Motor mount replacement - S-10 Forum
post #1 of 16 Old 11-23-2004, 10:21 PM Thread Starter
95 S-10 2200
aperry62's Avatar
User is: aperry62 is offline
Send a message via AIM to aperry62 Send a message via MSN to aperry62
Hey guys, I'm pretty sure that I busted my drivers side motor mount. What do I replace? Is it actually the metal piece or the rubber insert? From what I've seen in the online parts stores they are just the insert. Anybody have any tips on how to replace it. I have a Haynes manual but it's pretty vague. Any help would be appreciated.
95 s10 2.2L B&W T-5 5spd trans 191k
aperry62 is offline
post #2 of 16 Old 11-24-2004, 04:14 PM
Registered Abuser
erronisme's Avatar
User is: erronisme is offline
Re: Motor mount replacement
its a real pain, your better off letting a shop do it.
Bye Bye 98 S-10 Bye Bye 76 Luv!! bye bye 63 Fairlane 500
post #3 of 16 Old 11-24-2004, 04:22 PM
drag~N~spark
DropindaS-Mini's Avatar
User is: DropindaS-Mini is offline
Send a message via AIM to DropindaS-Mini
i have the drivers side motor mount for sale $24 shipped.
the Haynes manual hardly helps out (its basically an over view of the truck) if you work on motors its not hard to replace but if you havent worked on motors then i would find someone to do the job.
guess whos back
"the best ideas come to me within seconds of each other"<- by Me
SSM PROFILE
under major construction
post #4 of 16 Old 01-03-2005, 12:36 AM Thread Starter
95 S-10 2200
aperry62's Avatar
I tore into my truck this weekend to replace the DS motor mount and found out that the metal mount that attaches to the block is broken. A piece is missing so I can't weld it back together. Does anybody know where I can get one and how much they cost?
aperry62 is offline
post #5 of 16 Old 01-03-2005, 02:09 PM Thread Starter
95 S-10 2200
aperry62's Avatar
anybody?
aperry62 is offline
post #6 of 16 Old 01-03-2005, 03:49 PM
meyers2211's Avatar
User is: meyers2211 is offline
Send a message via AIM to meyers2211
Not sure which one ur talking about theres a steel mount to the frame and then theres the mount thats bolted to the engine round circular wit rubber insert. Mine was broken because the rubber was ripped and u have to replace the whole metal and rubber piece attached to the block. $63 from gm ***Motor Mounts are not where u want to cheap out***
post #7 of 16 Old 01-03-2005, 06:40 PM Thread Starter
95 S-10 2200
aperry62's Avatar
It's the metal part that connects to the motor. It looks like there is a metal mount that is attached to the frame and another metal mount that attaches to the motor with the rubber insert joining the two. I have never seen the mounts apart but it looks like three pieces but maybe I'm wrong. The piece that connects directly to the engine is the piece that's broke. It looks like the corners where it's bolted to the motor broke off.
aperry62 is offline
post #8 of 16 Old 01-03-2005, 07:31 PM
meyers2211's Avatar
its only two pieces i believe the motor mount has three bolts and is kinda bitchy to get to. And of course the one long bolt that bolts the two mounts together. oh and be careful putting that long bolt back in i did my motor swap and cross threaded the passenger mount.
post #9 of 16 Old 01-03-2005, 09:04 PM Thread Starter
95 S-10 2200
aperry62's Avatar
so the two pieces you are talking about is the metal mount and the rubber insert? How does it mount to the engine? I really don't want to get rapped at the dealer.
aperry62 is offline
post #10 of 16 Old 01-04-2005, 10:32 PM
meyers2211's Avatar
the metal mount and insert are one piece mount by three bolts in the side of the block
post #11 of 16 Old 01-04-2005, 11:26 PM
Ground Patrol
TempoRaptor's Avatar
User is: TempoRaptor is offline
hey aperry62, does your CAT convertor rattle on the frame cause your motor mount is busted???
Ground Patrol - SoCal since 1996
"Could of had a Bentley but Id rather ride Chevy."
1999 Chevy S-10 - still in the family.
1999 Chevy C3500 Crew Cab 454 Big Block - "The Beast"
2000 VW Jetta TDI - Daily Driver - 41 MPG
post #12 of 16 Old 01-05-2005, 01:39 PM Thread Starter
95 S-10 2200
aperry62's Avatar
it does on occassion but hasn't since I pulled down on the downpipe a little bit.
aperry62 is offline
post #13 of 16 Old 01-09-2005, 01:47 AM Thread Starter
95 S-10 2200
aperry62's Avatar
Well I tackled the engine mount replacement. It took about 4 hours and I had to take the exhaust manifold and fender well out to do it, what a misserable location. But I figure that I saved myself about $260 doin it myself as oppossed to the guys at the dealer. Props to Meyers2211 on the motor mount, I have no idea why the parts house would sell just the insert but I found the whole mount on gmpartsdirect.com for $33 comapred to the dealer $60 so not all bad.
aperry62 is offline
post #14 of 16 Old 01-09-2005, 01:50 AM
drag~N~spark
if you need the metal brackets that bolt to the frame p/m me i have the pair for $30 shipped.
guess whos back
SSM PROFILE
post #15 of 16 Old 01-14-2005, 10:39 PM
RIP U.S.A. 7/4/1776-11/3/
big_taki's Avatar
User is: big_taki is offline
Send a message via AIM to big_taki
did you have a problem bolting it back on cause i am doing mine right now and i can get the top bolt on the right in but the bottom one just does not wanna line upits hitting the bracket on the frame. did you have that problem. if so what did you do
big_taki is offline
post #16 of 16 Old 01-16-2005, 08:02 AM Thread Starter
95 S-10 2200
aperry62's Avatar
Yeah I had a little trouble getting everything to line up again since it has been broke for awhile things kinda got bent. I used a big screw driver/prybar to get things into allignment. I also had to cut the little metal bushing off the rubber mount. There was a design change in that rubber mounts according to the parts guy at the GM dealer. Might try seeing if that would help.
aperry62 is offline
