a blown member
dsi racing founder Age: 33
Ross Racing Engines
Location: Aggieland, College Station, Tx User is: OffLine |
Re: HPtuners 97-00 2.2's available in beta
about damn time!...lists the 97, with then engines that year going from 95-97. Anyone know if they had a significant change to the PCM in 97 that would make this not compatible with the two years prior?
a blown member
I would say if you have a question on why they dont support & when/if they will post up in that specific section of the forum...they had a poll a few months ago & those were the most requested so they started work on them www.hptuners.com but voicing your opinions on what you'd like to see is probably the best way to get what you want.
what is this thing and what can you do with it? it looks way over my head
WHAAAh?
Location: IOWA, land of Corn and Pork User is: OffLine |
Yeah.........exactly..........is it a program that we can hook up to our trucks or what is it and what can it do for us?
Ross Racing Engines
It's the necessary hardware and software to allow editing of the PCM. Allows you to change things like injector pulse, timing curve, all the stuff you need to adjust when installing a big cam or boost. Cam profiles have been limited with the 2.2 because there was no way to edit the timing with the stock PCM. Now, you can have a custom cam ground and then tune it. I'm sure that the aftermarket will boom because of this as well.
WHAAAh?
So if you have stock internals it really means nothing to you?
Ross Racing Engines
With just a stock motor, I'm sure you can use it to find some power through fuel and timing. It will allow you to tune each cylinder individually. Would it be worth the $500 on a stock motor? Probably not, but then that's just a guess as this is a new product with not much test data available.
a blown member
its a pcm editor & data logger so you can gather information about your computer & tune it to your needs rather then just some canned tune...fuel, spark, TM, shift points, tire size changes you name it it can do it and do it well
they support hundreds of year/models of cars/trucks/suv's and are expanding to offer tuning support to fords/chryslers so no matter what you buy they'll probably support it. |
a blown member
Ross Racing Engines
Chivalay Mane
awesome, bout time huh
97!?! should they work for 96? That would be hella nice since I am planning on building up the 2.2 in my truck as soon as I pull in out and put the fresh one in. |
Ross Racing Engines
a blown member
if theres no market for something its hard to justify spending time/money on coding/research. |
any idea if their software will allow you to edit other codes like ABS sensors or A/C codes?
the reason i ask is for those of us that have removed the ABS system and A/C (as well as other components) and need those systems disabled to pass smog. check engine lights make for a hard time with the smog nazis. |
a blown member
good deal, i'll get those codes for you in the next few days.
ol' bodybuilder
I have a '97 S10, 2.2L. I see where the standard VCM Suite is for 97-00 S-10 (beta). I was trying to figure out (via credit explanation) if I could just tune my vehicle once ar mant time as I want or any other cars. I thought it said once you insert Single Vehicle and Year/Model credits you can use it on any '97 S-10 2.2 - is this correct?
I think I'll wait until the tuner is out of beta. Any idea when that'll be? thnx |
ol' bodybuilder
I know a there a few different models that switched in '95 (but not many). I don't believe that a '95 S-10 was OBD II. It would seem llike if it works for '97, it should also work for '96 - unless there's other "electronic" type changes I'm not aware of. |
a blown member
vin locked means you can tune your vin as many times as you want...the year license you could tune your 97 and as many other 97's as you can find. But with the credit upgrade scheme even if you vin lock you'll be able to upgrade to the year license at a later time without fear of having to keep vin locking vehicles its a great system that is very flexible & allows the user to make a decision if they just want to work on their own vehicle or 100 knowing they'll at least get back 75% on their investment. When a version is in beta the people testing the product give feedback on its developement ie what they like, dont like & what they'd like to see. I've been a beta tester for almost a year now and I love knowing I had something to do with the ongoing development of a product.
a blown member
#24 |
ol' bodybuilder
#25 |
a blown member
#26 |
a blown member
#27 |
Rhasta the Lobstah
I am definitely interested in this...
#28 |
a blown member
if you decide to purchase & need any help let me know, I'll help you as much as I can.
#29 |
looks like i found something i can play with next on my truck
#30 |
tu-tu guru
lol, its been out awhile now
Atleast you're searching |
#31 |
Y doesn't anyone ever make these for 2001?
#32 |
boosted 2.2L
#33 |
has anyone bought this software/ kit for the s-10 in stl?
I need a tune baaaad... i am running excessively rich with my turb kit |
