I need a more serious heater core flush suggestion - S-10 Forum
post #1 of 13 Old 01-19-2011, 07:44 PM Thread Starter
mklimek4's Avatar
User is: mklimek4 is offline
heat has been a problem since i just bought my truck (94 s10 pickup 4cyl), replaced the thermostat and then deduced that my heater core was obviously quite clogged (in-flow is very hot, out-flow was cold).
so i took it to a self serve car wash, and stuck the nozzle to the in-flow pipe and now the in-flow is very hot, out-flow is only luke-warm, making the inside heat work maybe 40-50% of its whole power.
the truck i bought, had been sitting for about a year so i figure the is alot of buildup of gunk in the heater core, so is there anything else anyone can suggest that i throw at it (or in it more-less) to clean this thing out?
Id prefer a method that would be quick, but all suggestions are welcome (and i live in an apartment with no water-hose)
maybe i should go back and put the power-washer through the out-flow tube of the core and let it flow out the other in-flow tube too? or will the pressure maybe hurt the core?
thanks-
Mark
mklimek4 is offline
post #2 of 13 Old 01-19-2011, 08:10 PM
User is: crash55 is offline
Re: I need a more serious heater core flush suggestion
get a new core
crash55 is offline
post #3 of 13 Old 01-19-2011, 08:58 PM
4 Doors FTW
LUVMY02CREW's Avatar
User is: LUVMY02CREW is offline
I don't think you should try putting a power washer to it again. I think you dodged a bullet on that one.
I know you said you live in an apartment complex with no hose-pipe available, but that would be the best thing to use IF you could find one. An easy back and forth a few times will get some stuff out. Then maybe try putting some of the prestone cleaner in and let soak for a while before flushing with the hose-pipe again.
Maybe that will save you from getting a new core right now. Hope that helps a little.
2002 S10 Crew Cab, Black, 4WD, 4.3 Auto
I'm just trying to keep this beast running as long as possible.
post #4 of 13 Old 01-19-2011, 10:44 PM
gmo
Fixer of Everything broke
gmo's Avatar
User is: gmo is offline
i say a new core cause what says that it wont happen a little down the road its only 38.00 a advanced auto parts
gmo is offline
post #5 of 13 Old 01-20-2011, 02:24 AM
User is: Tomcat1983 is offline
If you put in about a cup of CLR and run the engine warm for about 15 minutes, heater cranked high of course. This should break down the calcium deposits that are causing your problem. I wouldn't recommend any longer due to the fact that the CLR "could" cause some issues with seals. A plugged heater core is caused by people not putting "Distilled water" and quality coolant in the cooling system. I'm not saying that this is the end all be all to fix your issue but it's easier then tearing the dash out to change a heater core. (not so much fun from experience)
Tom
post #6 of 13 Old 01-20-2011, 02:39 AM Thread Starter
mklimek4's Avatar
sounds good everyone, also does anyone think the prestone radiator/coolant system cleaner would do anything?
and on the note of heater core install, the only heater core ive ever installed was on an 85 caprice (which is all under the hood) so it was easier than anything.
but as for s10`s, my haynes book says i need to disconnect the steering column and other stuff, is the a heater core install really this complex on these trucks?
mklimek4 is offline
post #7 of 13 Old 01-20-2011, 10:38 AM
B4U Task Force
Rhotpursuit's Avatar
Get the cleaner, not the flush. Follow the directions, then find someplace to flush heater core in both directions...not the pressure wash.
BTW...it is a pain in the butt to change the core.
U.S.C.G. "So others may live"
Apple Red 96 SS
post #8 of 13 Old 01-20-2011, 10:46 AM
B4U Task Force
This really will not make a difference in our trucks as there is no water shut-off valve to the core. Heat is determined by an electric door on top of the core case.
Apple Red 96 SS
post #9 of 13 Old 01-20-2011, 01:15 PM
Bills Dad's Avatar
User is: Bills Dad is offline
I believe the complete dash board has to come out to do the core, just like the v-6. Takes the usual guy probably 6+ hrs...not fun
1997 S10 reg.cab/base, 4wd. L35
1997 Gmc Sonoma sl 4 banger
post #10 of 13 Old 01-20-2011, 03:14 PM Thread Starter
mklimek4's Avatar
just on the off chance it may work, i switched the in and out hoses to back flush the system, and now its blowing out scolding hot. cant believe it worked.
but now im worried that there is some amount of crap floating around my system. should i drain the system and refill?
mklimek4 is offline
post #11 of 13 Old 01-20-2011, 03:35 PM
lol good point, my bad.
Tom
post #12 of 13 Old 01-20-2011, 03:36 PM
Can't hurt for the cost of it.
Tom
post #13 of 13 Old 01-20-2011, 04:12 PM
gmo
gmo's Avatar
yeah replacing the core is a pain but also it gives you that piece of mind
gmo is offline
