No high speed fan - S-10 Forum
post #1 of 17 Old 08-16-2006, 05:24 PM Thread Starter
User is: sparkyspider is offline
No high speed fan
I have no hi speed blower motor. I have replaced the fan switch, the blower relay,and still have ni High speed, on a/c or vent or anything. Anyone else had this problem?
post #2 of 17 Old 07-16-2007, 09:41 PM
User is: Clean96Noma is offline
Send a message via AIM to Clean96Noma
Re: No high speed fan
I have this exact same problem. I replaced the blower motor resistor inside the housing ($10 for an AC Delco brand new part), also replaced blower motor, blower motor relays, and the HVAC control unit all with brand new AC Delco parts, still didn't figure out how to fix it...
post #3 of 17 Old 12-28-2009, 01:04 PM
Member
User is: V8S15Jimmy is offline
same problem, on the 2000 S10 which wire(s) control the high setting? I'm getting low (somewhat) but no high fan.
I know the lower settings go though the resistor and I changed the relay. Another thing I noticed was lack of 12 volts at the plug when set on "high"
The HVAC fuses in the dash panel are good
Help!
post #4 of 17 Old 12-30-2009, 08:51 AM
4 wheels aren't as fun
serpentracer's Avatar
User is: serpentracer is offline
our 2006 chevy work truck was doing that and it was the plug/wires from the motor to the control.
for that truck it was a service bulletin. they gave us a new plug with heavier wires and connectors and now it works.
but ours was a plug inside the truck to the heater box. didn't even have to take anything off the dash to fix.
I would bet you guys have the same problem.
http://www.motorcity1.com/TSB_Heater.htm
02 sonoma 4.3L auto
97 sonoma 2.2L manual
post #5 of 17 Old 03-21-2011, 10:34 PM
code_red63366's Avatar
User is: code_red63366 is offline
I know this article is old, but I have had the very same issue now forever. I have replaced the blower motor, Hvac control module on the HVAC housing under the hood and today I replaced the blower switch on the dash, yet still cant get number 4 speed to work. Sometimes it does pop on and work and other times it wont. Where abouts is this hush panel/close out panel located . I have a 2001 S10 2.2 litre.
post #6 of 17 Old 03-22-2011, 12:46 AM
m m m myyyyy sonoma
eyeofthetiger's Avatar
User is: eyeofthetiger is offline
Sometimes my high fan speed starts working if I pound my fist on the dash, but it usually stops the next time I go over a bump. Oh, well.
#20: 1996 GMC Sonoma 2wd xtendocab 2200cc 4L60E
modz: Powertrax Lock-Right, kthxbai.
post #7 of 17 Old 03-22-2011, 09:04 AM
Samething here eyeofthetiger. It comes on at odd times and not when you wan it to come on, im thinking its a bad ground or short in the wire. Myabe a factory issue?
post #8 of 17 Old 03-22-2011, 03:08 PM
SunnyDeez's Avatar
User is: SunnyDeez is offline
You know I had a similar issue. My fan would only blow on low and would stop working altogether at times. And if I turned my heat on and off real fast my abs and brake light would flash...
Anyway it turned out to be my ignition switch (by ignition switch I mean the cluster of wires attached to the ignition). I looked closely and the plastic was slightly melted by the contacts and they were corroded. Swapped out the ignition switch and the fan worked perfectly on all settings. It also got rid of the flashing lights. Its been over 6 months and its still running great.
I've read up on it and it seems bad ignition switches can cause some strange electrical problems with stuff like blower motors and electric windows in s10's. That might be your problem.
post #9 of 17 Old 03-22-2011, 09:31 PM
Yes i was reading about this also in another post, I guess it would be worth a shot at looking at it. I hate chasing down electrical gremlins. This morning when i got onto the on ramp for highway 70, I hah forgotten i had the blower switch set on number 4, well when i hit the gas to speed up, it came on, but wasnt working before??? Im trying to make note of when it does come on and what was done when it came on, in hopes to track it down to the problem.
post #10 of 17 Old 03-22-2011, 09:33 PM
Oh sunny, question, when you replace your ignition switch can you use your old key or do you have a new one you have to use? I know this is probably a dumb question, but the way the make cars now and days, I never know what to expect.
post #11 of 17 Old 03-23-2011, 11:57 AM
SunnyDeez's Avatar
You dont need a new ignition. Its easy to swap. Just drop the steering wheel and its cake.
Heres a link to the part on ebay. They have cheaper versions, but ACdelco is always the way to go:
http://cgi.ebay.com/ebaymotors/ACDEL...Q5fAccessories
post #12 of 17 Old 03-23-2011, 09:02 PM
Thanks for the info!
post #13 of 17 Old 01-19-2015, 04:50 PM
User is: xrayd is offline
Only when the fan speed switch is set to the highest setting the blower motor relay is pulled in. A separate +12v source then flows through this relay and supplies voltage to the blower motor. This separate +12v source is fed from a 30amp (green) green fuse in the 'Underhood Fuse Block'. Look for a blown 30 amp fuse under the hood, and not in the cabin. Replaced mine and FIXED!
xrayd is offline
post #14 of 17 Old 03-01-2015, 12:03 PM
Thanks for the reply. I did check that..the fuse was good. It ended up being the relay for the circuit. It kept melting the wiring and relay. Changed out the wiring and connector and then got a relay from Orielly's with a lifetime waranty. Now when it ruins the relay , i simply take it back and have it replaced for free till i can track down the source of the issue. I have yet to change the blower resistor on it so this will be my next task.It worked fine till about a couple months ago and now it only blows slow on 3 and 4 with hardly anything coming out on 1 and 2. I am guessing the resistor on an 01 2.2 base is under the hood on the hvac housing near the firewall. I will try and give it a go today, weather permitting.
Mike...... 2001 S10 2.2, Flex fuel, 5 speed, base model, all stock
2nd vehicle.......2003 Ford Excursion, 5.4, gas, 4 wheel drive, all stock
post #15 of 17 Old 03-01-2015, 06:56 PM
Ok.. So I replaced the blower motor resistor and it did not solve my problem. After a little more research I found that my issue was not electrical yet it was a simple vacuum hose under the hood near the abs unit and master cylinder. The hose was dry rotted. I replaced it with a new hose and the vent control selector issue is now cured. All is normal once again....for now
post #16 of 17 Old 07-16-2015, 10:58 PM
User is: Dalz102 is offline
Hey codered,
What's the part number on that O'Reilly warranted part?
Dalz102 is offline
post #17 of 17 Old 07-23-2016, 01:35 PM
DKO
User is: DKO is offline
Cool Re: No high speed fan
Thanks! Switching the fuse fixed mine.
DKO is offline
