New timing chain without tensioner? - Page 2 - S-10 Forum
post #51 of 150 Old 10-13-2012, 07:47 PM
agent00kevin's Avatar
User is: agent00kevin is offline
Re: New timing chain without tensioner?
And it took them this long to make a shorter, stronger chain :P
One would have to ask why GM didnt just do that in the first place...
Im interested though. Id like to see how they perform, but id be terrified to risk snapping one. I suppose since some cars ran on a BELT and countless other models ran without a tensioner it isnt that big of a deal...but like I said, I wonder why it took so many years to do and why GM didnt do it in the first place.
Also, given the Cloyes Tensioner I bought a while back lasted about 500 miles Im not exactly confident in their product quality. They do get good reviews on other vehicles though.
Would love to see some reviews after a few thousand hard miles have been put on one.
1988 GMC S15 2.5L
1997 Chevrolet S10 2.2L
1996 GMC Subruban 5.7L Vortec
post #52 of 150 Old 10-14-2012, 12:45 PM
Chzyrider's Avatar
User is: Chzyrider is offline
Re: New timing chain- double check your parts.
I was replacing the timing chain/gear set in my son's 1987 S10 Blazer 4x4 w/2.8L, ordering the Cloyes set from a popular online source with the gaskets. In comparing the two sets laying flat on the table, they appeared to be correct. Anyone would not normally notice any abnormal differences and install the new set as-is. But through my experience with the occasional mis-labled or mis-boxed part, I always compare the gears over each other to confirm the chain link count, tooth count, diameters and alignment.
In this case, for comparison, when I slid both of the bottom drive gears (loosely) back onto the crankshaft, that's when things did not match up.
It had apparently been mis-machined and the teeth did not align with the old gear. The replacement gear was off a couple degrees or so. I called the online source and sent them photos. They were very grateful in letting them know of this defect and said they would try to check their existing stock for others like it and promptly refunded my money.
I purchased another set from my local parts store and compared the two on the crank and they matched exactly. Both sets had the S-511 stamped on the bottom gear, but the one gear must've been machined on a Monday morning. I contacted Cloyes and they were very appreciative as well for pointing this out.
So always double-check your parts!!
post #53 of 150 Old 10-14-2012, 07:20 PM
Ross98's Avatar
User is: Ross98 is offline
Anything not standard dimensions, off the shelf costs more. The 2.2 is a base engine, manufactured in the millions, they're not looking for anything but lowest cost. But you'd think eliminating the tensioner would cover the cost difference??
1998 S-10 Ext cab/2.2/5-sp
Ross98 is offline
post #54 of 150 Old 10-15-2012, 05:35 PM
I Prefer Payne
payne4life's Avatar
User is: payne4life is offline
at first i wasnt convinced but the more i read on the more i believe it will work great. i know i have 150k miles on my stock chain and should probably change soon but my truck is running great right now so i havent really thought about changing the timing change.
2000 SAAB 9-3 2.0t hatchback 5-speed. 145k miles - CURRENTLY ON JACK STANDS
2000 s10 LS X-cab 2.2 flex fuel auto. 170k miles
MODS: 56mm TB, Ebay CAI with K&N filter, E-fan, ZQ8 sway bars, GC steering box, steering shaft u-joint
http://www.cardomain.com/id/brandomonium12
post #55 of 150 Old 10-15-2012, 09:04 PM
2.2 Extremist
GMC Motorsports's Avatar
User is: GMC Motorsports is offline
my question is it did say it would advance timing a lil bit. Would it be enough to where a computer tune would be needed or is it so minuscule it wouldn't matter? I mean if its available for the average joe to put in as a replacement part I'm sure it's not, just a thought.
2000 GMC Sonoma SLS
ECSB 2.2L Flex Fuel L43 bored 0.40, 0.20 head shave, 5-Speed, 4.10 gears, Space Blue Metallic, Graphite Int, OBX Header, straight pipe cat delete, Thrush Welded, urethane motor mounts, ZQ8 sway bars, Hurst Short Throw Shifter, ClutchMasters 9lbs flywheel
Other Rides: 09 Canyon 5.3 ZQ8, 05 Duramax, 85 Monte Carlo SS.
post #56 of 150 Old 10-16-2012, 11:58 PM
Tech Mod
beandip's Avatar
User is: beandip is offline
i dont see how it would advance timing, even if the chain was shorter, the crank/cam move at the same speed because they rotate at a fixed speed along the chain. changing the length has no effect besides how long it takes the chain to rotate 1 revolution.
