Normal OPt temp on a 2000 s10? - S-10 Forum
post #1 of 17 Old 04-13-2005, 11:23 PM Thread Starter
Concretslider's Avatar
User is: Concretslider is offline
seems like my gauge is reading about 200 and that I thought was to high. what is the normal opt temp on s-10's?
Once you have lost everything, You are free to do anything.
post #2 of 17 Old 04-13-2005, 11:29 PM
User is: 1998zq8s10 is offline
Re: Normal OPt temp on a 2000 s10?
are you running the a/c? that makes it go up a little. i believe the thermostats are either 185 or 195 leaning toward the 195
1998 ZQ8 S-10 pewter, 5/6 drop, tinted windows, cal-vu ss mirrors, clear corners, welded rollpan, licence plate sideways in gate
Next mods:
-shaved 3rd brake light, antenna, hood squirters
-paint
'05 Suzuki GSX-R 600 red/black, stock for now
post #3 of 17 Old 04-14-2005, 07:42 AM
User is: skoivisto is offline
The search function works wonders.
http://www.s10forum.com/forum/f105/operating-temps-177824/
post #4 of 17 Old 04-14-2005, 08:13 AM
Working on aircraft
ablues10's Avatar
User is: ablues10 is offline
The stock thermostat temp is 195, I would run a 180 tho.
pics more pics ^ project pics
ablues10 is offline
post #5 of 17 Old 04-14-2005, 10:32 AM
Trackside Support Vehicle
S-10Driver's Avatar
User is: S-10Driver is offline
Send a message via AIM to S-10Driver
^ hey u took my avitar, loser. lol
yeah, the 2.2 runs a little too hot in traffic during the summer. main reason why i need to get a e-fan.
post #6 of 17 Old 04-14-2005, 01:04 PM
LS6 swap in progress.
2.2L Sonoma's Avatar
User is: 2.2L Sonoma is offline
Send a message via AIM to 2.2L Sonoma
same here...in the summer i get up past 215/220 quite frequently (that is when i have a/c running and everything with clutch fan) i hope my e-fan can help out with that. I have my theromstat on the e-fan set to come on when the temp reaches ~190. I turn it up a little more for autocross...or just turn off the fan during the trial runs...
later!
AJ
post #7 of 17 Old 04-14-2005, 04:51 PM
s10xtreme's Avatar
User is: s10xtreme is offline
Send a message via AIM to s10xtreme
mine is around 200 - 210. I drove for over 4 hours with the ac on and it never moved past 210. The only time you would need to worry is when the fan kicks on, I believe thats like 215.
post #8 of 17 Old 04-14-2005, 05:37 PM
ROD TWISTIN MEMBER
dropped94's Avatar
User is: dropped94 is offline
Send a message via AIM to dropped94
WTF? do you mean the fan kicks on
~Charlie~
PRO DIME DROPPER
^^^CLICK FOR PICS
the bitterness of poor quality lasts long after the sweetness of low cost has faded
post #9 of 17 Old 04-14-2005, 05:44 PM
95 S-10 2200
aperry62's Avatar
User is: aperry62 is offline
Send a message via AIM to aperry62 Send a message via MSN to aperry62
stock fans don't engage all the time they are basically just free wheeling. When the coil on the front of the fan gets hot enough the clutch will disengage and the fan will spin faster drawing more air. basically like a two speed fan.
95 s10 2.2L B&W T-5 5spd trans 191k
aperry62 is offline
post #10 of 17 Old 04-14-2005, 06:46 PM
Forum Dictator
What?'s Avatar
User is: What? is offline
sheesh, i would rather fan kickin in around 180-185, rather not too hot, dont wanna risk warping the heads when it gits too hot all the time
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #11 of 17 Old 04-14-2005, 07:10 PM
I read in the manual that my truck has a thermostat that kicks in at 195 degrees. I assume that this is the optimum gas mileage temp? (in thinking of the addage of a motor too cold will get worse milage?) I only have mine fan's thermo turned up a little right now to autocross...warping the heads makes me think twice about it now, though if my truck were running 250 all the time then id really get worried...i noticed though, there is only one red line on the temp gauge and thats at 260? kinda wierd.
AJ
Edit: I also noticed that on the temp gauge it starts at 100, goes to 210 half way then at the end it is 260...thats a difference of 110 degrees in the first half of the gauge and only 50 degrees in the 2nd half? what the crap does this gauge KNOW that the scale is different after 210? I am kind of confused...
post #12 of 17 Old 04-15-2005, 08:00 PM Thread Starter
Originally Posted by skoivisto
why dont you shut the F*ck up
edit:: censor the language
post #13 of 17 Old 04-15-2005, 08:34 PM
Working on aircraft
ablues10's Avatar
LMAO!
Ya caught me!
Thats a bad ass avatar tho!
I just had to have it.
My truck has a e-fan and 180 deg. t-stat. it runs @ 160 tho, do you guys think thats bad?
ablues10 is offline
post #14 of 17 Old 04-15-2005, 11:04 PM
Ive heard that running too low can hinder gas mileage. I know for sure that my truck (99 sonoma) the thermostat in the motor opens up at 195...so i am assuming the optimum operating temp is somewhere in that area...i have my efan set to come on between 190 and 200...
160 might be kinda low...but thats just in my opinion.
AJ
post #15 of 17 Old 04-16-2005, 12:25 AM
S-10Driver's Avatar
LMAO!
Ya caught me!
at least u changed teh color.
i don't care, i stole someone's signal auto silvia one to make mine.
as for the temp, i think 180 would be better than 160. i bet your heater doesn't work too well.
post #16 of 17 Old 04-16-2005, 04:55 AM
Working on aircraft
ablues10's Avatar
Nope the heater is as hot as hell, so hot it overheats my stereo
ablues10 is offline
post #17 of 17 Old 04-18-2005, 12:10 AM
Forum Dictator
What?'s Avatar
AJ
160 is low, I go 180 the lowest on stock to some mods on 2.2. the reason lower stat temp hinder gas mileage because of the engine runing cooler and it needs to stay warm comp. got the fuel system to git more richer so the engine can git warmer. I use 180* for spring-summer wit a/c(if mom,girlfriend, etc in my truck) then in winter back to stock 195* so my truck able to maintain gas mileage and not get too hot(over 200*)
What? is offline
