Lights flicker...voltmeter-up and down. HELP! - S-10 Forum
post #1 of 11 Old 10-22-2009, 11:06 AM Thread Starter
User is: dlmack1 is offline
Ok guys, I need help......yes I have read every thread on the flicker/voltmeter problem, but it seems when people get it fixed...they don't post.
Problem.....driving on the highway lights (dash/or headlights-headlights do not have to be on) will flicker quickly...voltmeter ticks in unison with the flash. Sometimes.....voltmeter will slowly drop to 10, then back up to 14 (65 mph).
Truck at idle or driving (normally) is a constant 14...turning anything electrical on does NOT bring the voltmeter down...always 14.
And...it doesn't always happen...I could drive 2 or 3 days...fine.....4th day, it happens.????????
What are the symptoms of the headlight switch????, but again...the headlights do not have to be on for this to happen......Relay??????
If it's the alternator, fine I will replace.....I just don't think so.....volts are always at 14 or slightly above...no matter what I turn on.
items checked:
New Battery
new positive battery cable end
cable end at alternator new
new negative batter bolt
all terminals cleaned
new starter about 6 mos. ago
new fusible link (wire)
1997 s-10 2.2 auto, air (not hooked up) 190k
Thanks for your help!!!!!!!!
dlmack1 is offline
post #2 of 11 Old 10-22-2009, 02:21 PM
Po Po
walker01s10's Avatar
User is: walker01s10 is offline
Re: Lights flicker...voltmeter-up and down. HELP!
It sounds like maybe the regulator in the alt is going bad.
Does it do it at an idle if so take a volt meter and hook it to the batt and watch the volts to see if it jumps there If it does then it's def the alt regulator. When my regulator starts to go bad on my custom alt that is one of the signs that its about to go out. My volt gauge will bounce around and my lights will flicker.
post #3 of 11 Old 10-22-2009, 05:55 PM Thread Starter
Unfortunately, it only seems to do it when I am going over 50mph....if it did it at idle, that would be great......I could test and see what's going on....but its rock solid at idle and slow (city) driving.
Thanks for your input...I was leaning towards just throwing an alternator in there.....just wanted someone to say "hey, mine did that when my alt was going".....exactly what you said...
Thanks!
dlmack1 is offline
post #4 of 11 Old 11-10-2009, 07:20 PM
User is: chevyman1759 is offline
My Truck does the same thing at idle and at 50 mph.I also get a buzzing noise in the radio.Sounds like I have solid core wires on it.Could it be the regulator ?It's a 02 pickup ZR2 with 105,000 on the ticker.Any ideas?
post #5 of 11 Old 11-11-2009, 07:29 PM Thread Starter
well, replaced the alternator......was fine for a week, now back to the same......I am ready to drive it off a cliff!!!!!
could a bad headlight switch do this??????? truck was fine on the way home tonight, turned the lights on, and about 10 minutes later, the gauge started dropping again.........
Anyone??????
dlmack1 is offline
post #6 of 11 Old 11-11-2009, 07:51 PM
User is: kc5gxc is offline
Mebbe its your grounds. Clean all grounds and recheck battery cables...cheap to do.
Good Luck........Pete
kc5gxc is offline
post #7 of 11 Old 11-11-2009, 10:44 PM
User is: jstanley is offline
There is a fix.... I even have the directions for it, but since they refer to all sorts of part #s I don't know, they may as well be in Hungarian.
All I gathered was that a wire is used to bypass a function.
Since I have had the alt replaced (it croaked) and no change, I suspect the alt/regulator is not the issue.
Grounds, battery cables etc all good.
jstanley is offline
post #8 of 11 Old 11-12-2009, 07:16 PM Thread Starter
Can you give me a little more detail???does it say where this bypass wire goes and what it is actually bypassing?????or in what area its in??
Thanks in advance.....
dlmack1 is offline
post #9 of 11 Old 11-12-2009, 08:03 PM
When and if I find the paper with the info, yes.
Maybe it will mean something to you.
jstanley is offline
post #10 of 11 Old 08-09-2010, 05:05 PM
child at heart
gregoneck's Avatar
User is: gregoneck is offline
Send a message via Yahoo to gregoneck
bumping this to see if anyone ever got this issue fixed.
my truck is doing this voltage flicker at and above 75mph. rpm has no effect on it and i'm sure it's speed related. below 75, it fine.
it's been doing it for a very long time but the speed at which it does it at has been slowly dropping over the years.
75mph is really starting piss me off.
any updates for this problem?
98noma xtcab stepside zq8 double deuce
05 GTO 402 M6
Some people are like slinkies, they're not really good for anything but they can bring a smile to your face when you push them down a flight of stairs
post #11 of 11 Old 11-11-2011, 08:27 PM
S10Beef's Avatar
User is: S10Beef is offline
I know this is an old thread but just posting cause no one else posted the solution. I to had the same problem. headlights flickered between 60-75 mph, but never did any other time. Replaced the alternator, did the sense wire trick, new battery, all the grounds where re grounded.....still the same thing. Turns out my speedo was also randomly jumping between 60-75 mph. Changed the VSS and not only did the the speedo work flawlessly, the headlight flicker is gone. So before spending tons of money, as long as your alt is putting out what it should check your vss sensor first. It will cost you 50.00 bucs. Not sure what the VSS has to do with the dash lights and headlights flickering but it fixed it. I needed all that stuff anyway so i wasn't wasting my money, but it did drive me crazy for two months. Hope this helps someone.
S10Beef is offline
