o2 sensor problem - S-10 Forum
post #1 of 14 Old 07-01-2005, 04:03 PM Thread Starter
User is: 1998zq8s10 is offline
o2 sensor problem
2 days ago my truck threw code p0137, o2 sensor low voltage. which one is this? cleared the code, and last night ses light came on again. there is no loss of power, truck runs exactly the same, and i am getting good gas mileage, no noticeable drop. i replaced the manifold o2 sensor within the past 6-8 months, so i dont know why it would be bad already if that is the sensor it is throwing a code for.
1998 ZQ8 S-10 pewter, 5/6 drop, tinted windows, cal-vu ss mirrors, clear corners, welded rollpan, licence plate sideways in gate
Next mods:
-shaved 3rd brake light, antenna, hood squirters
-paint
'05 Suzuki GSX-R 600 red/black, stock for now
post #2 of 14 Old 07-01-2005, 04:55 PM
skinnyg's Avatar
User is: skinnyg is offline
Send a message via AIM to skinnyg Send a message via MSN to skinnyg Send a message via Yahoo to skinnyg
Re: o2 sensor problem
it would prolly help if you posted year and engine size, and did you use a dealer sensor? ONLY use a gm sensor.
skinnyg is offline
post #3 of 14 Old 07-01-2005, 10:44 PM Thread Starter
it says in my sig the truck is a 98, and i posted in 2.2 forum, so that means the truck is a 2.2. i used a bosch oem sensor.
Next mods:
-paint
post #4 of 14 Old 07-02-2005, 12:50 AM
Soon To Be Pimp
slammed94noma's Avatar
User is: slammed94noma is offline
Send a message via AIM to slammed94noma Send a message via Yahoo to slammed94noma
how much is a o2 sensor?
1994 sonoma 3/4 drop, V8, M3 mirrors,K&N, window tint, remote start, Stainless steel exhaust, e-fan
My Cardomain site: http://www.cardomain.com/id/slammed94noma
post #5 of 14 Old 07-02-2005, 01:09 AM
Registered Abuser
erronisme's Avatar
User is: erronisme is offline
not saying that its bad...but there is another O2 sensor after the cat
Bye Bye 98 S-10 Bye Bye 76 Luv!! bye bye 63 Fairlane 500
post #6 of 14 Old 07-03-2005, 06:50 PM Thread Starter
i know that, but i think that code has to do with the manifold 02 sensor
Next mods:
-paint
post #7 of 14 Old 07-05-2005, 04:27 PM
User is: bordv2 is offline
p0137 is 02 sensor circurt low volts (bank 1 sensor 2) im haveing the same problem but i got more then one code.. and it stinks because now my gas mileage went from 300 down to 200 to a tank ... and that code i gave u is from a 97 s10 but obd 2 says all codes are the same though year though year.. also if u guys are geting other codes around these problems its p0131 os sensor circuit low volts (bank 1 sensor 1) p0141 o2 sensor heater circuirt malfunction (bank 1 sensor 2) and po151 02 sensor circuit low volts (bank 2 sensor 1) now with gm discount they are 105 each if they are not the manafold and if u go to pepboys u can get them 59 dollars each from bosh..
bordv2 is offline
post #8 of 14 Old 07-06-2005, 12:22 AM
The doctor is in...
Dr. Nate's Avatar
User is: Dr. Nate is offline
Send a message via AIM to Dr. Nate Send a message via Yahoo to Dr. Nate
O2 sim
2003 Xtreme ~ Toy
2007 Silverado ~ Tow Pig
Dr. Nate is offline
post #9 of 14 Old 07-09-2006, 05:52 AM
90 f**kin 7 s f**kin 10
vespasoul's Avatar
User is: vespasoul is offline
Send a message via MSN to vespasoul Send a message via Yahoo to vespasoul
Originally Posted by Dr. Nate
O2 sim
does the o2 sim work for all 3 or just the one behind the cat?
I Snatch Kisses, and vice versa!
what's the difference between a pick-pocket and a peeping tom?
a pick-pocket snatches watches...
post #10 of 14 Old 07-09-2006, 04:12 PM
Roadrunner=Chicken
Dozer600's Avatar
User is: Dozer600 is offline
Just the one behind the cat.
Jason
98 2.2 5 speed
87 Astro (Next project: Topless with V8, lifted on a 80' Blazer frame)
54 John Deere 40U
00 Polaris 600 Touring
Dozer600 is offline
post #11 of 14 Old 07-10-2006, 04:49 AM
vespasoul's Avatar
DAM Thanx anyways
post #12 of 14 Old 09-10-2013, 07:32 PM
Twinkletits
aaronweisler's Avatar
User is: aaronweisler is offline
Any resoloution to this?
1998 2 door GMC Sonoma 2.2L, Un- Front end swap, Microfibre Buckets, Zq8 Rims 6.5" speaker conversion and Kaption Sub behind seat.
post #13 of 14 Old 09-10-2013, 08:00 PM
always something new
S10dude's Avatar
User is: S10dude is offline
did you see how old this thread was ?............
All truck pics
S10dude is offline
post #14 of 14 Old 09-14-2013, 02:06 PM
User is: Ed98 is offline
P0137 is the post-catalyst heated sensor.
It may be as much as $80 I think. Maybe less. Only other possibility is a bad PCM for this code. Or wiring.
Labor Rates: $35/Hr. If you watch: $45. If you help: $55 If you tried to fix it yourself first: $95
Ed98 is offline
