replacing starter - S-10 Forum
post #1 of 14 Old 07-16-2009, 12:53 PM Thread Starter
User is: xXs10Xx is offline
replacing starter
how hard is it to change the starter in a 99 s10 with a 2.2?
i hear its a real PITA.
if you have any tips let me know thanks
xXs10Xx is offline
post #2 of 14 Old 07-16-2009, 12:56 PM
User is: beedle4 is offline
Re: replacing starter
eazy
dont let it smack ya in the face when un-bolting it...
beedle4 is offline
post #3 of 14 Old 07-16-2009, 12:57 PM
And disconnect the battery!
beedle4 is offline
post #4 of 14 Old 07-16-2009, 01:11 PM Thread Starter
i read that you have to unbolt the exhaust to get it out. this true?
i know that the trans to engine brace has to come out tho. its two bolts and the elec. connections right? any other tips or advice would be great.
xXs10Xx is offline
post #5 of 14 Old 07-16-2009, 01:14 PM
where's my chippy?
lee-mill's Avatar
User is: lee-mill is offline
Send a message via AIM to lee-mill
yea deff make sure your holding that thing when the last bolt holding it in comes out, i forgot to and boom starter to the forehead
lee
95 subaru svx
lee-mill is offline
post #6 of 14 Old 07-16-2009, 02:06 PM
When I did mine I did not touch the exhaust.
But yeah I think one of those round supports has to be swng out of the way.
beedle4 is offline
post #7 of 14 Old 07-16-2009, 02:20 PM
Local Tech
ls1s10onair's Avatar
User is: ls1s10onair is offline
i have lifts, but it only takes me 5 min.... never moved the exhaust, or anything else for that fact.
98 ext. cab- AES 390 LSX/T56, cpw longtube headers, c.a.i, trick flow 220cc heads, comp cam, Magnuson TVS2300 blower @ 16lbs, Snow Performance Meth Injection, custom exhaust, 4.10's
2014 Lexus IS350 F-Sport
post #8 of 14 Old 07-16-2009, 03:05 PM Thread Starter
the reason i ask is this.
i got a 99 s10 with 2.2 and 5speed
i notice when its hot out like the last 3 days (90+)
when i leave my house in the am when its cool.
drive to a place and have to start my truck again
when its starts i sometimes hear the starter grinding very slightly as it starts up. this will only happen when i drive to a place and start the truck shortly after. but if i sits a few hours it will start fine with no grinding.
my uncle thinks that it may be the starter but i want to make sure before i throw 130 bux to 180 for a starter and then i still have this problem.
what do you guys think is causing this?
xXs10Xx is offline
post #9 of 14 Old 07-16-2009, 09:29 PM
OCP
User is: OCP is offline
My truck is a 98 with the 2.2 and 5 speed. It was a BITCH but I got it done without removing the exhaust. I had to unbolt mine and let it kinda hang in there and unbolt the battery cable with a long extension and a universal socket. GOOD LUCK
OCP is offline
post #10 of 14 Old 10-29-2009, 03:24 PM
nemesis8's Avatar
User is: nemesis8 is offline
i cant get it out. i unbolted the exhaust, all bolts and cables and even unbolted the motor mounts to lift the motor and still no luck!
its barely still in the bell housing and hits the motor mount i cant move it for shit!
98 GMC Sierra ext. cab-Bagged and dragged
05 350z touring
nemesis8 is offline
post #11 of 14 Old 10-29-2009, 06:59 PM Thread Starter
it took me all of 5 minutes to get it out and 5 to get back in. took long to get the part then put it in lol
xXs10Xx is offline
post #12 of 14 Old 10-29-2009, 11:31 PM
User is: dmax is offline
you may need to remove the exhaust downpipe to get it back in with the heat shield on the solenoid
#1 MOST IMPORTANT THING make sure if you have a heat shield on your solenoid be sure to put it back on the new starter or you will fry solenoids yearly like i do because i lost my heat shield!!!
on that note my 00' auto is easy to replace the starter in without removing the exhaust but as i said i didn't put that shield back in and as a result end up replacing my starter yearly
dmax is offline
post #13 of 14 Old 10-31-2009, 01:05 PM
4 wheels aren't as fun
serpentracer's Avatar
User is: serpentracer is offline
my 2002 with the 4.3 used to do that. I took it off and put grease on the shaft where the gear slides. it quit. and has been fine ever since. that was almost 3 years ago. this could possibly save you a $100.
02 sonoma 4.3L auto
97 sonoma 2.2L manual
post #14 of 14 Old 11-01-2009, 01:02 PM Thread Starter
that was not my problem the armature bearings were shot and it was bouncing around inside and wouldnt start the trucks sometimes.
xXs10Xx is offline