-Jonathan
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #57 of 150 Old 10-17-2012, 06:58 AM
Powder Coat Specialist
xtrememeasures10's Avatar
User is: xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
I took some measurements of the crank and cam gear last night. Ill post results when i have some time here closer to the weekend.
97' w/ 03' Front end, Too many mods to list....
2.2L Build and Powder Coat Project
http://www.s10forum.com/forum/f105/2...ernals-486082/
Check out my Business Powder Coating work.
http://www.facebook.com/makpowdercoating
post #58 of 150 Old 10-17-2012, 07:29 PM
User is: jc01 is offline
I installed this setup on my truck last week and i have put 300 miles on it and starting to tick . It sounds like its coming from the timing cover. Does anybody know wat it could be? I replaced the oil orifce amd soaked the chain overnight in oil. Any ideas?
jc01 is offline
post #59 of 150 Old 10-17-2012, 08:37 PM
Its only at idle and off idle but do not hear it about 2000 rpms didn't hear anything before just changed the gears bc had the front cover off to fix oil leak
jc01 is offline
post #60 of 150 Old 10-19-2012, 04:14 PM
i called Cloyes and they bascially said that it had to be something i had i done and theres no way its installed correctly . im never buying one of there products again very disappionted
jc01 is offline
post #61 of 150 Old 10-20-2012, 03:19 PM
i took it apart this morning and and chain had alot of slack in it and it wasnt in there when i first installed it i cannot believe how much it was stretched in the few miles i had it on there. heres some pics .
ID:	128472   Click image for larger version
jc01 is offline
post #62 of 150 Old 10-20-2012, 03:39 PM
always something new
S10dude's Avatar
User is: S10dude is offline
doah.............
All truck pics
S10dude is offline
post #63 of 150 Old 10-20-2012, 04:16 PM
8/31/1897 - 4/29/2004
BravadaX's Avatar
User is: BravadaX is offline
Hahahaha.
I turned mine into an Oldsmobile, bitches love Oldsmobiles.
BravadaX is offline
post #64 of 150 Old 10-20-2012, 05:47 PM Thread Starter
User is: sonomatokey is offline
Oh, boy ! Going with the GM chain and tensioner.
post #65 of 150 Old 10-20-2012, 07:01 PM
Registered Un-dependent
Mechnix's Avatar
User is: Mechnix is offline
I always wonder when people think they are smarter than the people that designed the vehicle in the first place....
Mechnix is offline
post #66 of 150 Old 10-21-2012, 12:07 PM
Tag
User is: Tag is offline
So if it is their claim he installed it wrong what could he have done to cause stretch?
95 2.2 manual extended cab.
Tag is offline
post #67 of 150 Old 10-21-2012, 02:28 PM
Mechnix's Avatar
That's what chains do...
Mechnix is offline
post #68 of 150 Old 10-21-2012, 02:39 PM
S10dude's Avatar
nothing .....thats there fail safe "it's your fault , not OUR's.......
All truck pics
S10dude is offline
post #69 of 150 Old 10-21-2012, 04:30 PM
And carquest says they cant do anything cause its special order
jc01 is offline
post #70 of 150 Old 10-21-2012, 04:32 PM
It's mostly BS
rimara's Avatar
User is: rimara is offline
It seems that the timing set will continue to be a weak point in the 2.2. I really would have liked to have seen Cloyes come through on this, but I'm skeptical at this point.
For that chain to have stretched that amount in just 300 miles, there must have been some serious forces on that chain. What sort of force could cause a chain to stretch that fast? I don't claim to know the answer in this case but I have a guess. If the chain were to go into what is called harmonic resonance, it will massively amplify the forces on that chain and very easily make it stretch. If one were to look at the OEM design, you will see that both chain segments between the gears have a plastic guide running on it. One side also acts as a tensioner, but still both sides have a plastic guide that will dampen vibration. With the Cloyes design, those dampeners are gone. Cloyes claims that they control vibration or oscillation by carefully controlling the length of the chain to minimize slack. As with any mechanical vibration, its vibration intensity is frequency dependent, in other words, the vibration intensity will vary depending on the speed of the components involved. We have all seen when a heat shield for example will rattle like crazy at just the right engine rpm (the heat shield's resonant frequency) and be otherwise quiet at other rpms. So why did the testing in the circle track that Cloyes did not see this problem? Who knows, but it is very possible that running an engine at a constant 6K+ is not the same as an engine at normal rpms of 2-3K. While one might think that the high rpm use would put more stress on the parts, this might not be the case depending on the resonant frequency of the system.
