Offical Fastest 2.2L 1/4 Times
Old 10-21-2007, 10:17 PM   #1
i need a paint job
s106banger's Avatar
i think we need to start a fastest 2.2 sticky. i know we have stickys for the forced induction group but i am intrested to see what kinda time people have goin on with the 2.2 n/a.
post your name, 1/4 mile time, trap speed, and your 60' if you got it.
2.2 N/A
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
2.2 on the bottle
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
2.2 force induction
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
i dont care if its stupid or worthless just post your times.
Old 10-21-2007, 11:09 PM   #2
Trackside Support Vehicle
S-10Driver's Avatar
Re: fastest 2.2 s10's
18.80 @ 71 mph
http://video.google.com/videoplay?do...ch& plindex=0
Old 11-27-2007, 01:19 PM   #3
Moderator
What?'s Avatar
Re: Offical Fastest 2.2L 1/4 Times
(C) = Slips/Pics/Vids Confirmed
(UC) = Slips/Pics/Vids UNConfirmed
2.2L N/A
1. Gutlesswonder(C) - 17.3 @ 81mph/130kph
Mod: Intake(ditched a headlight and ran a funnel to direct air), 2.25" exhaust w/high flow cat, Al's Header, E-fan, Asp pullies, IAT mod(worthless) I had a jet stage II and venom 400pcm but they actually decreased my times. Tires, 255/55/15
2. ktr_s10(C) - 17.66 @ 75.46mph/121.43kph
Mods: '94 5spd, efan, cat removed, cherrybomb turbo muffler, autozone intake, performance coils and wires, 4/5 drop, 245/45/17s all around
3. smirnoffmx(C) - 17.8 @ 79mph/127kph
Mods: K&N FIPK, Pacesetter Header, Hollow Cat, Flowmaster, Decked Head, Oversized valves with 3 angle valve job
4. camaro_s10_89(UC) - 17.9 @ 75mph/120kph
5. What?(C) - 18.1 @ 74mph/119kph
Mods: K&N FIPK Gen II, 5 Spd, Reg cab, ALL STOCK
6. ProTouring2.2(C) - 18.165 @ 75.48
7. 2.2sleeper(C) - 18.3 @ 73 mph/ 115kph
8. eacs10(UC) - 18.7 @ 85mph/136kph
9. S-10Driver(C) - 18.8 @ 71mph/114kph
Mods: K&N Intake, Flowmaster 40, Efan, Auto Trans
10. Chvys10(UC) - 19.0 @ 88mph/141kph
2.2L on the Bottle(Nitrous)
1. Black X(C) - 15.71 @ 85mph/137kph 65 Shot
2.
2.2L Forced Induction (Click this thread for further member's setup http://www.s10forum.com/forum/f105/o...embers-270646/ )
1. Adler(C) - 14.1 @ 101mph/162kph(Turbo/Sunfire)
2. cs xtreme (C) (Turbo) -
R/T .162
60' 2.003
330 5.659
1/8 8.815
mph 76.95
1000 11.553
1/4 13.869
95.41 mph
3. SpoolinSdime(UC) - 14.329 @ 95.01mph/152kph(Turbo)
4. bladerjc43015(UC) - 14.88 @ 92.73mph/148kph(Turbo)
5. 325c2(C) - 15.82 @ 85.39mph/137.41kph (Turbo)
6. 300k - '98 Auto(Turbo)
7psi
60' 2.1
330' 6.3
1/8 10.0
1/8mph 66.6
1000 13.1
1/4 15.9
1/4mph 82.55
Old 03-08-2008, 05:54 PM   #4
Professional Noob
datman13's Avatar
14.4 on a 2.2.
damn.
Old 04-23-2008, 03:34 AM   #5
It wouldn't be that hard to run 14's if the truck was pushin' 15# of boost, was hooking up & had a good low gear to multiply torque.
A 700R4 trans with a 4.10 or lower axle (lower the better) &posi trac, would do great.
Simple math is key here.
2.2L = 132 cu in
2.2L w/14.7# boost (double atmosphere) = 264 cu in.
most v8's stock put out like 80% volumetric efficincy so it looks like this
355 cu in x .80% = 284 cu in.
Since a turbo properly set up will deliver 100% volumetric efficency plus the 2.2 has half the reciprocating drag. Less pistons & lighter crank etc.
Anyway... If we reversed the 2.2 w/ 14.7# boost to an normally aspirated
it would be something like this
264 devided by 80% = 330 cu in...
Properly geared a 327 chevy (stock) with low gears & good grip will push most s10's well into the mid 14 second range.
The big advantage that the turbocharged 2.2 would have over a big v8 is the absense of brutal torque so the 0-60 times would be easier on the hook.
i.e. most v8's have a little trouble with smooth launches & have wheel spin...
Time slips can be fabricated so I wouldn't even go there...
One final thought my friends....
A rocket will get you there the fastest, but nothing sounds like a v8... ~Jim
Old 04-23-2008, 06:39 AM   #6
Moderator
What?'s Avatar
2.2L N/A
2.
R/T .162
60' 2.003
330 5.659
1/8 8.815
mph 76.95
1000 11.553
1/4 13.869
95.41 mph
7psi
60' 2.1
330' 6.3
1/8 10.0
1/8mph 66.6
1000 13.1
1/4 15.9
1/4mph 82.55
Old 07-01-2008, 02:43 PM   #7
1996 s10. 2.2 all stock with 280000 km. Ran a 18.272 72.94 mph 1/4 mile. .2498 reaction. 2.4882 60 feet.
