#101 |
Pac is a hackin!
Re: HOW TO: Install Performace Pulleys
i had to order mine separately. almost a year later and no problems with em at all.
#102 |
Where can I get performance pulleys for a 2.2L? I may install an e-fan later, but I'm using a 235 watt amp pushing a small sub behind my seat. It's not impressive at all. What do I need to get a little more horsepower out of this engine, and where do I buy it?
Thanks. Charles. |
#103 |
Moderator
Truck Performance(if it isn't Backorder)
Www.aspracing.com With your setup, it isn't needed for alt pulley, but you can order with it so you have it ready and pay shipping once Last edited by What? : 10-27-2008 at 02:54 AM. |
#104 |
Loves The MPG
ok i know a lot of people on here have done this mod and i've seen a bunch of people bitching that these online store have taken months to ship the order. anyone know of the fastest place?
#105 |
So all I really need is a smaller crank pulley then? That will gain me a few horses? Thanks.
Charles. |
#106 |
SMOKINGACHICKEN
i dont think you get an alternator pulley with the asp crank pulley from truckperformance.com, if you go the asp website they have a universal alternator pulley tho i dont know if you can use that one. Comic where did you get your alternator pulley?
#107 |
shifting gears
I got the alternator pulley and decided not to use it. Crank only for me, which is fine since I don't have a big stereo. If someone wants it, let me know.
#108 |
94 2.2, feel the power?
Since you guys are only changing the crank and possibly the alt pulley, does it have too much affect on the a/c, power steering, and water pump? Im thinking about doing the swap, I just want to know how it affects them, obv. they will move slower then before, but does it hurt anything. Such as, does the a/c still feel as cold? i don't care as much about power steering, but i need the water pump to still be fine. Thanks
#109 |
is rockin' out to
#110 |
Moderator
Fastest way will be direct to www.aspracing.com
I used with and without alternator pulley, there was no affect on a/c losing any coldness, temperature increasing and whatnot, same as before |
#111 |
alright..thanks guys...this might be my next mod to my truck, trying to make it nicer and better gas mileage. Power is also nice thing to add, make it more efficient or lose less power to stupid things. Current project: finish adding a/c. Need it for my daily commute in Houston.
#112 |
Every thing works the same my a/c still blows cold also and im usually pushin 14v with the new sts alt pully. |
#113 |
i have a system in my truck...
1200 watts peak, 330 RMS. If i install JUST the crank pulley will the alternator be fine for that system? Will i need a new belt? |
#114 |
well your pushing quite a few extra amps. You might just want to pick up a alternator pulley from the junk yard. there were some other posts on this subject that some people just put a 2.4L sunfire alternator pulley on and didn't have problems.
#115 |
Pac is a hackin!
my new smaller alt pulley was like $8...
i would deffinately think about finding/getting one |
#116 |
could i just find a pulley from autozone that would work? (for the alternator, that is).
#117 |
i have a question about the belt nimbers...the ones you have listed are different from the numbers i got from the folks at asp...???they gave me Gates K060716...is this correct or should i just ignore thier reccomendation and just follow the sizes that were posted?they didnt ask me if i had a/c or anything...
#118 |
Pac is a hackin!
i tried about 3 different belt sizes untill i settled on one.
#119 |
I'm Back!!
not to hijack but here is my pulley install process and it was worth every penny. http://www.s10forum.com/forum/f105/2...esults-412780/ |
#120 |
X2 on worth every penny
#121 |
hey thanks for helping clear that up. my pulleys just arrived today.cant wait to install them.my truck has a hard time keeping p with traffic uphills.i can keep up but its hard to hit 55 in fifth gear. i usually get stuck at 50 and slowly build up speed.once i pass 55 then its easy to hit 60 and up.hopefully this helps.i did the e-fan and it helped me save gas, my a/c blows a little colder and i got some but not much horsepower gains. after this mod im thinking of doing the throttle body mod.
