Manual Transmission Fluid - S-10 Forum
post #1 of 35 Old 05-19-2010, 11:25 AM Thread Starter
User is: ewd199 is offline
I have 2000 5-speed chevy s-10 pickup. I just bought it and want to change the transmission fluid. Can someone tell me what type I need to use, and the capacity? Thanks
ewd199 is offline
post #2 of 35 Old 05-19-2010, 05:31 PM
I break stuff.
Hiigara's Avatar
User is: Hiigara is offline
Re: Manual Transmission Fluid
I use Royal Purple Synchromax - it's listed as a "transmission additive" but it's actually the fluid the NV1500 transmissions use. Usually 3Qt does it for me.
(Filling tip: Get 4ft or so of 3/8" ID Nylon tubing from Lowe's or somewhere, run it through your driver's side wheel well along the frame rail to the fill hole - makes it insanely easier to fill the transmission)
The trucks:
'98 2.2 ZQ8 - Flowmaster 40 Series, Kamikaze header. TD04HL-19T Remote Mount @ 6PSI
http://www.s10forum.com/forum/f30/pr...nturbo-503763/
'02 X-Cab LS 2.2, 220-amp home-rebuilt CS130D, 2xSony XM-2002GTR's, 2x Alpine Type-R 12".
Hiigara is offline
post #3 of 35 Old 05-19-2010, 07:11 PM
Powder Coat Specialist
xtrememeasures10's Avatar
User is: xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
I bought a 12ft garden hose, cut the ends off and to a reasonable length and a funnel. drop it down from under my hood put it in the trans and dump it in the funnel til its full.
97' w/ 03' Front end, Too many mods to list....
2.2L Build and Powder Coat Project
http://www.s10forum.com/forum/f105/2...ernals-486082/
Check out my Business Powder Coating work.
http://www.facebook.com/makpowdercoating
post #4 of 35 Old 05-20-2010, 12:18 AM
Tech Mod
beandip's Avatar
User is: beandip is offline
Also unscrew the fill plug first not the drain. if for some reason you cant get the fill plug off and the transmission is drained...well you get the idea.
-Jonathan
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #5 of 35 Old 05-20-2010, 02:05 PM
^^^ I dont know why i didnt throw that in. Thats very important, or your in for a big headache.
post #6 of 35 Old 05-20-2010, 10:32 PM
4 wheels aren't as fun
serpentracer's Avatar
User is: serpentracer is offline
just use 5w motor oil. it works a hell of a lot better than the over priced (basically atf) synchromesh fluid.
I've used synthetic motor oil in mine since 2000 or so.
02 sonoma 4.3L auto
97 sonoma 2.2L manual
post #7 of 35 Old 05-21-2010, 01:12 AM
Tech Mod
beandip's Avatar
^ not going to start shit but that has been covered before, i wouldnt do it.
-Jonathan
beandip is offline
post #8 of 35 Old 05-22-2010, 12:04 AM
already been done. been using it for more than 150k miles.
most transmissions use oil. just like a motorcycle does.
you can't use "gear" oil. it's way too thick. 5w motor oil is just about the same viscosity as the synchromesh.
02 sonoma 4.3L auto
post #9 of 35 Old 05-23-2010, 02:08 AM
BTR
misfitsbob's Avatar
User is: misfitsbob is offline
Can't you just take the shifter out of the top of the tranny and pour it in that way? I was told you can, but have never tried.
post #10 of 35 Old 05-23-2010, 12:02 PM
Registered Un-dependent
Mechnix's Avatar
User is: Mechnix is offline
Motorcycle oil has additives for the shearing that transmissions do to oil plus friction modifiers.... In the end it's your truck though..you could use water if you want... I use the Royal Purple and it fixed a problem with my 2nd gear syncro- smooth as silk now
Mechnix is offline
post #11 of 35 Old 05-23-2010, 07:35 PM
Better post-em.
comics22's Avatar
User is: comics22 is offline
owners manual should say...
i think my 95 is just reg ol 80w90 gear oil...
comics22 is offline
post #12 of 35 Old 10-29-2010, 11:14 PM
User is: 198s10 is offline
dam auto store sold me 80x90 gear oil for my trans, I didn't even look at the bottle. Well until the thing would not shift. Lucky for me i drained it they gave me a nice store credit and the right pensoil syncro oil for free! A good day.
198s10 is offline
post #13 of 35 Old 10-30-2010, 04:49 PM
User is: S10Clyde is offline
lol you could flip the car over, thus turning the drain plug into the fill plug
S10Clyde is offline
post #14 of 35 Old 10-30-2010, 04:57 PM
Team Sheen
TobyTheSandwich's Avatar
User is: TobyTheSandwich is offline
Ehhhhhh. Let us know if it didn't screw your transmission up bad.
Always check the bottle first.
Originally Posted by nomacane07 View Post
I promise we used a catch pan. That's what spilt out of the overflow when he pulled it out.
post #15 of 35 Old 10-30-2010, 05:45 PM
skfury440's Avatar
User is: skfury440 is offline
How bad was your 2nd gear syncro? Mine has been bad for about a year now, the transmission shop said it would be cheaper to find a used tranny but I still haven't found one. I might try that though if it actually made a difference, my syncro grinds anytime I shift into 2nd when I'm not at the right rpm. A lot of times it just drops right in but sometimes especially in the winter when it's easy to spin tires it just doesn't. Anything similar to what you had?
'64 Tbird 428P.I.
