p1137 and p0137 codes? - S-10 Forum
post #1 of 8 Old 08-10-2010, 05:06 PM Thread Starter
User is: brucelee13245 is offline
Hey guys, i have an 01 xtreme 4 speed and its spitting these codes out. I looked up the codes but i do not know if these are urgent or not really a big deal. I just put in an aftermarket intake so may that be causing it. I would appreciate the help guys. thanks.
post #2 of 8 Old 08-10-2010, 06:23 PM
child at heart
gregoneck's Avatar
User is: gregoneck is offline
Send a message via Yahoo to gregoneck
Re: p1137 and p0137 codes?
they are O2 and lean related codes so i would check the install and make sure it's correctly installed but i think the problem is the O2 sensor itself.
98noma xtcab stepside zq8 double deuce
05 GTO 402 M6
Some people are like slinkies, they're not really good for anything but they can bring a smile to your face when you push them down a flight of stairs
post #3 of 8 Old 08-10-2010, 11:29 PM Thread Starter
hey thanks, what kind of affect would that have on my truck?
post #4 of 8 Old 08-11-2010, 04:23 PM
child at heart
gregoneck's Avatar
lean problems can f some stuff up, especially if it's real lean (my GTO knows all about that). at WOT it will make a detonation picnic out of your rod bearings and pistons.
but looking the codes you posted the p0137 is a bank 1 sensor 2 code and that is the after cat one so either the cat is done or the O2 is bad.
05 GTO 402 M6
post #5 of 8 Old 08-11-2010, 10:13 PM Thread Starter
hm l , which 02 sensor am i looking at and where? and also, how can i check to see if my cat is bad? the last thing i need is a fried motor
post #6 of 8 Old 08-11-2010, 10:21 PM Thread Starter
hm, looking at it it looks like its the right side after cat o2 sensor, say i replace all of the 02 sensors before and after the cat (should be four of them) will i be good to go? im trying to learn stuff so here i am. thanks guys.
post #7 of 8 Old 08-12-2010, 07:53 PM
child at heart
gregoneck's Avatar
there are only 2 on the 2.2.
one in the exhust manifold and the other is after the cat.
05 GTO 402 M6
post #8 of 8 Old 08-12-2010, 09:14 PM
Forum Dictator
What?'s Avatar
User is: What? is offline
He's right, you only need to replace o2 sensor on AFTER cat, either that OR your cat is bad. Either way isn't affecting your engine unless cat is clogged bad then you'll lose mpg and power.
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
