Hit Brakes --> Reverse Lights Come On - S-10 Forum
post #1 of 4 Old 06-26-2011, 11:53 AM Thread Starter
User is: Reconn is offline
Alright so last night I got pulled over for what I figured was my tint.. However he came to the window and said that something was going on with my brake lights. He had me hit them for him again then did it for me to show me the problem..
Somehow when you hit the brakes, the brake lights dim and the reverse lights come on. Also the right turn signal goes very fast when the headlights are on, but not when they're off?
Any idea whats causing this? It really sucks cause it caused me to get a ticket for my tint as well when he noticed that.. Less than a week and I have to remove it already. =/
2000 S10 Xtreme
Reconn is offline
post #2 of 4 Old 06-26-2011, 12:20 PM Thread Starter
Re: Hit Brakes --> Reverse Lights Come On
Found this on popular mechanics..
My Reverse Lights Come on When I Hit the Brakes
August 2, 2010 at 2:04:00 PM by Mike Allen | 0 comments
Q: Every couple of months when I hit the breaks in my 1995 Toyota Camry, the reverse lights come on. They will do this for about a week and a half and then go back to only coming on when in reverse. What is causing this and how do I fix it?
A: There’s a bad ground somewhere near the tail lights, causing the brake lights to source their ground through the backup lights. Check ground point Ba1, which is in the trunk.
Read more: My Reverse Lights Come on When I Hit the Brakes - Popular Mechanics
Gonna mess with the ground by passenger side headlight, looks sort of corroded.
2000 S10 Xtreme
Reconn is offline
post #3 of 4 Old 06-26-2011, 01:29 PM
i saw what you did there!
fast68chevy's Avatar
yeah the dimming lights tell you bad ground issue
check the ground bolt on frame rail under tail end of bed near bumper it needs to be clean dry and good
may need to remove the bolt and clean rust etc
if that doesnt work then you may need to run new ground wires to both lights and make a nice new ground, can do it in sheetmetal as well
post #4 of 4 Old 06-26-2011, 03:04 PM Thread Starter
thats exactly what I did and it worked... found this post on google: http://www.fixya.com/cars/t1381686-c...il_light_issue
turned out my ground was terrible.. was checking the 5 grounds first then the main ground just snapped right off... took me about a half hour to get the bolt off due to rust... then i had to scrape the rust off and put a new connector on there.. and they work perfect now
2000 S10 Xtreme
Reconn is offline