Old 07-02-2008, 12:28 PM   #8
gutlesswonder's Avatar
Quote: Originally Posted by cs xtreme
June 25
7:22 pm
R/T .290
60 ft 2.195
330 5.928
1/8 9.092
mph 77.30
1000 11.847
1/4 14.164
mph 99.66
more in my turbo engine build thread
that trap is good for a 13 all day long
Old 07-04-2008, 01:59 AM   #9
Have a nice day!
ProTouring2.2's Avatar
first run ever:
19.7 @ 73, grinded second gear, then went to fourth, then finally found second. Embarrassed the shit out of myself and threw that slip away
second run: 18.1 @ 75
R/T ... 0.554 (R/T doesn't count towards total time)
60' ... 2.642
330 ... 7.587
1/8 ... 11.688
MPH ... 60.21
1000 ... 15.181
1/4 ... 18.165
MPH ... 75.48
Clutch was slipping badly during the burnout and a little off the line. I parked the truck after that.
98 reg cab 5 speed, stock motor with all kinds of exhaust leaks and a bad EGR valve.
Old 07-12-2008, 12:46 PM   #10
boosted 2.2L
cs xtreme's Avatar
7-12
2.0 60'
lots of heat soak, launched at 2300, (brakes wouldn't hold boost) had to adjust the rear brakes up after that pass but was fighting heat soak (about 100* out).
anyway first pass was a 13.86 followed by two 13.96's and then a 14.1 in about a 30-40 mph headwind. decided to call it a night after that
I'll post exact timeslip details when i get off work.
Old 07-12-2008, 06:58 PM   #11
boosted 2.2L
cs xtreme's Avatar
R/T .162
60' 2.003
330 5.659
1/8 8.815
mph 76.95
1000 11.553
1/4 13.869
95.41 mph
Old 08-16-2008, 07:27 PM   #12
rb25det inside :D
scottymizt's Avatar
ok got my official time for the 2.2l turbo 7 psi of boost and on street tires with air ride(wheel hop sucks)
reaction .15
60ft 2.27
330ft 6.53
594ft 9.488
1/8 10.14
1/8mph 68.83
1/4 15.86
1/4mph 85.20
i did have one slip that said i ran an 11.8@85mph but i think something blew thru the lites lol
Old 08-18-2008, 05:53 PM   #13
wow you really need to work on your 1000ft. I have trapped 85mph running a 17 sec 1/4.
Old 08-18-2008, 07:54 PM   #14
rb25det inside :D
scottymizt's Avatar
i thought it was pretty much right on there were two others with almost the same et and traps as me.
Old 04-06-2009, 09:46 AM   #15
R/t .216
60 2.507
330 7.103
1/8 11.211
Mph 60.57
1000 14.735
1/4 17.737
Mph 74.00
Old 04-09-2009, 12:35 PM   #16
andyswmr714's Avatar
R/t .268
60' 2.643
330 7.073
1/8 10.784
mph 67.70
1000 13.888
1/4 16.529
mph 85.55
DTS kit. No Cat. 2.5in exhaust all the way, Synchronic bov.
I had quite a bit of slip-age I believe my times would have been better if i had a locking diff. That was my very first time at the track as well.
If i go again with the same set up I am going to ice the intercooler.
Old 04-09-2009, 03:12 PM   #17
boosted 2.2L
cs xtreme's Avatar
Quote: Originally Posted by andyswmr714
R/t .268
60' 2.643
330 7.073
1/8 10.784
mph 67.70
1000 13.888
1/4 16.529
mph 85.55
how much boost?
Old 04-11-2009, 01:30 AM   #18
The stock kit is set up for 8 psi. I have a MBC but, I dont' feel comfortable enough running more boost considering the Manual FMU is a 12:1.
Old 04-22-2009, 11:08 PM   #19
Ok i cant get a pic yet but i will be able to in the next week and i have a base standard cab with no cat or muffler cold air intake iat bypass 5 speed trans bosch plantnum plus u grove plugs i believe thats it if i think of more i will post it
Old 05-17-2009, 01:15 PM   #20
300k's Avatar
'98 Chev S10 2.2l turbo auto.
7psi
60' 2.1
330' 6.3
1/8 10.0
1/8mph 66.6
1000 13.1
1/4 15.9
1/4mph 82.55
Old 05-31-2009, 06:35 PM   #21
first run
R/T .2
1/4 19.59 @ 68mph
best run
R/T .05
1/4 19.03 @ 70mph
only a cold air intake
Old 10-31-2009, 02:28 AM   #22
bone stock 2.2 5 spd
2.5 60 ft
1.4 1/8
18.125 1/4
72.6 mph
gotta work on my 60 ft
Old 11-14-2009, 06:02 AM   #23
Just turned 18
Hard to see the timeslip I'll try to get a better picture of it or scan it, but here is my quickest run from tonight.
R/T.... .578
60'.... 2.813
330.... 7.793
1/8.... 12.038
1000.... 15.696
ET.... 18.789
MPH.... 72.74
2000 2.2 s10 5 speed - 56mm tb, FlexALite efan, Inline Fuel Pump, 180* tstat, cold air intake, 40 series, Kumho 205/75/15s, as well as ditched headlight...
Page generated in 0.67474 seconds with 31 queries
[Output: 120.45 Kb. compressed to 111.22 Kb. by saving 9.23 Kb. (7.66%)]