I wonder if Cloyes performed a test on this timing set on a real 2.2 that measured the mechanical oscillations through the entire rpm range? If all they did was give the new chain to some racers and extrapolate good results there into success on the street, this could be a big mistake. Hey, I'm guessing about what exactly is going on with these parts, but at this point, I'm going to stay will the OEM design until and unless I see better evidence from Cloyes that their design is perfected. I'd love to see Cloyes build a setup with a window in the cover to observe the chain through the rpm range with a high speed camera. I'm not holding my breath.
2001 S10 2.2 5sp ext cab
Don't hit and run...let us know how you fixed it!
rimara is offline
post #71 of 150 Old 10-21-2012, 11:28 PM
User is: turboS-10 is offline
That's a good bit of slack but it doesn't look too bad... I don't know, maybe it's just hard to see in the pictures but the 4.3L engines have a good bit of slack in them too even when properly installed and properly functioning. The slack would only be a problem if it is in fact the cause of the ticking, if it is at risk of jumping time, or if it caused the timing to be so far off that the truck has poor performance.
Was the chain able to hit the timing cover or block or anything else that would make the ticking sound? Have you had that block align honed by any chance?
post #72 of 150 Old 10-21-2012, 11:53 PM
See id like to put mine in too but am reluctant to do so now. I checked the size of the gears and there is sooo minimal difference in size it could be just normal wear. I dont think there has been enough engineering done or real life testing to prove this setup will work. We need to all stay diplomatic about this. We test it and submit our results as a group they will be forced to re engineer this design and make the necessary changes.
post #73 of 150 Old 10-22-2012, 04:40 AM
No it hasn't the truck had no sounds before the timing chain amd 4.3 are different then there 2.2. Ik the truck had a bad low rpm misses that wasnt there before and hopefully with the old setup it will be gone and we shouldn't have to do this theres the ones that should have tested there product before they started selling.
jc01 is offline
post #74 of 150 Old 10-22-2012, 05:42 AM
Thats the unfortunate thing, there not going to spend a lot of money testing it. Boeing will sell an airliner with a known fault in design that could be a major saftey hazard. What makes you think cloyes is any better. Thing is there is nothing better than real world testing. I still want to install it and see what my results are. I like the idea of a window to see whats going on in there but it would just get covered in oil.
post #75 of 150 Old 10-22-2012, 11:31 AM
Mechnix's Avatar
I really think if they want to go tensioner-guide free they should have used a hi-vo chain
Mechnix is offline
post #76 of 150 Old 10-22-2012, 02:04 PM
I put the truck back together today some how it was two notch's off idk if it slipped or it moved like installing it but im pretty sure it didnt cause i watched it carefully as i installed it so idk wat happened
jc01 is offline
post #77 of 150 Old 10-22-2012, 03:33 PM
Mechnix's Avatar
regardless of how careful you were when you installed it , did you verify that everything was lined up right -before you put the cover on?
Mechnix is offline
post #78 of 150 Old 10-22-2012, 03:46 PM
Registered Hoosier
Hoosier Rick's Avatar
I always turn them over two revolutions and recheck before I button them up.
I thought about cutting a tensioner apart and just using the guide.
2000 Jimmy 4x4 4dr. 252,000 miles
2002 rcsb, 2.2 at, 253,000 miles
1967 C10
post #79 of 150 Old 10-22-2012, 03:47 PM
Im think but not a 100 percent but ik it runs alot better now amd no sounds coming from the timing cover any more
jc01 is offline
post #80 of 150 Old 10-22-2012, 04:25 PM Thread Starter
Are you sure you didn't install it wrong in the first place?
post #81 of 150 Old 10-22-2012, 06:17 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
LOL, you have no idea how much testing is done with a new aircraft design before the FAA will even allow it in the air. Cloyes doesn't have to prove anything even to the DOT, there is no comparison. Good to know what happens with this chain after a few hundred miles tho, I'll be sticking with the GM parts.
