9.52@152.65
PIC 62MM RSM Throttle Body VS. Stock
For your viewing pleasure
Re: PIC 62MM RSM Throttle Body VS. Stock
where can you get the 62mm RSM TB...
9.52@152.65
www.dfwminis.com
damn I would rather go get olds (or whatever it is) throttle body for $40
WHAAAh?
Location: IOWA, land of Corn and Pork User is: OffLine |
but those are a 59mm right?
www.dfwminis.com
yep
i can only find a 59mm throttle body on the rsm website
i can beat a geo...barely
AJ |
it dont show one for the s-10 so which one will fit the 03 s-10???????????
how much more does a 62 mm TB put out over stock?
Campin In Style
does adding the larger tb make any noise difference. im about ready to demod my truck because im tired of how loud the dang thing is. if i could find out what causes the loudness id get rid of it or fix it.
Moderator
Brandon, 98-03 are same TB, go get it if you can
Kretty1, not shown on dyno but enough for you to git your arse moving faster than intake/exhaust put together Ziber, i know im deaf, i didnt hear any difference with my hearing aids and others has put on and never say anythin about noise difference, check for any leak hosing as well, what type of noise is it making? |
Low in Alaska
what kinda intake systems would work with this?
Moderator
stock to drop in intake to any aftermarket intake set up for our 2.2 will work, same outside diameter, just inside is bigger opening.
Fake it till you make it!
http://www.rsmracing.com/Lrg_Images/befaft22.jpg This is the one for 94-97. This is a good power mod. Very easy to see and feel results. I would recomend it to all because it works! S10
How quick can these 2.2's get to, 15's? w/o Turbo or SC
Ok so here is my opinion on the bigger throttle body mod. Yes I have a 2.2 and its fully built w/internals ( AND YES IT COSTED OUT THE ASS. AND NO IT DOES NOT HAVE FORCED INDUCTION) why by a bigger throttle body for more air when you need to widen the intake that the tb sits on? Sure I understand that it can get more air and stuff but only so much air can be forced through the intake. So ergo you should also widen the intake to which the tb sits on to accomadate that mod. if you do that then the tb is a worthy mod.
ZR2 is exactly correct. The intake ttract is usually the restricting factor on air fow in....
Banned
what throttle body could i use on my 1995 2.2?
tu-tu guru
sts makes em $275+$100 core
rms website gone?i cant get it to open