'01 S10 Xtreme
post #16 of 35 Old 10-30-2010, 10:15 PM
2nd gear grinded once today, but other then the one time she is smooth . The truck has 203,000 miles. New rear end is on its way and i may find a cheap low mile 5 speed to install in it.
198s10 is offline
post #17 of 35 Old 10-30-2010, 10:50 PM
chris14029's Avatar
User is: chris14029 is offline
where dose one even begin to search for the new venture tranny, i have never been able to find one. i dont need one mine is in perfect con. but just woundering
2.2l 2000 s10 5sp 188,000
Thrush glasspack muffler
e-fan mod
cold air intake
post #18 of 35 Old 10-31-2010, 09:43 PM
mikecrts's Avatar
User is: mikecrts is offline
I used Penzoil Syncromesh in my Jeep with a speed before I turned it into an all time trail rig and still use it after beating the piss out of the tranny and clutch. It is cheaper than the Royal Purple and I believe the same quality for less price.
mikecrts is offline
post #19 of 35 Old 11-01-2010, 10:03 AM
Team Sheen
what do you mean? the NV1500 can just be looked up by "s10 transmission" and the given year. It's pretty simple. Not many people go by transmission codes unless they are autos.
post #20 of 35 Old 08-18-2011, 06:12 PM
User is: chrisinator13 is offline
i stripped my bolt... anybody wanna send me one there arent using or tell me where to get a new one..?
post #21 of 35 Old 08-18-2011, 06:40 PM
always something new
S10dude's Avatar
User is: S10dude is offline
nope
All truck pics
S10dude is offline
post #22 of 35 Old 08-18-2011, 09:23 PM
Get it out w/ a large bolt extractor and get one from the dealer. or a hardware store dude.
post #23 of 35 Old 10-03-2013, 01:18 PM
User is: cobraearl is offline
Bought a used sonoma. 97 4.3 5spd... The Lub in the transmission is a Black Thin Oil.. I just put a slave cyl in it. drained the transmission and did not know whether to put it back in or replace... What the heck does the Correct stuff look like????? So far, its back in the transmission while if figure this out...
post #24 of 35 Old 10-03-2013, 02:48 PM
Mechnix's Avatar
Not super bad... just noticed it after buying truck, when it was cold and usually on the second shift into second it would act up... been fine now for years with the R/P-syncromesh
Mechnix is offline
post #25 of 35 Old 10-03-2013, 07:16 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
AC Delco Synchromesh friction modified part number 88900399. You need to buy 3 quarts and fill it till it runs out the filler plug while the truck's level.
Teamsters Local 1150
SH-60B is offline
post #26 of 35 Old 11-23-2014, 08:41 PM
User is: 5.3l_S10 is offline
Is the filler plug the big Allen plug on drivers side of trans and if so where's the fill plug
5.3l_S10 is offline
post #27 of 35 Old 11-23-2014, 09:24 PM
Fronk-en-Steen
mostizzle's Avatar
User is: mostizzle is offline
http://repairguide.autozone.com/znet...528006207d.gif
TelAmeriCorp
post #28 of 35 Old 11-23-2014, 10:11 PM
It's mostly BS
rimara's Avatar
User is: rimara is offline
My NV1500 has the 17mm filler on the driver's side.
2001 S10 2.2 5sp ext cab
Don't hit and run...let us know how you fixed it!
rimara is offline
post #29 of 35 Old 05-28-2015, 07:16 PM
User is: georuff is offline
How can I tell if I have an NV1500? I have an 03 S10, 2.2.
I went to the dealer for fluid and, even with the VIN # he couldn't tell me which trans I have. I checked and the fluid is a pale red color. My fill plug is a 17mm female hex on the driver side.
georuff is offline
post #30 of 35 Old 05-28-2015, 07:25 PM
It's mostly BS
rimara's Avatar
All 96+ S10/Sonoma 2.2s had the nv1500
rimara is offline
post #31 of 35 Old 09-22-2015, 12:56 AM
User is: EzinAZ is offline
https://drive.google.com/file/d/0ByZ...ew?usp=sharing
This is what you'll need to remove/install the oil plugs on the NV1500 manual transmission.
EzinAZ is offline
post #32 of 35 Old 02-23-2016, 05:11 PM
User is: erock12390 is offline
I just got my clutch done at a transmission shop (still under warranty). The guy replaced the slave cylinder while he was in there. The new clutch is great. I've even noticed an increase in gas mileage with it. However, it is sometimes hard to put the thing in gear.
Here's my guess: the guy at the shop put gear oil in my transmission instead of synchromesh. Could that be causing this problem?
Or did he put a junk slave cylinder in? Or is it my master cylinder?
Any thoughts?
post #33 of 35 Old 02-23-2016, 06:52 PM
Fronk-en-Steen
mostizzle's Avatar
If it's V6 truck or a 4 cylinder truck that's newer than 95 I'd be going back there and asking why they didn't put the recommended fluid in the transmission. They need to rectify the situation one way or another.
TelAmeriCorp
post #34 of 35 Old 02-24-2016, 06:35 PM
Better post-em.
comics22's Avatar
these slaves are a pain in the ass to bleed ive heard, took the local shop 2 times to get most of the air out otherwise it grabbed about an inch off the floor...
comics22 is offline
post #35 of 35 Old 02-25-2016, 09:03 AM
MEP1's Avatar
User is: MEP1 is offline
Like comics said the clutch should be fully disengaged long before the pedal hits the floor. Next time you have trouble getting it into gear try pumping the clutch 4 or 5 times fast and see if it's better. It might need to be bled properly.
MEP1 is offline
