p0200 T/ code on my 99's10? - S-10 Forum
post #1 of 9 Old 09-11-2006, 08:03 PM Thread Starter
I void warranties
str8valve's Avatar
User is: str8valve is offline
im gettin this p0200 trouble code on my truck, runs like crap. replaced everything you can think. i am hearing a lot of talk about replacing the ecm. any way checkin it to be sure. left my multi meter in the rain the other day, and i cant find a noid light anywhere in town. can i make my own noid light out of some spade terminals and a dome light or can i go pick up a cheap dmm and check for voltage at the injector's harness. any help would be greatly appreciated.
post #2 of 9 Old 09-12-2006, 04:58 PM Thread Starter
I void warranties
str8valve's Avatar
Re: p0200 T/ code on my 99's10?
ok just bought a noid light set. #4 injector stays lit up while all the others flash. so is that a bad pcm?
post #3 of 9 Old 09-12-2006, 05:34 PM Thread Starter
I void warranties
str8valve's Avatar
how do i check the continuity from pcm to injector?
the wiring diagram in my haynes manual is a bit unclear on wire colors.
post #4 of 9 Old 09-14-2006, 02:38 PM
pork-the other white meat
casanoma's Avatar
User is: casanoma is offline
Send a message via AIM to casanoma Send a message via Yahoo to casanoma
mine is doing the exact same thing except it is #3 cyl
AA
casanoma is offline
post #5 of 9 Old 09-14-2006, 11:02 PM Thread Starter
I void warranties
str8valve's Avatar
got a pcm from a 98' cavilier. took it to the dealer had them reprogram it for my truck. so far so good.
post #6 of 9 Old 09-14-2006, 11:11 PM
Roadrunner=Chicken
Dozer600's Avatar
User is: Dozer600 is offline
Good to here. Keep us posted.
Jason
98 2.2 5 speed
87 Astro (Next project: Topless with V8, lifted on a 80' Blazer frame)
54 John Deere 40U
00 Polaris 600 Touring
Dozer600 is offline
post #7 of 9 Old 09-18-2006, 05:27 PM
casanoma's Avatar
did the same thing so far so good
AA
casanoma is offline
post #8 of 9 Old 07-09-2011, 10:07 PM
User is: Bubbas Truck is offline
Autozone now has reman PCM's, will flash them prior to shipping if you provide VIN
post #9 of 9 Old 07-11-2011, 11:33 AM
User is: dinosaurcabinets is offline
I was having problems with my #4 injector. I was looking at the wiring harness on the fuel rail, and one of the wires that connected to the injector looked a little off. I carefully trimmed the wire away with an exactoknife, and found that wire inside had separated. I resoldered it, wrapped it up with electric tape, and it works fine now.
