Installing head....need torque specs - S-10 Forum
post #1 of 9 Old 04-27-2009, 07:58 AM Thread Starter
Body Draggin Member
SlammedWhitey03's Avatar
User is: SlammedWhitey03 is offline
Send a message via AIM to SlammedWhitey03
Dad just had his 2.2 rebuilt and is installing the head back on the motor. I found the specs on the head bolts, but I need to know if there are any specs on torquing the lifters? It's a '96 model 2.2 if it makes and difference in the years.
Thanks,
Chris
sig
post #2 of 9 Old 04-27-2009, 11:23 AM
Zr2.2
BillsDuster's Avatar
User is: BillsDuster is offline
Re: Installing head....need torque specs
I'm guesing your talking about the rocker arm nuts. If so the spec for 94-97 is 22 ftlbs
FOR SALE: 1998 S10 Ex-cab 2.2, 5 speed, locked 4.56 rear, 4 wheel disc brake swap, Fabtech spindles, Fabtech long travel, SOA rear, 31/10.5 BFG's
Daily: 1995 Blazer LT, 4.3, 4l60e, ORD SAS HPd30, xploder 8.8, 35's
Full Resto Someday: 1974 Ramcharger SE, 360, auto, 4x4, rust free from AZ. Keeping it stock...maybe
BUY ME: $250 shipped, Powertrax No-Slip GM7.5" 28 spline axle. PM if interested
post #3 of 9 Old 04-27-2009, 10:39 PM
joining 2.2l boosted club
1tuffs10's Avatar
User is: 1tuffs10 is offline
i dont know if this helps any but here are some toque specs from my haynes book for s10/blazer 94-2004
camshaft sprocket bolt ........................................96
camshaft thrust plate bolts ..................................106 in-lbs
crankshaft pulley bolts.......................................... 37
crankshaft pulley/hub-to-crankshaft bolt...................77
cylinder head bolts
step 1
long bolts............................................. ..........46
short bolts............................................. .........43
step 2................................................. .............tighten additional 90*
engine mount-to-engine bolts.................................39
engine mount through bolts....................................38
engine mount bracket-to-frame bolts.......................33
exhaust manifold nuts...........................................115 in-lbs
flywheel/driveplate-to-cylinder head nuts/bolts
through 1998.............................................. ......24
1999-later............................................. ...........17
lifter guide retainer-to-block-stud............................97 in-lbs
oil pan bolts............................................. ............89 in-lbs
oil pump-to-block bolt............................................32
rocker arm studs............................................. ......37
rocker-arm nuts (bolts on 1999-later).......................19-22
timing chain cover bolts..........................................97 in-lbs
valve cover bolts............................................. ......89 in-lbs
2000 xtreme top mount twin scroll t3 header/custom 2.5" straight pipe/ac-delete/56mmtb/lowered 4"/ 44lb injectors/hptuners software tuning/baby blue H.I.D kit/carbon fiber ram air hood/ electric fan conversion/ Turboed with T3/T4 running at 9psi e-85/msd ignition/nkg plugs 2 steps colder/.63 ar hot/50 cold compressor
1tuffs10 is offline
post #4 of 9 Old 12-02-2013, 02:41 PM
User is: hwes is offline
step 2 on head bolts,what is it ?
are rocker arms torqued while valve is in any position ?
hwes is offline
post #5 of 9 Old 12-02-2013, 02:47 PM
Step 2 on head bolt torque is not in my stats, what is it ?
are rocker arm nuts torqued with valves in any position ?
hwes is offline
post #6 of 9 Old 12-02-2013, 05:14 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
Step 2 on the head bolts is to tighten the bolts down an extra 90 degrees (1/4 turn) to stretch the bolts. Do it with a breaker bar. This is in addition to the torque specs mentioned in step 1. The bolts are torque-to-yield, that's why they are one use only. Don't re-use old headbolts, they've already been stretched.
I torque the rockers with the valves closed, this way you're not fighting the spring and screwing up your reading.
Teamsters Local 1150
SH-60B is offline
post #7 of 9 Old 12-02-2013, 07:53 PM
metalhdmatt's Avatar
User is: metalhdmatt is offline
there is also a pacific torque pattering... look at my pic!
2002 S10 2.2L, EX.Cab, 5 speed, 4:10 rear end, Electric fans, Custom intake, Under Drive pulleys, CAT delete with O2 simulator, Dropped 3/4 rolling on 245/45/18, Street Performance shocks, BIG 3 upgrade, 200A Alternator, (1) Sundown 12" ZV4 REV2 in custom ported box, Sundown SCV-2000D pushing, Alpine Type-R in dash, doors & rear custom box build, Alpine PDX-F4 pushing. Alpine CDE-HD149BT head unit
[/B][/FONT][/COLOR]
post #8 of 9 Old 12-03-2013, 09:46 PM
2Low2Tow
GmcNoma95's Avatar
User is: GmcNoma95 is offline
This thread is about 5 years old. If the guy didn't figure out torque specs by now then he's in trouble. Stop bringing up old threads!
PROJECT NOMA ~UNDER DE-CONSTRUCTION!~
1) 2/3 DrOp Kit
2) Rebuilt 4L60E Trans. W/ Performance Parts.
3) Rebuilding a 2.2L into a Stroker motor
Re: Driveshaft vibration when pulling out???? Quote: Originally Posted by s10xtremist Stop pulling out.
Originally Posted by rimara View Post
People are willing to help you...they just don't want to burp and diaper you.
post #9 of 9 Old 12-03-2013, 10:17 PM
why don't you try reading in the middle of this thread to find that someone "actually" searched for a answer and found a old thread, then figured out he couldn't get the knowledge that he needed to carry on so he asked a question... this is what really pisses me off about this forum, instead of people answering questions they bitch about everything else other than just answering them... if you dont want to answer questions, don't comment or don't be apart of a ****ing forum!!!!! thank!!! matt...
[/B][/FONT][/COLOR]
