How to replace a belt tensioner? - S-10 Forum
post #1 of 26 Old 01-30-2008, 09:04 AM Thread Starter
User is: Jizz is offline
Anyone have write up on removing the belt tesioner on a 2003 S10 I4?
When you start the truck it makes hideous rattling sound. I thought OMFG the engine is toast but under further investigation I found that the belt tensioner is "rattling" "shaking" like crazy.
Jizz is offline
post #2 of 26 Old 01-30-2008, 01:44 PM
NOT AN S10
tg900's Avatar
User is: tg900 is offline
Send a message via AIM to tg900
Re: How to replace a belt tensioner?
i'm pretty sure there's three bolts...the pulley cracked on my 95, so i replaced the whole thing, there should be three bolts near the alternator, they were a pain to get to but i got them without taking off any other stuff. i haven't had to look at the tensioner on my 98 yet but i'd assume its the same thing
I checked advance/autozone...autozone has two different part numbers, advance has the same for 94-03. it goes for like $67, i thought it was like $30 when i changed mine a year ago
Originally Posted by hedgehog View Post
..... I know the truck better than my wife and have also found it to be more dependable than my wife.
ELTC NEPA
tg900 is offline
post #3 of 26 Old 01-30-2008, 01:46 PM
NOT AN S10
tg900's Avatar
I found a picture of my old tensioner...hope this doesn't happen to anyone
ELTC NEPA
tg900 is offline
post #4 of 26 Old 01-30-2008, 01:51 PM
viperstd's Avatar
User is: viperstd is offline
that happend to mine last time I took my belt off.
You just take a belt tool and remove the belt and bolt it. Like the previous posts mentioned its a few bolts. Bolt up the new one, use the belt tool again and reinstall the belt (this is a great time to replace the belt if it needs it). All said an done, this is a 15 minute job and one of the few things that is easy to do on these trucks
1999 S-10 Ext.Cab | 167k Miles | 2.2L | 5 spd | 4.10s
viperstd is offline
post #5 of 26 Old 01-30-2008, 03:44 PM Thread Starter
Did it this morning. Will post a HOW TO in a bit
Jizz is offline
post #6 of 26 Old 01-30-2008, 11:35 PM
NOT AN S10
tg900's Avatar
belt tool = 3/8 socket wrench
ELTC NEPA
tg900 is offline
post #7 of 26 Old 01-31-2008, 08:13 AM
viperstd's Avatar
I own a 600+ toolset, and nothing clears by fan other than a belt tool. believe my, i've bled trying
viperstd is offline
post #8 of 26 Old 01-31-2008, 08:50 AM
Forum Dictator
What?'s Avatar
User is: What? is offline
I used standard 3/8 craftsman, no problem with clutch fan in way either, just work it in between blades, but eh at least you got the belt tool
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #9 of 26 Old 02-02-2008, 10:05 PM Thread Starter
WOW just WOW!
We need a "HOW TO" section.
I did not need any special tools.
I used a 3/8" ratchet as the "removal" tool it was a Craftsman standard. Had no problems at all. I had the belt on at all positions except the AC. I moved the tesioner to the left (if facing the front of the truck) and my wife slipped the belt over the AC pulley -- walla done.
I will wirte up a full HOW TO Monday.
Can we get a HOW TO sticky going?
With this may people on this forum we should be able to pull this truck apart and put it back together ourselves!
Jizz is offline
post #10 of 26 Old 02-02-2008, 10:06 PM Thread Starter
OK maybe there was some confusion. I have a 2003 I4. It has 1 bolt holding on the tensioner.
Jizz is offline
post #11 of 26 Old 02-03-2008, 11:24 AM
Roadrunner=Chicken
Dozer600's Avatar
User is: Dozer600 is offline
The picture was with the tensioner bracket attached. Only one bolt holds the tensioner to the bracket. Same setup accross the board. Did mine a few years back.
Edit: Sorry I was late to the party. Very easy fix
Jason
98 2.2 5 speed
87 Astro (Next project: Topless with V8, lifted on a 80' Blazer frame)
54 John Deere 40U
00 Polaris 600 Touring
Dozer600 is offline
post #12 of 26 Old 02-03-2008, 11:33 AM
This season SUCKS.
dngrous_dime's Avatar
User is: dngrous_dime is offline
Send a message via AIM to dngrous_dime Send a message via MSN to dngrous_dime Send a message via Yahoo to dngrous_dime
Is it just me, or does that bracket look like it has a completely ****ED bolt pattern?
