I have no idea what is wrong with my truck. HELP! - S-10 Forum
post #1 of 15 Old 11-10-2010, 02:08 AM Thread Starter
Jae_Hampton's Avatar
User is: Jae_Hampton is offline
Hey, I have a 2000 Chevy S10 2wd 2.2L 4 Cylinder automatic. It is hard to explain what my truck is doing but ill try to explain it and hopefully you guys can understand. I stop at a stop sign or a stoplight and then when I push the accelerator to go it like hesitates to go, like it putt putts and then it doesn't accelerate anymore after a few seconds. (The truck is still running and everything) It kinda feels like if no gas is going to the motor or something. So then I have to put it in park, turn off the truck and then turn it back on and everything is good. It happens once or twice every time I drive it. Does anyone might know what this can be? I took it to the shop and they ran all sorts of tests on it and they said they couldn't find anything wrong with it.
-Thank you!
Jae_Hampton
post #2 of 15 Old 11-10-2010, 02:38 AM
always something new
S10dude's Avatar
User is: S10dude is offline
Re: I have no idea what is wrong with my truck. HELP!
that's a default limp mode and you reset it when you shut it off so it comes
out of limp mode....mine did that and it was the connection at the big fuse box under hood for relays..the battery connection from battery was dirty and the ecu was getting a bad connection for power. clean all battery connections and grounds
All truck pics
S10dude is offline
post #3 of 15 Old 11-10-2010, 02:47 AM
The photo terrorist
postal's Avatar
User is: postal is offline
I have had similiar symp from simply a clogged fuel filter .Power would come on and off .Just a simple suggestion if electrical is good as stated above ..
Quote: Originally Posted by dannyboy954 Postal never seems to fail with the Gifs or Pics. LOL
Wanted!!! 96-97 2.2 5 spd b&m or hurst short throw shifter ,nv1500!!!!! Let me know if you have one!
postal is offline
post #4 of 15 Old 11-10-2010, 05:55 PM Thread Starter
Alright cool. Thanks! Ill go check that out right now.
post #5 of 15 Old 11-10-2010, 05:58 PM Thread Starter
Yeah I got a couple people saying the same thing. The guy at the shop said it was fine and if it was the fuel filter then the problem would be going on all the time. But I am going to buy the fuel filter anyways and put it on myself, it wont hurt. Thanks you!
post #6 of 15 Old 11-10-2010, 06:33 PM
johnny drama
98_noma's Avatar
User is: 98_noma is offline
i would look at the throttle position sensor
98_noma is offline
post #7 of 15 Old 11-10-2010, 09:32 PM
User is: 2Wheelz is offline
I've got a 94 2.2 with the same issue.
New fuel pump (just last week)
New fuel filter about 7k miles ago
New 02 sensor about 10k miles ago
New throttle body sensor about 10k miles ago
still keeps cutting out on me, it hesitates only when at lower speeds, flat out dies sometimes at stop signs or stoplights, chugs like a fuggin frog on crack and nobody can seem to figure out what it is. i'm DOA right now, had to pull over. the thing is, i drive all over the place. lately it's been on a tow truck more than it's been under my command, seems like.
2Wheelz is offline
post #8 of 15 Old 11-10-2010, 10:49 PM
Better post-em.
comics22's Avatar
User is: comics22 is offline
a sticky EGR valve will do this. simple test is to undo the vacum connection to it, plug the vacum line with a golf tee or bolt and try driving it around.
comics22 is offline
post #9 of 15 Old 11-12-2010, 05:42 PM
You might want to check (or have checked) the idle air controller. I'm told now, this has been the issue all along. I have spent almost $2,000 throwing parts at it for the last year. The IAC was the first thing that was changed! But I'm being told now by a dealership mechanic that not only was it installed incorrectly, but that it was installed with only one gasket, and it supposedly needs two.
I'm looking at parts sites for said gasket, but can't find it. I can find IAC's all over the place, but not seeing gaskets sold with it. I'm really at the mercy of whatever a mechanic says, because when the truck is not running it ends up at "Joe's Shop" usually on a tow truck. Not a mechanic, lol, i just wish i was in my spare time to rake in the $100 hourly diagnostic fees.
2Wheelz is offline
post #10 of 15 Old 12-01-2010, 08:31 PM Thread Starter
I have changed the fuel filter and had some more people checked my truck out to see what the problem is and still no one can find what is wrong with the stupid thing. I talked to a friends friend of mine and he said he has had the same problem. He told me if I put any additives like octane booster in my fuel tank, and I said yes. (Right after i did so, that is when the problem actually started happening) He told me that the additives effect the catalyst converter. He said once he replaced it, that the problem never happened again. So I'm going to replace it and see what the result is. Has anyone put additives in the fuel tank and had this problem??
post #11 of 15 Old 12-01-2010, 08:37 PM Thread Starter
I meant to say Catalytic Converter.
post #12 of 15 Old 12-03-2010, 02:24 PM
Varides.com
Stehl's Avatar
User is: Stehl is offline
Send a message via AIM to Stehl
TPS sensor. Or check your electrical.
To check the tps just hook up a scanner and monitor the truck while running or off. The tps voltage should go up with the gas pedal down and voltage should decrease when let off.
The Virginia Rides Forum
http://varides.com
Stehl is offline
post #13 of 15 Old 12-03-2010, 09:11 PM
Broke down
User is: black2002ls is offline
The catalytic converter should throw a code for down stream O2.
However, I've had a similar issue, the cat came apart and left a "ball" inside, this ball would make its way back and block off the exhaust and cause the engine to choke itself out.
post #14 of 15 Old 12-03-2010, 11:43 PM
User is: boostedef123 is offline
Before you wast 2-300 dollars on a new cat!!!!!!! Plug it up to a scan tool. Nothing worse than a parts hanger. Any decent shop will have one that can monitor the flow through the cats from the o2 sensors. I highly doubt it would be the cat.
post #15 of 15 Old 12-04-2010, 12:36 AM
monkeytruckin's Avatar
User is: monkeytruckin is offline
Mine was doing the same thing. I replaced my trans filter, fluid flush, installed a new tps sensor and fuel filter. I figured all needed changed. I wish I would of figured out which was the culprit, but I figured all needed replaced.
86 Blazer 4x4 2 Dr Tahoe... Clean DD...
'97 Blazer 4x4 4 door... parts are being gathered...
