Ignition switch problems - S-10 Forum
post #1 of 15 Old 02-01-2010, 06:34 PM Thread Starter
User is: smkummer is offline
Maybe someone here has had this happen. When turning the switch from lock one click to unlock, the batt. light comes on and the odometer lights up ( I believe on unlock-nothing should light up). Then when going to the run position, the radio and fan works but the fuel gauge and voltmeter are dead. When going to start, nothing happens. All fuses checked good. This is a 2001 extreme 4cyl. manual. Any ideas? thanks ahead of time. Mike
smkummer is offline
post #2 of 15 Old 02-01-2010, 11:00 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
Re: Ignition switch problems
Weak battery, poor battery connections, broken starter, clutch interlock switch, clutch not pushed down (that last one's kinda dumb)
Teamsters Local 1150
SH-60B is offline
post #3 of 15 Old 02-02-2010, 10:47 AM Thread Starter
Thanks for your time and thought. New battery, battery conections tight, "new" rebuilt starter just installed, need to check clutch switch as the clutch master cylinder was just replace and maybe something got jarred. I will remove the underneath cover and look for any loose wires.
But why would the battery light and odometer come on if the key was moved from off/lock to off/unlock? Sure appears to be switch problem. I did download from here what appears to be the factory procedure to R&R the ignition switch.
smkummer is offline
post #4 of 15 Old 02-02-2010, 02:46 PM
It's "Neanderthal"
SH-60B's Avatar
If you had this problem right after changing the ignition switch, then it's likely some problem with the installation. I think that first switch position is "acc", and the radio should work, the second is "on" and the fuel pump should prime and dash will come on and all electric stuff will work, then there's "start".
Is there an adjustment?
SH-60B is offline
post #5 of 15 Old 02-03-2010, 02:44 PM Thread Starter
I never changed the ignition switch. The first position foward of lock/off is unlock, and it allows the wheel to turn. The only position back from lock/off is acces.. Again it is a 2001 extreme and were have a owners manual from a 2001 sonoma. We are using after market cut keys with no resisitoror transponder. I did notice in the GMC manual that the ignition needed the correct coded key. I wonder if that was a option on the 2001 chevys. This problem just started after my son lost his last remaining factory key. But the vehicle has worked fine with the aftermarket keys before.
smkummer is offline
post #6 of 15 Old 02-03-2010, 03:00 PM
forum idiot
orangesonoma's Avatar
the keys are no coded...no s-series was...the code is built into the ignition switch
but it can be the switch .. i have replace a few...did a pontiac grand prix the other day...it was also a 2001
Brian
orangesonoma is offline
post #7 of 15 Old 02-03-2010, 09:45 PM
A CLEANMACHINE's Avatar
User is: A CLEANMACHINE is offline
Send a message via Yahoo to A CLEANMACHINE
i had a wierd problem w/my switch.turned off night b4 andin the am the interior lights were still on tried to turn on and it jammed could hardly turn off so i sprayed it with wd40 about a yr ago and it's worked fine since you should try it just for kicks.
99 ext cab auto, 7psi mitsu 14b turbo,ported and coated 2 1/2'' exhaust to turbo muffler,fake cat,underdrive pulley,efan,2.3 t/b,42lb racetronix inj,4.3 fuelpump,aem wideband,pyrometer,f/press guage,.lowered rear 2'',hhr seat , counsole,and finished fabbed cowl hood.
post #8 of 15 Old 02-08-2010, 06:54 PM Thread Starter
Re: Ignition switch problems 2001
Can anyone tell me if the ignition switch on a 2001 s10 is located under the steering wheel column? I have the procedure for the 1995 to 99 models but the switch appears to be under the colum instead on top. Thanks ahead of time
smkummer is offline
post #9 of 15 Old 02-10-2010, 02:26 PM
NOT AN S10
tg900's Avatar
User is: tg900 is offline
Send a message via AIM to tg900
probably not a good idea with wd-40 near electrical parts, maybe some lectra clean from CRC? Might be a safer choice, i'm not an electrical guru though
Originally Posted by hedgehog View Post
..... I know the truck better than my wife and have also found it to be more dependable than my wife.
ELTC NEPA
tg900 is offline
post #10 of 15 Old 02-14-2010, 03:02 PM Thread Starter
Re: Ignition switch is NOT the problem
OK, we swapped the switch and nothing changed! Again, when moving from lock/off to unlock, the batt. light and odometer lights up. When going to on, the radio and fan come on but no idiot lights come on,guages are dead and no fuel pump. Then when going to start, the starter does not work but the lights turn off.
smkummer is offline
post #11 of 15 Old 09-11-2013, 12:57 PM
User is: sailnut is offline
Hello i have the same problem on my 2001 S-15 What was the fix?
sailnut is offline
post #12 of 15 Old 09-11-2013, 02:31 PM
It's "Neanderthal"
SH-60B's Avatar
Test the starter relay.
SH-60B is offline
post #13 of 15 Old 11-01-2014, 10:45 AM
User is: Sledfreak is offline
To Orange Sonoma: The passlock security is not built into the ignition switch it is built into the lock cylinder and has to have the correct ohms to operate. This can be bypassed with the correct parts from radio shack. I'm betting he has a faulty ignition switch itself.
post #14 of 15 Old 11-01-2014, 11:57 AM
It's "Neanderthal"
SH-60B's Avatar
That was almost 5 years ago, lol, wecome to the forum tho
SH-60B is offline
post #15 of 15 Old 11-01-2014, 12:48 PM
always something new
S10dude's Avatar
User is: S10dude is online now
All truck pics