Brian
Originally Posted by 1fast4by View Post
Also, in case you were unaware Ass dynos never work
Originally Posted by MotorNut123 View Post
yea i graduated. My whole family is proud. High school graduation is a huge thing. At least for my family it is.
post #13 of 26 Old 02-03-2008, 10:50 PM
NOT AN S10
tg900's Avatar
bolt pattern is right at least for my 94-97 2.2 it was, i never had any problems yet on my 98+, keep in mind the top of that touches the engine block, so the spring pushes the pulley in
ELTC NEPA
tg900 is offline
post #14 of 26 Old 02-04-2008, 10:43 PM
Forum Dictator
What?'s Avatar
Im right here
alot post progress of upgrade and not just rebuild for stock thats why not much of these sticky
What? is offline
post #15 of 26 Old 09-14-2009, 06:12 PM
User is: evankeith is offline
Sorry to dig up an old thread, but I figured at least it shows I did search...haha
but anyway, I am about to change the tensioner on my 2001, and after a ton of picture looking, I have came across a few pics on e-bay, and those tensioners look nothing like these, it appears to only have one bolt in the center...
So my question is, am i looking at the wrong tensioner, or is that the correcct one, and if it is, what is the proper way to take it off? Im afraid if i just jump into it, I will let all the tension off, and it will go flying...haha
any one know?
post #16 of 26 Old 09-14-2009, 06:28 PM
sorry, heres the pictures I was talking about....
ID:	106249   Click image for larger version
ID:	106250   Click image for larger version
post #17 of 26 Old 09-14-2009, 06:35 PM
Tech Mod
beandip's Avatar
User is: beandip is offline
Yup that's it.
-Jonathan
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #18 of 26 Old 09-14-2009, 08:36 PM
so do I just remove that center bolt to take it off? and it wont come flying at me?
post #19 of 26 Old 09-14-2009, 09:45 PM
fish head's Avatar
User is: fish head is offline
You have to remove the belt first! lol
post #20 of 26 Old 09-14-2009, 09:46 PM
fish head's Avatar
I did mine a few weeks ago, it was not to bad to change out. It was making all kinds of noise with or without the a/c on.
post #21 of 26 Old 09-14-2009, 11:12 PM
smart ass...haha, but I kinda figured that one out already... and yeah, like I said in my other thread, it sounds like a damn cummins idling...
post #22 of 26 Old 09-15-2009, 06:39 AM
fish head's Avatar
I got you! Mine was very loud also.
post #23 of 26 Old 09-17-2009, 02:13 AM
User is: jpdodge150 is offline
Hey, my first truck when I was 16 was a 1ton dodge cummins dually flatbed farm truck with a 5spd getrag tranny. I loved that truck to death until I had to sell it due to health issues and other problems last summer. If my s10 started making such a sweet sound like a 12 valve cummins, I would most likely keep it like that for as long as I could...haha!
post #24 of 26 Old 09-17-2009, 01:14 PM
User is: ricksgsxr is offline
Great info! this is how I found this site as the Chilton manual has no specific r/r for this item.
I thought I toasted my motor with all the damn rattling but than the steering all of sudden got real hard to steer LOL!
It lasted 183,647 miles
Autozone $51-$63 here in Jacksonville with Autozone being the least expensive (97 S-10 2.2 4 cyl)
post #25 of 26 Old 09-18-2009, 07:31 PM
User is: kc5gxc is offline
On my '02 it's easy to get to belt tensioner from underneath after jacking up.
From the top it wud be a real pain.
Pete
kc5gxc is offline
post #26 of 26 Old 09-19-2009, 02:23 AM
The **** you lookin' at?
evanspears1's Avatar
User is: evanspears1 is offline
Send a message via MSN to evanspears1
yeah, it probably would have been easier from the bottom... I changed it this afternoon, I wouldve went from the bottom, but it rained earlier, and the ground was soft damn it, but even taking the fan shroud and all off took me only like 2 hours, and that was taking my time...
2001 Chevy S-10... Powered by your mom
Originally Posted by stv-lo
Will you tell your cat to stop looking at my pirate rodent like he's lunch? Or I'll make both of you walk the plank.