Teamsters Local 1150
SH-60B is offline
post #82 of 150 Old 10-22-2012, 08:26 PM
S10dude's Avatar
^that
All truck pics
S10dude is offline
post #83 of 150 Old 10-22-2012, 09:11 PM
Actually i do. Being in the industry for over 8 years now. Being an A&P ( airframe and powerplant) mechanic, IA (inspection authorization) and having my FCC license. I work on the toys of the richest people in the world and help install, design and modify things you only dream about installing in your truck or house. There is a lot of R&D done on aircraft before the engineering drawings are even on paper, let alone an actual model built. However there are many faults that are known about once being built that are ignored. Just like any other industry. Dont begin to think any one industry is perfect.
Either way a company like cloyes goes through a good amount of R&D. Nothing compaired to an aircraft manufacturer but bottom line they dont want to build a product that has a high rate of failure. They will accept a small rate of failure. They all make decisions that sacrifice quality as an end result to make a profit. Whether they admit it or not.
post #84 of 150 Old 10-22-2012, 09:55 PM
I'm confused... you put the stock stuff back in and it was 2 teeth off or when you took the tensionless stuff out it was 2 teeth off???
post #85 of 150 Old 10-22-2012, 10:05 PM
I put the stock stuff back and decied to check the timing and it was 2 off i didnt check it before i took the tensionless setup off
jc01 is offline
post #86 of 150 Old 10-22-2012, 11:47 PM
Tag
Without the tensioner how did you check the timing when you installed it?
Tag is offline
post #87 of 150 Old 10-23-2012, 04:25 AM
It's "Neanderthal"
SH-60B's Avatar
I've been building jet engines and aircraft for 35 years between Pratt & Whitney and Sikorsky Aircraft, I wouldn't dream of installing anything from there into my truck, why would I? I've worked closely with production and design engineers in both companies to work out manufacturing kinks, there really aren't any design flaws in our products, just people who don't know how manufacture a component.
Cloyes might as well be making Big Macs, all they have to do is please a customer.
SH-60B is offline
post #88 of 150 Old 10-23-2012, 06:16 AM
mcdadcop's Avatar
User is: mcdadcop is offline
Not to cause an arguement here, but two things come to mind.
First, I've seen a lot more play in timing chains than is displayed in the picture above, without causing any problems at all! That much play equals about a quarter of a degree of timing, or less.
Second, there's not enough "flex" showing on that chain to hit anywhere on the block? Is there anything inside the cover that might have been in the way??
I've got 135,000 miles on my 96 tutu. Origional chain is in there. I have the same noise at and just off idle that most everyone else has. I wonder how much longer I can ignor the noise while knowing what is causing it, but also know I don't dog it when driving.
I'm thinking I still just might try this new chain, even after reading here and realizing I might have to do it again in a week. (I drive about 375 miles a week, back and forth to work. Mostly highway.)
96 Isuzu Hombre 2.2 5 spd. Which everyone knows is an S-10 with an accent..
Last edited by mcdadcop; 10-23-2012 at 06:17 AM. Reason: My spelling stinks tonight.
mcdadcop is offline
post #89 of 150 Old 10-31-2012, 03:45 PM Thread Starter
Well I just got my truck back from the shop (headgasket) and now it is throwing the code P0342. I used my scan tool to get rid of the code and it still comes back on. Going to check and see if the wires are loose.
post #90 of 150 Old 10-31-2012, 08:36 PM
User is: rodder98 is offline
Re: New timing chain without tensioner? Huh?
Guys, tell me what I am failing to understand, please. My experience with timing chains and gears is only with 4.3's and small block Chevy V8 engines.
They never had any tensioners on them, just 2 gears and the chain.
And, the pics y'all posted from the vendors here, only have a chain and 2 gears, nothing else. So, I sure don't see any tensioner, such as a timing belt would have.
I would love to understand what tensioner you are talking about. It has been my experience that chains lasted 150,000 miles or so.
Thanks.
