBER BUT REQUEST 1" SHORTER FOR PROPER LENGTH(On both with and without A/C)
STS Performance www.stsperformance.com
With A/C AND Alternator Pulley Goodyear Gatorback Poly-V belt #'s are 4060715 6PK1815.
With A/C NO Alternator Pulley, get same number but ask for 1" shorter for proper length
Without A/C, minus 14"
Turbo and Supercharging:
http://www.s10forum.com/forum/f105/turbo-f-a-q-128219/
__________________________________________________ _______________________
Nitrous:
NX GM Universal Kit
www.nitrousoutlet.com
www.nitrousdirect.com
www.harrisspeedworks.com
__________________________________________________ ________________________
Fuel System:
Adjustable Fuel Pressure Regulator
Brakes:
Rotors
Pads
Brake Line
Complete Brake Kit
You can find them at
Alternator/Stater
www.nationsautoelectric.com/
www.mralternator.com
www.hoalternators.com
www.DBElectrical.com
www.wai-wetherill.com/products/sresultv.cfm
Sites to find most of these parts listed above
www.jtuners.com/
www.jbodyperformance.com
www.cavalierconnection.com
www.mantapart.com
www.ebay.com
www.RSMRacing.com
COMPLETE EVERY LISTING PART FROM SUMMIT RACING AVAILABLE FOR 2.2(this is set at year 1998, if you have a different year, please change the year)
http://store.summitracing.com/defaul...+-59827+-42619 be sure to add in your year
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f105/revised-list-of-performance-parts-look-before-posting-88841/
Posted By For Type Date
Speed Equipment for 95 4-cyl engine??? - The Forums at Chevy Talk This thread Refback 12-24-2007 07:45 PM
S-10 2.5 L engines...speed equipment??? - The Forums at Chevy Talk This thread Refback 12-24-2007 07:42 AM
Page generated in 0.62049 seconds with 31 queries
[Output: 55.45 Kb. compressed to 54.11 Kb. by saving 1.34 Kb. (2.43%)]