If at first you don't succeed, then skydiving is not for you.
rodder98 is offline
post #91 of 150 Old 10-31-2012, 09:10 PM
It's mostly BS
rimara's Avatar
Here you go
http://www.jasperengines.com/pdf/GM2.2TimingTB.pdf
rimara is offline
post #92 of 150 Old 01-28-2013, 07:11 PM
HemiChallenger's Avatar
User is: HemiChallenger is offline
Send a message via AIM to HemiChallenger
Picked up my upgraded cloyes chain without the tensioner. I'll post up my results in a few days. Had pretty noticeable "ticking" when cold.
Current ride: 2000 s-10 2.2 auto ext. cab 4.10 gears
Past rides:
'92 350 s-10 12.16@113 1.80 60ft.
'98 n2o cavalier convertible 15.30@92 2.50 60ft.
post #93 of 150 Old 01-28-2013, 07:45 PM
BLU BALLER
xskarekrowx's Avatar
User is: xskarekrowx is offline
95 S10 LS 2.2 5spd
Fully bagged, caddy tails, fully shaved, and more shit.
Built not Bought
http://www.s10forum.com/forum/f30/pr...nished-667738/
post #94 of 150 Old 01-31-2013, 08:00 PM
Got her done finally. Ticking/knocking is noticeably reduced @ cold temps (below 30 here currently). Going to try different oil soon and see if it helps with the cold tick (suspecting lifters are the culprit). Noticeably more low end power. Daily driving is much nicer. Installed like a normal timing chain on every other cam in block engine. Little bit of slack on the non-tension side.
The old chain and tensioner was actually in really good shape for 130K miles. I was almost hesitant to continue but I did anyway. There were no instructions on what to do with the old tensioner bolts so I installed them back in the block with a dab of thread lock.
So far so good. 4 cold starts and probably less than 20 miles so far. I live very close to my work.
Past rides:
post #95 of 150 Old 02-05-2013, 07:36 PM
Update! CLOYES IS JUNK!!!!!!!! Didnt even make it a few days and I had a strange belt noise... Checked it tonight since its above 20. Removed the serpentine belt to verify the noise I suddenly had. Sure enough with belt off timing chain sounds like its coming through the timing cover.
I'm calling cloyes tomorrow.
Past rides:
post #96 of 150 Old 02-06-2013, 11:40 PM
HotRods_Punk&Oi88's Avatar
User is: HotRods_Punk&Oi88 is offline
Man that totally sucks! I was trying to remain optimistic about this non-tension chain but it seems like no one has had luck with it... Replacing a timing chain is not only very time consuming but it will leave you stranded if it fails, not something you want to chance it with. Let us know what Cloyes says if they even stand behind their product.
1995 Chebby S10,2.2, Auto, Reg Cab,Short Bed, Base Model.
Mods:5" / 4" Drop,Torq Thruts,Taurus E-Fan,Taylor Wires,Bored Throttle Body,Aeromotive Adj. FPR,Epay Intake,1.6 Roller Rockers,160 Thermostat,ASP Underdrive Crank Pulley,OBX Header & Downpipe,2-1/2" O.D. Magnaflow Glasspack.
More to come...
My boss is an Austrian Painter.
post #97 of 150 Old 02-08-2013, 02:01 AM
Ridin' on Twankies
colbye32's Avatar
User is: colbye32 is offline
Send a message via AIM to colbye32 Send a message via Yahoo to colbye32
So the few people that have installed these are having trouble nearly instantly.
Im not pointing fingers, but whos fault is it? The installer, or the manufacturer??
Keep us updated.
00' Noma, bagged, 20's, heat/ac, multicolor - Zq3-Specialty Road Head Package
colbye32 is offline
post #98 of 150 Old 02-08-2013, 11:19 AM
Mechnix's Avatar
if anything this cloyes set-up is easier to install than stock, having read how they tested this I'm not surprised.
The stock one goes well over 100K I don't know why people see that as a defect....
Mechnix is offline
post #99 of 150 Old 02-08-2013, 05:27 PM
I'm going to take it apart over the weekend. I'll take pics and start a new thread. I havent had time to contact cloyes, been busy with work.
Past rides:
post #100 of 150 Old 02-22-2013, 01:33 AM
Pony's got a nice rear
ratrace2's Avatar
User is: ratrace2 is offline
Those Cloyes guys really know how to lay "it" on Thick.
What a bunch of B.S.
The GM chain was fine, great even. The Cloyes tensioner was Crap.
That is the whole story.
Damn. That is Loud !!
ratrace2 is offline
